    Firmware 2.03beta2 available
    Firmware installation
    25
    86
    12.2k
      The endstop states are passed to DWC after remapping, so DWC should read correctly.
      • Edgars Batnaundefined
        Edgars Batna
        Just did a quick print on my CoreXY. No obvious issues.
        • dragonnundefined
          dragonn
          CoreXY - everything seems to working fine.
            deckingman @dc42
            @dc42 Sorry to be a pain but for the purpose of re-mapping end stops, can I just ask if the following input assignments vs labels is correct?
            On the Duet Ethernet......
            Label "X" is input 0
            Label "Y" is input 1
            Label "Z" is input 2
            Label "E0" is input 3
            Label "E1" is input 4
            On the Duex 5.........
            Labels E2 to E6 are respectively inputs 5 to 9.
            Is that correct?
              dc42 administrators @deckingman
              @deckingman said in Firmware 2.03beta2 available:
              Is that correct?
              Correct. Also inputs 10 and 11 are the two on the CONN_LCD connector. It's the same numbering as in the M591 command.
                deckingman @dc42
                @dc42 Thanks. - I don't have any filament sensors so I've never looked at M591.
                May I suggest that this input numbering vs label be included in the Wiki somewhere. Either in the section entitled "connecting end stop switches" or in the section dealing with M574. I don't think I trust myself to edit the Wiki personally but I'll have a go if you like.
                AndreSundefined 1 Reply Last reply Reply Quote 0
                  Next time we revise the Duet we will number the endstop inputs and motor outputs, instead of giving them axis and extruder labels.
                    deckingman @dc42
                    @dc42 said in Firmware 2.03beta2 available:
                    Yes I believe you've said that before - makes perfect sense. Hindsight is always 20:20 ☺
                      deckingman
                      Just want to report that this (firmware 2.03 beta2) is all working well for me. CoreXYUV is all doing what it should do. Also I have been able to get homing working on my 3rd gantry by temporarily assigning both drives and end stops to X and Y axes.
                      The homing file is a bit complicated because basically I'm homing 7 axes - initially a course home, followed by a finer home at slower speed for each axis. Then re-mapping all drives and end stops so that for printing, it becomes a 3 axis machine.
                      Anyway, big thanks to David.
                      • AndreSundefined
                        AndreS @deckingman
                        I have put it in with M574.
                        deckingmanundefined wilrikerundefined 2 Replies Last reply Reply Quote 2
                          deckingman @AndreS
                          @andres said in Firmware 2.03beta2 available:
                          Thanks - I'm sure others will appreciate that information.
                          • wilrikerundefined
                            wilriker @AndreS
                            And for the sake of completeness I also added a table to Connecting endstop switches in the wiki.
                            Manuel
                            My Tool Collection
                            deckingmanundefined 1 Reply Last reply Reply Quote 3
                              deckingman @wilriker
                              @wilriker Very nice ☺
                                I've put an update to firmware 2.03beta2 for the Duet WiFi/Ethernet and Maestro at https://www.dropbox.com/sh/mk3jlsoi6gyxd8q/AABbEvX2qb19McbRe6UvRmI9a?dl=0. Changes in this version:
                                • New M505 command to support multiple configurations more easily (see separate thread)
                                • Bug fix for file selection on 12864 displays on the Maestro
                                • Bug fix for CNC and laser machines (was complaining about attempts to move outside the allowed limits during homing)
                                • Increase max numbers of extruders and heaters per tool to 8 on the Duet WiFi/Ethernet
                                • Babystepping command (M290) now works on any axis, however at present only Z babystepping can jump moves in the movement queue
                                • NicoLab28undefined
                                  NicoLab28
                                  there have been changes for the M291 triggers / messages in tool change macros?
                                    dc42 administrators @NicoLab28
                                    @nicolab28 said in Firmware 2.03beta2 available:
                                    M291 sets baby stepping, it has nothing to do with triggers.
                                      NicoLab28
                                      M290 is for baby stepping.
                                      I'm talking about blocking tool change macro with a message using trigger and M582.
                                      When we put M291 command in trigger#.g
                                      https://forum.duet3d.com/topic/8381/m291-s2-does-not-block-macro-execution
                                        My mistake, M291 is for displaying messages and optionally waiting for a response.
                                        What are you trying to use M291 in a trigger to do?
                                          NicoLab28
                                          Interrupt the tool change macro, to make a manual intervention, and resume.
                                          In tfree.g tpre.g or tpost.g, if we make an M582, then an M291 in trigger # .g the message arrives after the end of the tool change.
                                          As a result, the problem could not be resolved
                                          • pawPrinterundefined
                                            pawPrinter
                                            CoreXY working well here, along with leadscrew bed levelling and sensorless homing
