    IDEX Support
    60
    10.2k
    • iDeveloundefined
      iDevelo
      @dc42:
      New firmware 1.16 beta 5 with full IDEX support is now on GitHub.
      Awesome. I have movement on U!
      • iDeveloundefined
        iDevelo
        So far so good!
        https://youtu.be/-ALZAlP6Zqw
        • toshiundefined
          toshi
          I'm begin to design a coreXY printer and this idea of IDEX is an huge improvement I thing and i would like to upgrade with this. Good luck, you are in the good way !
            T3P3Tony administrators
            Cool idex on corexy? That's a first as far as I am aware!
            • botundefined
              bot
              I believe that dc42 came up with the idea of coreidexy on this forum, and harvested some ideas from the reprap forums. It is an idea that certainly has promise.
              *not actually a robot
                yes but the first implementation đŸ™‚
                • chrishammundefined
                  chrishamm administrators
                  I've just finished some preliminary work on Duet Web Control to support multiple axes. If you are using an IDEX configuration, you can try out my latest 1.13 beta 2 for Duet WiFi which is available here: https://www.dropbox.com/s/3eaafeubpfhsyge/DuetWebControl-1.13-b2.bin?dl=0. More features are coming soon!
                  Duet software engineer
                  • iDeveloundefined
                    iDevelo
                    Oh man!
                    • iDeveloundefined
                      iDevelo
                      @chrishamm:
                      Actually now i can't create Macros. I get an error saying could not update the file.
                      • iDeveloundefined
                        iDevelo
                        And i can't roll back. I uploaded the stable version and it asks if i want to install but it never does. How can i manually install the old version?
                        • iDeveloundefined
                          iDevelo
                          And i can't upload and print…...
                            To roll back, copy the version 1.12 DuetWiFiFirmware.bin file to /sys on the SD card (by moving the SD card to a PC temporarily if necessary), then run M997 S2.
                            • iDeveloundefined
                              iDevelo
                              https://youtu.be/oyrjId29BgM
                                Saw this awesomeness on Twitter, good Job. Following on from that conversation, I am not really up to speed on corexy however I am guessing you have you U axis Min and max at opposite ends from the X axis Min and max?
                                • iDeveloundefined
                                  iDevelo
                                  Oh Tony it's not corexy anymore. I converted to Cartesian in the end.
                                    Ahh you never said! Whoops. In that case just chance your U axis to move in the same direction as the X axis and tell it that the U axis microswitch is a max not a Min.. the Wiki page example is a good starting point
                                    • iDeveloundefined
                                      iDevelo
                                      Haha sorry!
                                      Getting close. Need to sort purging and retractions a little.
                                        Looking good! I am not bothering with a purge tower as the nozzles will be off the bed when not in use and I am working on how to handle purge and ooze. You have good alignment of the heads there, I will share my calibration file.for head alignment when I get a chance.
                                        • iDeveloundefined
                                          iDevelo
                                          https://youtu.be/k2RNLKLt2Uc
                                            Well done for getting this far, and for posting the first video of an IDEX print on a Duet WiFi. Let me know if you find anything wrong in the IDEX firmware support in 1.16 beta 5.
