big box madness
none of those are for pt100 or pt1000 thermistors
check the configurator for the sensor channel to set it correctly
https://configurator.reprapfirmware.org/Heaters -
@veti cheers for the help, i have changed to the pt100, but still have the same issue. where should i then pin the two wires into the board,
to the external RTD interface board
https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
@veti i have tried it and still cant connect the bloody thing. so ive found the daugherboard connection point on the duet. that has 10 pins. i only have 4 wires (dual extruders' with two sets of black and red wires connected together) I just dont know where to put the bloody things. the images on the page you supplied are not very helpful and i cant crack the schematic. i think im just being stupid.
@magdi Do you have a PT100 daughterboard?
@phaedrux i have a pt100 board but it came with my e3d v6 not the same as the duet one.
@magdi So you got this? https://e3d-online.com/pt100-amplifier-board
@phaedrux yep two of those badboys,
Alright, sorry to say, but I don't think that will work. You'll need the daughterboard.
https://e3d-online.dozuki.com/Wiki/E3D_PT100_Amplifier_Documentation
https://e3d-online.dozuki.com/Wiki/Temperature_Sensor_Documentation#Section_PT100 -
@phaedrux right is there not way just just bypass the pt100 and just connect the thermistor to the duet board?
Well if the sensor is a PT100 sensor, then no, it needs the daughterboard to interface with the duet. If you have a seperate regular thermistor, then yes, it could be connected to the thermistor input.
@phaedrux i have a separate thermistor sorry i should of said that, the thermistor fist into the pt100 but i dont understand why i cant just put it in the motherboard. temps are still wrong when i do that
Here's how you connect a regular thermistor.
https://duet3d.dozuki.com/Wiki/Connecting_thermistors_or_PT1000_temperature_sensors
@phaedrux thanks for the help as always. have just done it. temps are now ~280 so we we need another 90%hit! print head is stone cold.
M305 P0 R4700 T100000 B3950 (for the bed WORKS!)
M305 P1 R4700 T100000 B4725 C0.0000000706 (HOT END NOT WORKS) -
Is this an e3d thermistor?do you know the values to use for it?
@phaedrux yes used the ones as advised on the wiki
no you connected a pt100 and configure a ATC Semitec 104GT-2. that does not work.
you need to get a ATC Semitec 104GT-2 or get the pt100 daugther board
@Veti it has been done before
https://forum.e3d-online.com/threads/bigbox-duetwifi-controller.1766/
so im confused now haha!
the dude got it to work with
;*** If you have a Duet board with 1K thermistor series resistors, change R4700 to R1000 to the following M305 commands
M305 P0 T100000 B4388 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
M305 P1 T100000 B4388 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
M570 S120 ; Increase to allow extra heating time if needed
M106 F10 ; Fix for Bigbox Blower -
you just bought the wrong thermistor.
that config is not for a pt100 sensor that you boughtyou got this.
https://e3d-online.com/pt100-temperature-sensor
you needed to buy this.
https://e3d-online.com/thermistor-cartridge -
@veti im with you now!
thanks so much
will feedback once i get the new thermistors
