Newbe need help duet ethernet printinmg headtower fails
Hello
I tryed to print headtower, but if the print start the heater and the beg go to temperature 1.
I am comingh from Radds 1.5 and Repetier
Can you help me?here is my cura start script:
M107 ; Stopp Fan
M83
M92 X80.40 Y80.40 Z800.00 E440.50:837.00 ; Set steps per mm
M201 X1500 Y1500 Z300 E10000 ;Set max printing acceleration
M201 X3000.00 Y3000.00 Z300.00 E10000.00:10000.00
T0
M106 P1 S255
M190 S[bed0_temperature] T0
M109 S[extruder0_temperature] T0
G28; home all axes
G90; set positioning to absolute
G92 E0 ; set E to 0
G1 E15 F300 ; fill up nozzle from previous retract
G1 Z0 F6000; set nozzle to first layer height
G1 F12000; ensure fast travel to first print move
G92 E0; set E to 0 againAnd here a bit from the gode:
;POSTPROCESSED
;ChangeAtZ instances: 1
;Generated with Cura_SteamEngine 3.6.0
T0
M190 S110
M104 S260
M109 S260
M82 ;absolute extrusion mode
M107 ; Stopp Fan
M83
T0
M106 P1 S255
G28; home all axes
G92 E0 ; set E to 0
G92 E0; set E to 0 againM83 ;relative extrusion mode
G1 F3000 E-4.5
;LAYER_COUNT:500;LAYER:0
M107
G0 F1800 X119.08 Y102.422 Z0.2
;TYPE:SKIRT
G1 F3000 E4.41685
G1 F1800 X119.623 Y101.849 E0.02626
G1 X120.222 Y101.334 E0.02627
G1 X120.87 Y100.883 E0.02626
G1 X121.561 Y100.499 E0.02629
G1 X122.286 Y100.187 E0.02625
G1 X123.039 Y99.95 E0.02626
G1 X123.813 Y99.791 E0.02628
G1 X124.598 Y99.71 E0.02625
G1 X125 Y99.7 E0.01337
G1 X175 Y99.7 E1.66301
G1 X175.789 Y99.74 E0.02628
G1 X176.569 Y99.859 E0.02624
G1 X177.334 Y100.057 E0.02628
G1 X178.074 Y100.331 E0.02625
G1 X178.783 Y100.679 E0.02627
G1 X179.454 Y101.097 E0.02629
G1 X180.078 Y101.58 E0.02625
G1 X180.651 Y102.123 E0.02626
G1 X181.166 Y102.722 E0.02627
G1 X181.617 Y103.37 E0.02626
G1 X182.001 Y104.061 E0.02629
G1 X182.313 Y104.786 E0.02625
G1 X182.55 Y105.539 E0.02626
G1 X182.709 Y106.313 E0.02628
G1 X182.79 Y107.098 E0.02625
G1 X182.8 Y107.5 E0.01337
G1 X182.8 Y157.5 E1.66301
G1 X182.76 Y158.289 E0.02628
G1 X182.641 Y159.069 E0.02624
G1 X182.443 Y159.834 E0.02628
G1 X182.169 Y160.574 E0.02625
G1 X181.821 Y161.283 E0.02627
G1 X181.403 Y161.954 E0.02629
G1 X180.92 Y162.578 E0.02625
G1 X180.377 Y163.151 E0.02626
G1 X179.778 Y163.666 E0.02627 -
@eckbert0815 said in Newbe need help duet ethernet printinmg headtower fails:
I'm sorry, I don't understand your problem description. Have you tested and tuned the bed heater and extruder heater?
I dia a pid tuning and saved it with M500.
The problem is, when the print starts, the heater goes from 260° to 1° and teh bed from 110° to 1°- -
@eckbert0815 Looks like it's something to do with your slicer settings.
In the actual gcode file these lines are fine
M190 S110
M104 S260
M109 S260but a little later are these lines
M109 S[extruder0_temperature] T0The firmware won't understand those commands.
Thanks, now i have the next problen, big elephantfeeds and overextrusion.
@eckbert0815 I'm not surprised.
For your steps per mm you have M92 X80.40 Y80.40 Z800.00 E440.50:837.00 ;
But that's in you slicer start script. Why are you making those settings in your slicer and not your configuration files? More importantly, why do have two completely different values for each extruder? Do you have one with a 1.8 degree motor and the other with a 0.9 degree motor?
You haven't told us anything about your printer or your configuration settings, other than the start script you use in Cura. I suggest you read this then come back with the information that is needed for someone to be able to help. https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
You are right, i told you nothing!
