    IDEX Support
    60
    10.4k
      Yes, see https://duet3d.com/wiki/Configuring_multiple_independent_X-carriages_on_a_Cartesian_printer#Miscellaneous.
      • iDeveloundefined
        iDevelo
        Awesome! I'll make sure both are the same height then ๐Ÿ™‚
          I have a put preliminary build of firmware 1.16 beta 4 at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiFirmware.bin. This supports X axis mapping. So you should now be able to do dual material and mirrored prints on IDEX machines.
          Some notes:
          1. I have updated the sample tool change files on the wiki page. In particular, you should not use the G1 R2 commands in the tpost#.g files that I had in the earlier version.
          2. The reported coordinates are raw, which is deliberate. So the X coordinate shown by DWC is that of the physical X axis regardless of any mapping. Same with M114. If you have a PanelDue and you put the latest 1.15a firmware on it, you can see the U coordinate as well. Eventually, DWC will show the U coordinate as well.
          3. Make sure that the commands in your homing files that cause the head to back off a few mm after dong course homing have the S2 modifier on them, so that X mapping will not occur on those commands. Similarly, any command you have in homez.h or homeall.g to put the head in a particular position prior to doing a G30 probe should have the S2 modifier to ensure that you put the X carriage there and not the U carriage.
          4. I suspect there will be a few glitches, such as additional places where X mapping needs to be done. Most likely they will occur when changing between tools. This is something that I can't test fully, because I don't have a dual carriage printer yet.
          • iDeveloundefined
            iDevelo
            Ok I'll keep you updated with my progress and report any issues.
            I should get some movement this weekend but I doubt I'll beable to print as I'm waiting for a bondtech extruder to arrive. My main aim is to get X/U complete and test homing and bed leveling.
            I have plenty of time next week to complete this.
            Thanks for your hard work ๐Ÿ™‚
              T3P3Tony administrators
              I have mirrored printing working on by BigBox IDEX system:
              I made a few changes to the Wiki so if you are working on this make sure you are using the most up to date examples from there. My configuration does not differ from the example on the wiki other than for steps/mm dimensions and other printer specific stuff.
              • iDeveloundefined
                iDevelo
                @T3P3Tony:
                https://s9.postimg.org/4rrky828f/Big_Box_IDEX_with_Duet_Wifi.jpg
                Well done!
                  New firmware 1.16 beta 5 with full IDEX support is now on GitHub.
                  • iDeveloundefined
                    iDevelo
                    @dc42:
                    Awesome. I have movement on U!
                    • iDeveloundefined
                      iDevelo
                      So far so good!
                      https://youtu.be/-ALZAlP6Zqw
                      • toshiundefined
                        toshi
                        I'm begin to design a coreXY printer and this idea of IDEX is an huge improvement I thing and i would like to upgrade with this. Good luck, you are in the good way !
                          Cool idex on corexy? That's a first as far as I am aware!
                          • botundefined
                            bot
                            I believe that dc42 came up with the idea of coreidexy on this forum, and harvested some ideas from the reprap forums. It is an idea that certainly has promise.
                            *not actually a robot
                              yes but the first implementation ๐Ÿ™‚
                              • chrishammundefined
                                chrishamm administrators
                                I've just finished some preliminary work on Duet Web Control to support multiple axes. If you are using an IDEX configuration, you can try out my latest 1.13 beta 2 for Duet WiFi which is available here: https://www.dropbox.com/s/3eaafeubpfhsyge/DuetWebControl-1.13-b2.bin?dl=0. More features are coming soon!
                                Duet software engineer
                                • iDeveloundefined
                                  iDevelo
                                  Oh man!
                                  • iDeveloundefined
                                    iDevelo
                                    @chrishamm:
                                    Actually now i can't create Macros. I get an error saying could not update the file.
                                    • iDeveloundefined
                                      iDevelo
                                      And i can't roll back. I uploaded the stable version and it asks if i want to install but it never does. How can i manually install the old version?
                                      • iDeveloundefined
                                        iDevelo
                                        And i can't upload and printโ€ฆ...
                                          To roll back, copy the version 1.12 DuetWiFiFirmware.bin file to /sys on the SD card (by moving the SD card to a PC temporarily if necessary), then run M997 S2.
                                          • iDeveloundefined
                                            iDevelo
                                            https://youtu.be/oyrjId29BgM
