Firmware 2.03beta2 available
Firmware installation
25
86
12.2k
    I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/2.03beta2. Highlights include:
    • Configurable endstop assignments
    • Configurable minimum speed
    • Fan speed is scaled by M106 X parameter
    • Leadscrew bed levelling bug that was introduced in firmware 2.03beta 1 is fixed
    I would particularly welcome feedback from users of CoreXY and similar printers. Please read the upgrade notes first.
    undefined undefined 2 Replies Last reply 16 Feb 2019, 16:03 Reply Quote 1
      john park @dc42
      @dc42 thank you ^^
        boldnuts
        I can confirm that Leadscrew bed leveling is fixed, thanks
        Leadscrew adjustments made: -0.008 0.016, points used 2, deviation before 0.009 after 0.000
        15:55:54M98 P"0:/macros/X Axis callibration"
        Leadscrew adjustments made: -0.088 -0.086, points used 2, deviation before 0.087 after 0.000
        undefined 1 Reply Last reply 16 Feb 2019, 16:06 Reply Quote 0
          dc42 administrators @boldnuts
          @boldnuts said in Firmware 2.03beta2 available:
          That was quick!
            deckingman @dc42
            @dc42 When I get a mo, I'll try this out and see if I can home my 3rd gantry. Could you expand on how to use the configurable end stop assignments please? The release notes say .....
            "M574 allows endstop input numbers to be configured (C parameter). Currently only the first input number specified for each axis is monitored."
            Can you expand on how to use this "C" parameter please - instructions haven't made it to the wiki yet.
            undefined 1 Reply Last reply 16 Feb 2019, 16:14 Reply Quote 0
              dc42 administrators @deckingman
              @deckingman said in Firmware 2.03beta2 available:
              Here's an example of swapping the X and Y endstop inputs:
              M574 X1 S1 C1 ; X endstop is connected to input 1 which is labelled Y
              M574 Y1 S1 C0 ; Y endstop is connected to input 0 which is labelled X
              undefined 1 Reply Last reply 16 Feb 2019, 16:35 Reply Quote 0
                deckingman @dc42
                @dc42 said in Firmware 2.03beta2 available:
                Thanks. One more question. I assume that if I go into the machine properties section of DWC, then in your example above, if I trigger the endstop for the X axis I would expect the Y axis switch to trigger. Correct? Or is the Machine Properties section of DWC clever enough to know that the switches have been re-mapped?
                  The endstop states are passed to DWC after remapping, so DWC should read correctly.
                  undefined 1 Reply Last reply 16 Feb 2019, 21:12 Reply Quote 0
                    Edgars Batna
                    Just did a quick print on my CoreXY. No obvious issues.
                      dragonn
                      CoreXY - everything seems to working fine.
                        deckingman @dc42
                        @dc42 Sorry to be a pain but for the purpose of re-mapping end stops, can I just ask if the following input assignments vs labels is correct?
                        On the Duet Ethernet......
                        Label "X" is input 0
                        Label "Y" is input 1
                        Label "Z" is input 2
                        Label "E0" is input 3
                        Label "E1" is input 4
                        On the Duex 5.........
                        Labels E2 to E6 are respectively inputs 5 to 9.
                        Is that correct?
                        undefined 1 Reply Last reply 16 Feb 2019, 21:18 Reply Quote 0
                          Is that correct?
                          Correct. Also inputs 10 and 11 are the two on the CONN_LCD connector. It's the same numbering as in the M591 command.
                          undefined 1 Reply Last reply 16 Feb 2019, 21:32 Reply Quote 0
                            deckingman @dc42
                            @dc42 Thanks. - I don't have any filament sensors so I've never looked at M591.
                            May I suggest that this input numbering vs label be included in the Wiki somewhere. Either in the section entitled "connecting end stop switches" or in the section dealing with M574. I don't think I trust myself to edit the Wiki personally but I'll have a go if you like.
                            undefined 1 Reply Last reply 19 Feb 2019, 12:35 Reply Quote 0
                              Next time we revise the Duet we will number the endstop inputs and motor outputs, instead of giving them axis and extruder labels.
                              undefined 1 Reply Last reply 16 Feb 2019, 21:36 Reply Quote 0
                                deckingman @dc42
                                Yes I believe you've said that before - makes perfect sense. Hindsight is always 20:20 ☺
                                  deckingman
                                  Just want to report that this (firmware 2.03 beta2) is all working well for me. CoreXYUV is all doing what it should do. Also I have been able to get homing working on my 3rd gantry by temporarily assigning both drives and end stops to X and Y axes.
                                  The homing file is a bit complicated because basically I'm homing 7 axes - initially a course home, followed by a finer home at slower speed for each axis. Then re-mapping all drives and end stops so that for printing, it becomes a 3 axis machine.
                                  Anyway, big thanks to David.
                                    AndreS @deckingman
                                    I have put it in with M574.
                                    undefined undefined 2 Replies Last reply 19 Feb 2019, 13:04 Reply Quote 2
                                      deckingman @AndreS
                                      @andres said in Firmware 2.03beta2 available:
                                      Thanks - I'm sure others will appreciate that information.
                                        wilriker @AndreS
                                        And for the sake of completeness I also added a table to Connecting endstop switches in the wiki.
                                        Manuel
                                        My Tool Collection
                                        undefined 1 Reply Last reply 19 Feb 2019, 13:38 Reply Quote 3
                                          deckingman @wilriker
                                          @wilriker Very nice ☺
                                          10 out of 86
