    X and Y surging / hesitant / pulsing while returning from homing
    2.1k
      Ok with the volume up loud I can hear that the motor sound isn't fluid when returning to the home position.
      What happens if you do a test print?
      Are your motor currents within range of 85% of rated max?
      • Excelonundefined
        Excelon
        No, I believe those steppers are rated for 1.68amps (1680)and I have it set to 0.8 ( 800 ). Could that cause it?
        I lowered the amps on everything because the steppers are too loud when @ rated amps
          Do you have the spec sheet for the motors?
          Well we don't know whether the hesitation sound actually has any negative effect on printing. It'll be a balance between sound and power.
          Excelonundefined 1 Reply Last reply Reply Quote 0
          • Excelonundefined
            Excelon @Phaedrux
            @phaedrux
            All the stepper motors are from E3D. Here is the link to the steppers.
            https://e3d-online.com/motors-compact-but-powerful-motor
            I do have to say that the pulsing and hesitation is getting worse. Now, instead of the steppers pausing once or twice while returning from home its doing it about every 15mm, or so... Could I have a bad board?
            • Excelonundefined
              Excelon
              @dc42 and @Phaedrux
              So, I wanted to change out the Duet 2 wifi board to see if I had a faulty board so I removed the one from the Ender 3 that hasn't been turned on in months.
              Verdict? The steppers DID NOT jerk or hesitate while returning from homing, but as soon as I started a print it DID. Long story short ( I'll cut out how exactly I found this ) the steppers only jerk/hesitate when the mesh map is loaded and active.
              WHY?
                WHY?
                Jerk set too low.
                https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation#Section_Troubleshooting
                If you get jerky movements when the head moves across the bed at speed with mesh bed levelling enabled, but not with it disabled, this indicates that your Z jerk setting is too low for the travel speed you are using and the amount of compensation needed. Increase the Z parameter in the M566 command in config.g, or use a lower travel speed.
                • Excelonundefined
                  Excelon @Phaedrux
                  @phaedrux
                  @excelon said in X and Y surging / hesitant / pulsing while returning from homing:
                  @dc42 and @Phaedrux
                  WHY?
                  Ok.... for 'Z'... I don't think I changed the Z axis. Only X and Y since though were the only ones giving me issues. Let me try this! Thank you
                    I have a very slow Z axis with a heavy bed and I use a jerk and acceleration value of 60 for each. Seems to work out ok.
                    • Excelonundefined
                      Excelon @Phaedrux
                      @phaedrux said in X and Y surging / hesitant / pulsing while returning from homing:
                      I like to use a lower jerk value for when the print requires supports since it's hardest to print supports. It's mostly just the first layer and sometimes the start of the second.
                      NOTE: I raised the Z jerk and it's not doing it now. Thanks guys. Sorry, I had to find out the hardway. I am hard headed!
                        Glad it's working.