With radds and repetier is it easier to cofigurate the printer with the startcode, otherwise you have to flash a new firmware or edit it on the printer self.Let`s start again!
Ich have a core xy see picture.
Technial details:
Modell: NoName
Hotend: Nf tc-01 full Metall Heatbrak, 0.41 Microswiss Nozzle
Extruder: 2x Titan Bowden one with 1.8° stepper and one with 0.9°
Pancake stepper.
Filament: ABS-X Schmelzbar
Firmware: Duet (RepRap)
Slicer: Cura 3.6New Cura Startcode: (works fine)
T0
M116
M106 P1 S255
G28 Y X ;home X and Y axes
G1 Z20 F6000 ;Move the platform down 0mm
G28 Z ;home Z axes
G1 Z0 F6000 ;Move the platform down 0mm
G92 E0
G1 F200 E3
G92 E0New config.g
; generated by RepRapFirmware Configuration Tool v2 on Wed Mar 06 2019 16:12:25 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M555 P1 ; Set firmware compatibility to look like RepRapFirmare
M667 S1 ; Select CoreXY mode; Network
M550 P"R2D2" ; Set machine name
M540 PBE:04:32:3E:51:3A ; Set custom MAC address
M552 P0.0.0.0 S1 ; Enable network and set IP address
M553 P255.255.255.0 ; Set netmask
M554 P192.168.1.1 ; Set gateway
M586 P0 S1 ; Enable HTTP
M586 P1 S1 ; Enable FTP
M586 P2 S1 ; Enable Telnet; Drives
M569 P3 S0 ; Drive 3 goes backwards
M569 P4 S0 ; Drive 4 goes backwards
M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation
M92 X80.40 Y80.40 Z800.00 E918.03:837.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X10000.00 Y10000.00 Z500.00 E1500.00:1500.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z300.00 E10000.00:10000.00 ; Set accelerations (mm/s^2)
M906 X1900.00 Y1900.00 Z1900.00 E1900.00:1400.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X300 Y265 Z245 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active low and disabled endstops
M574 Z1 S1 ; Set active high endstops; Z-Probe
M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
M557 X15:285 Y15:245 S20 ; Define mesh grid; Heaters
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 130C
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
with radds, the printer prints ok with 120mm/s
Now i got this:
The headtower is so lala print from 260-215° Flow 100 EM/EW 40
But the 20mm cube........i don`t know the problem.
![0_1552139493910_IMG_0350.jpg](Uploading 100%)
Sorry for my bad english, i am from germany.
Note the printer is still in process, becaus i can`t print the parts for paneldue, dor, sidecover .....
@eckbert0815 The problems look to be temperature related and I can't see any M307 commands in your config.g so I suggest you tune the heater PID settings https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
Also your steps per mm for the extruders don't match what you've said about the motors. For an E3D Titan with 1.8 degree motors the steps per mm are in the order of about 420 so for a 0.9 degree motor, they should be about 840. In your config.g you have E918.03:837.00. So I suggest you set the steps per mm roughly, then calibrate both extruders.
I'm guessing that by "headtower" you mean a temperature tower. If the pictures show the result of printing ABS in a range from 260 to 215 then the upper delamination of the layers is exactly as one would expect if that was printed as low as 215.
@deckingman The M307 ist in the config-override.g
; Heater model parameters
M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
M307 H1 A1249.4 C240.8 D5.3 S1.00 V27.2 B0
M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00I have changes to the extruder with the 0.9 stepper becaus the big gear from the other titan ist not the best, changed at the board too and calibrate it. But not the second one. I wil calibrate the exturder later.
New steps and jerk....
M92 X80.40 Y80.40 Z800.00 E879.00:420.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E1200.00:1200.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X10000.00 Y10000.00 Z500.00 E3600.00:3600.00 ; Set maximum speeds (mm/min)
M906 X1900.00 Y1900.00 Z1900.00 E1400.00:1900.00 I30 ; Set motor currents (mA) and motor idle factor in per centNow i try a print with less temperature 240° nozzle and bed 85°, retract 5.5mm.
It sems to be better.
@deckingman The M307 ist in the config-override.g...........................
In that case, you need to add M501 to the end of your config.g file in order to read in those values. https://duet3d.dozuki.com/Wiki/Gcode#Section_M501_Read_stored_parameters
Without the M501, the values stored in config-override. won't get read. Alternatively, you can copy or cut and paste those M307 lines into your config.g file.
