"Z probe already triggered at the start of the homing move."????
4.9k
    crchisholm
    On a coreXY printer:
    I have X and Y homing working as I would expect....home X and the bed drops about 10mm, X homes and the bed comes back up. When home X and Y, everything is fine. When I try to home Z, I get the message (above) saying that "Z probe already triggered" and the homing failes. I can't figure out what I have setup wrong. Below is my current config.g
    ; generated by RepRapFirmware Configuration Tool v2 on Fri Feb 01 2019 16:04:24 GMT-0500 (Eastern Standard Time)
    M667 S1 ; Select CoreXY mode
    M550 P"Core XY" ; Set machine name
    M552 S1 ; Enable network
    M587 S"BHNDVW3201B4B28" P"3c5d116a" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Drive 0 goes backwards
    M569 P1 S0 ; Drive 1 goes backwards
    M569 P3 S0 ; Drive 3 goes backwards
    M92 X80.00 Y99.3639 Z402.6845 E98.00 ; Set steps per mm
    M566 X900.00 Y900.00 Z150.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y6000.00 Z380.00 E1500.00 ; Set maximum speeds (mm/min)
    M201 X3000.00 Y500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
    M906 X950.00 Y950.00 Z950.00 E950.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y270 Z300 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active low and disabled endstops
    M574 Z1 S2 ; Set endstops controlled by probe
    M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X15:13 Y15:195 S20 ; Define mesh grid
    M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      Can you post your homing files as well?
      What type of probe is it?
      undefined 1 Reply Last reply 4 Feb 2019, 18:17 Reply Quote 0
        Have you tested your Z probe as described at https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
          crchisholm @Phaedrux
          @phaedrux I don't have a probe. I have an end-stop. That's part of what is confusing me.
            crchisholm
            Here are the homing files
            ; homex.g
            ; called to home the X axis
            G91 ; relative positioning
            G1 S1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000 ; go back a few mm
            G1 S1 X-305 F360 ; move slowly to X axis endstop once more (second pass)
            G1 Z-5 F6000 S2 ; lower Z again
            G90 ; absolute positioning
            ; homey.g
            ; called to home the Y axis
            G1 S1 Y-275 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F6000 ; go back a few mm
            G1 S1 Y-275 F360 ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            G1 X15 Y15 F6000 ; go to first probe point
            ;G91 ; relative positioning
            ;G1 S2 Z5 F100 ; lift Z relative to current position
            ;G90 ; absolute positioning
              crchisholm
              I say I don't have a probe, but actually I have a BLTouch (still uninstalled and in the original package). I have not printed anything to mount it too yet, so I was hoping to put that off until everything else was setup and working.
              Bad Plan???
              undefined 1 Reply Last reply 4 Feb 2019, 19:02 Reply Quote 0
                SupraGuy @crchisholm
                @crchisholm said in "Z probe already triggered at the start of the homing move."????:
                Bad Plan???
                I wouldn't say that it's a bad plan, particularly if you have everything that you need to get basic printing started without needing the BLTouch sensor to get started.
                Adding the sensor isn't too big a deal, and you can always revert back to a known working configuration if you decide that you need to print something else without getting it working.
                Lead screw driven printer, powered by Duet 2 Wifi
                MPCNC powered by Duet 2 Wifi
                CoreXY printer driven by Duet 3 6HC
                LowRider CNC powered by Duet 2 Wifi
                  ; homez.g
                  You can change your configuration to use a simple endstop for the Z axis for the time being, and setup the BLTouch later once you have the parts printed.
                  First you'll need to change the quoted config section above to match the following:
                  M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                  ; M574 Z1 S2 ; Set endstops controlled by probe
                  ; M558 P5 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
                  ; G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                  ; M557 X15:13 Y15:195 S20 ; Define mesh grid
                  Basically just added the Z min endstop to the first M574 command, and commented out the whole z probe section.
                  For the homing files you'll have to change homez and homeall to not use a G30 command and instead use G1 S1 Z move to seek the endstop.
