    Print problems and fixes
    33
    2.8k
    • Wes Howeundefined
      Wes Howe
      The first things I would do is make sure the bed is clean (glass cleaner), carefully check that my extruder barely touches the bed at zero (I see you have a probe, maybe recheck the Z offset). If you raen't using that for mapping, make sure the bed is level across and at all 4 corners. These are the things that always bite me, not Cura or Simplify (have not used the others in a long time).
      Of the settings you have that I think significantly differ from mine are that I use a bed temp of 50 C. I also use a thinner first layer, 50% or 75%.
      • Wes
      p.s. Not sure what the object was. I don't usually use rafts, I try to design my way around them. I do always use a skirt to help make sure the extruder is pumping well before it prints the first layer.
      chriskimbrundefined 1 Reply Last reply Reply Quote 1
      • chriskimbrundefined
        chriskimbr
          chriskimbr @Wes Howe
          @wes-howe Using brand new PEI Sheet. Its clean.
          Bed Temp has no effect. sticking fine to bed.
          My offset is showing...
          M98 P"0:/macros/G30 S1"
          Stopped at height 0.967 mm
          So i have this in my config.g
          G31 P25 X-20 Y-45 Z0.97 ; Set Z probe trigger value, offset and trigger height
          First Layer Looks fine, its the subsequent layers that is out of whack.
            dc42 administrators @chriskimbr
            @chriskimbr said in Print problems and fixes:
            Have you checked that you have the correct Z steps/mm value, so that when you command the head 50mm up it really does move 50mm?
            Also, what hot end thermistor does your printer use, and what M305 P1 settings do you have in config,g?
            chriskimbrundefined 2 Replies Last reply Reply Quote 2
              Is your thermistor configured correctly?
              Have you done a PID tuning of the hotend?
              Have you calibrated e steps per mm?
              Is the cooling fan duct blowing onto the print or onto the hotend?
              That's a very small object to print at 80mm/s base speed.
              Maybe include you config.g?
              chriskimbrundefined 2 Replies Last reply Reply Quote 0
                chriskimbr @dc42
                @dc42 Have you checked that you have the correct Z steps/mm value, so that when you command the head 50mm up it really does move 50mm?
                How and where do I check the z steps value?
                I got a thermistor from Local store, no paperwork, he said it was standard 100k thermistor.
                Config.g
                ; generated by RepRapFirmware Configuration Tool v2 on Sat Feb 09 2019 18:37:46 GMT+0000 (GMT)
                M667 S1 ; Select CoreXY mode
                M550 P"TronXY X5SA" ; Set machine name
                M552 S1 ; Enable network
                ;*** Access point is configured manually via M587
                M586 P0 S1 ; Enable/Disable HTTP S0=disable S1=enable
                M586 P1 S1 ; Enable/Disable FTP
                M586 P2 S1 ; Enable/Disable Telnet
                M569 P0 S0 ; Drive 0 goes backwards
                M569 P1 S0 ; Drive 1 goes backwards
                M569 P3 S0 ; Drive 3 goes backwards
                M92 X80.00 Y80.00 Z400.00 E96.00 ;steps per mm
                M566 X900.00 Y900.00 Z12.00 E500.00 ; Set maximum instantaneous speed changes (mm/min)
                M203 X9000.00 Y9000.00 Z180.00 E3000.00 ; Set maximum speeds (mm/min)
                M201 X1500.00 Y1500.00 Z20.00 E800.00 ; Set accelerations (mm/s^2)
                M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X330 Y330 Z400 S0 ; Set axis maxima
                M574 X1 Y1 S0 ; Set active high endstops
                M574 Z1 S2 ;Define Z to use Probe. Home to Min.
                ;M591 D0 P2 C3 S1 ; Filament sensor on for E0 extruder, simple NO switch connected to E0
                M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
                ;G31 P25 X-20 Y-45 Z0.475 ; Set Z probe trigger value, offset and trigger height
                ;G31 P25 X-20 Y-45 Z1.2132 ; Set Z probe trigger value, offset and trigger height
                M557 X30:315 Y15:315 S75 ; Define mesh grid
                M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
                ;M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                M305 P1 R4700 T100000 B4388 ; set E0 thermistor parameters
                M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 ; Define tool 0
                  If it's a standard Chinese thermistor then this line won't give accurate temperatures:
                  Try changing the B parameter to B3950. This still won't be very accurate, but it will give the same results as Marlin temperature table 11, which is what most 8-bit controllers use with this type of thermistor.
                  chriskimbrundefined 1 Reply Last reply Reply Quote 0
                  • chas2706undefined
                    chas2706
                    Hi, I have same printer. I notice your stepper currents are set at 800. If you original steppers from tronxy they have maximum current rating of 1.68 so yours should be set at 85% which is just over 1.4.
                      dc42 administrators @chas2706
                      @chas2706 said in Print problems and fixes:
                      I don't know that printer, but if the motors are attached to plastic parts then you may find that at 1.4A the motors get hot enough to soften the plastic. I find that 1.68A motors run well enough at 1.0A or 1.2A in my printers.
                      • chas2706undefined
                        chas2706
                        Thank you for that dc42. I shall reduce mine.
                        By the way, this board is the bee's knees and your commitment to it and the forum are outstanding.
                          chriskimbr @dc42
                          @dc42 Sorry forum won't let me uncomment this line says its spam.
                          Ive been using this line ...
                          Do i need the C7.060000e-8 value?
                          I got this from someone elses config and am not sure if i need it or what to set mine at.
                          • antlestxpundefined
                            antlestxp
                            have you checked that all of you axis are going the proper distances (step per mm). you can check by jogging the tool head along a ruler so you don't have to run a print.
                              chriskimbr @Phaedrux
                              I ran this command to do the PID test.
                              M303 H1 S240
                              What does this mean? what to do next?
                                https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                                After running the tuning M500 will save the results to config-override.g and then you must add M501 to config.g to load config-override.g at startup.
                                • NicoLab28undefined
                                  NicoLab28
                                  check relative extruder, you never know
                                  • DocTruckerundefined
                                    DocTrucker @NicoLab28
                                    @nicolab28 said in Print problems and fixes:
                                    Certainly check extruder e-steps but absolute or relative extrusion doesn't have that much effect.
                                      NicoLab28
                                      On one of my printer, the nozzle closes continuously, and checking this box, no more worries.
                                      He has an M83, and S3D gives him an absolute gcode
                                        chriskimbr @dc42
                                        @dc42 I stuck a ruler and moved x, y , z. spot on.
                                          @phaedrux Is this where are you seeing 80mm/s base speed?
                                          Whats the difference, Don't they both set the microstepping speed? does one override the other? what is the correct speed to have with my issues?
                                            Phaedrux Moderator @chriskimbr
                                            No I got it from your screen shot from S3D here:
                                            4800mm/min = 80mm/s