                  ; homez.g
                  G1 S1 Z-300 ; seek end stop
                  G1 Z5 ; back up
                  G1 S1 Z-300 F300 ; home Z again slowly
                  G1 Z5 ; part nozzle 5mm above the bed
                  undefined 1 Reply Last reply 23 Feb 2019, 15:22 Reply Quote 0
                    SupraGuy
                    For that matter, you can set upt he printer to use a manual adjustment for the Z probe
                    M558 P0
                    This will allow you to use the Z jog buttons in the DWC as the Z probe, adjusting the Z height to 0 manually until you're ready to print the BLTouch parts.
                    My earlier response was assuming that you had an already complete kit though.
                      crchisholm
                      this worked great. Thanks.
                      One more question, though. Am I right to assume that the Duet supports either am min or max end-stop, but not both?
                      undefined 1 Reply Last reply 5 Feb 2019, 18:37 Reply Quote 0
                        Phaedrux Moderator @crchisholm
                        @crchisholm you really only need one or the other to home to, afterwards the firmware will enforce travel limits.
                        You can use one of the other endstops like e0 or e1 and use it as a general trigger endstop to do whatever you want if triggered. They can all be wired together if you use a switch on each axis for max.
                          @phaedrux question: the code you show above... can it be entered and exicuted directly in the DWC? I have my printer built and all functionality tested except the BlTouch, so I don’t want to do something now that creates a problem (like a crash into the bed). I think I understand the M557 and M558 commands, and a lessor understanding of the G29, G30 and G31 commands but not real confident yet. Ruining this sfuff like console commands would allow me to dip my toes in the process ( I think)
                            Yes every command can be run from the console. The config.g is just a list of commands that gets run in order at startup. There's nothing special about it other than that. Any time a new command is run it takes effect.
                            So you could enter each line one at a time in the console. Or to make for less typing you could enter the commands into a new macro file called BLTouch test and then run that macro. That way if you want to revert just reboot the duet. If it all tests ok you can put the commands into config.g.
                            The gcode wiki is a good reference to keep on hand for figuring out how the gcodes work.
                            G29 is for mesh bed leveling.
                            G30 runs the macro bed.g. and can be used for a number of things like lead screw leveling. It's not required.
                            G31 defines the XYZ position of the probe in relation to the nozzle tip. So when the probe triggers the system know where the nozzle is.
                              crchisholm
                              This post is deleted!
                              undefined 1 Reply Last reply 23 Feb 2019, 21:28 Reply Quote 0
                                crchisholm @crchisholm
                                  crchisholm
                                  Scachiundefined 1 Reply Last reply 23 Feb 2019, 21:40 Reply Quote 0
                                  • Scachiundefined
                                    Scachi @crchisholm
                                    @crchisholm You have your bltouch connected now ?
                                    Check your sensor signal wiring and the value of your probe-z shown in the web frontend.
                                    If it reads 1000 all the time you may have a wiring problem like bad crimp or using the wrong polarity of your probe signal cable or something like that.
                                    Check the documentation and all the test and probe release reset command mentioned there:
                                    https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
                                    undefined 1 Reply Last reply 23 Feb 2019, 22:25 Reply Quote 0
                                      crchisholm
                                      I don't know why I am having trouble typing here, but what I actually entered in DWC was...
                                      M557 X0:200 Y0:200 S50
                                      M558 P9 H5 F100 T6000
                                      G32
                                      and I get the Z Probe already triggered before probing move started.
                                      undefined 1 Reply Last reply 23 Feb 2019, 21:58 Reply Quote 0
                                        @crchisholm what do you have in bed.g? That's what gets run when you send g32
                                        undefined 1 Reply Last reply 23 Feb 2019, 22:30 Reply Quote 0
                                          crchisholm @Scachi
                                          @scachi Well, you called that one correctly! I have continuity on four or the five wires all the way from the termination point back to the jack on the BLTouch connector. The white wire does not. I am not sure what I can do about this as my eyes are just not up to working on a connector that small. I may have to return the device back to Amazon and order another. This is frustrating, but then, no body forced me to build this printer. Crap
