    Repetitive layer defects
    3.9k
    • DocTruckerundefined
      DocTrucker @Denis
      @denis There is, but that is not the only problem there is also a z-wobble like issue. Short of pictures with scales the wobble looks a very similar wavelength to what you have pictured.
      Denisundefined 1 Reply Last reply Reply Quote 0
      • Denisundefined
        Denis @DocTrucker
        @doctrucker I would like to hear some reasonable thoughts, instead of an answer, that this is a problem of such printers. You can write shit happens, it will be just as useful
        Edgars Batnaundefined DocTruckerundefined 2 Replies Last reply Reply Quote 0
        • Edgars Batnaundefined
          Edgars Batna @Denis
          @denis Have you tried setting extrusion width to 75% of nozzle width? I've got a completely different printer, but I'm investigating a very similar issue. The image is sort-of potato-vision...
          Denisundefined 2 Replies Last reply Reply Quote 0
            DocTrucker @Denis
            @denis said in Repetitive layer defects:
            Your response makes little sense, and I've no time to waste freely with tone like that. I wish you luck fixing your problem. Good bye.
            • Denisundefined
              Denis @Edgars Batna
              @edgars-batna Yes, and I see a change. Now I will try the leading pulleys made of polyurethane (Perhaps Chinese iron curves in places. suddenly help?)) and then publish a photo with reduced extrusion. Down to 85 percent. There is something to think about. In addition, in the spiral mode in one layer, the wall is ideal.
              • Denisundefined
                Denis @Edgars Batna
                @edgars-batna It was a good idea. I see the problem in extrusion. Strange, because I calibrated it. It seemed to me that the calibration procedure should not be questioned. However, all I can say is that the problem exists, and I can only reduce the extrusion in order to get a quality print. This may be the uncoordinated steps of the engines of extruders and axial engines, but let the developers explore this. It is a pity that I changed the printer to the delta after buying a duet and lost several months of time)) I thought I was struggling with the wobble, but it turned out that it wasn’t. 0_1552180839782_photo_2019-03-10_04-04-56.jpg
                Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
                  Edgars Batna @Denis
                  @denis It is practically the same what I observe on my printer, even though it is a completely different build.
                  Though, what I meant is not the overall extrusion multiplier, but rather extrusion width in slicer settings. So, for 0.4 nozzle set it to 0.3 for perimeters.
                  The amount of material will still be as you calibrated it, but the perimeters will be significantly finer. It reduced most of the ripples for me.
                  • Denisundefined
                    Denis @Edgars Batna
                    @edgars-batna Now I use a 0.3 nozzle, but the general idea is clear to me. This is really strange, because these defects began after I changed the marlin to a duet for HBot and were aggravated during the transition to the delta. After the adjustment, I get excellent prints, so I don’t scold the duo in any way, but I urge the developers to check the algorithms again.
                      Edgars Batna @Denis
                      @denis Yes, I had exactly the same thoughts and couldn't figure it out either. One observation that I've made is that there have been threads with printers that use linear axes that encounter similar Z ripples, so one would think it's not mechanical, but wait...
                      My current theory is that the E3D-type nozzles with a flat area around the nozzle hole is what's causing it. There's a snowball effect where the nozzle rides on top of the previously extruded perimeter, thus it is pushed upwards slightly. Just 25% of layer height and there you go - it will start snowballing and oscillating, since at high enough pressure the filament will get pushed down and then it starts over. Basically, as soon the nozzle can be pushed upwards by a fraction of layer height, the problem starts. We're already in fractions of a millmeter; these tolerances are hard to achieve at home.
                      Well, this is a theory. To prove it one would need to take a nozzle and sand it down like this:
                      But I haven't tried it yet. Sounds EZ... but, it might destroy lines where extrusion is larger than the nozzle...
                      • Denisundefined
                        Denis @Edgars Batna
                        @edgars-batna Well, I am glad that this situation can be influenced and we know how.
                        • Denisundefined
                          Denis
                          Unfortunately, the reduction in extrusion only masks the problem, but does not solve it. Lines are still visible. It seems to me on different sizes they appear with a different period. What else can you pay attention to? Any advice.
                            Edgars Batna @Denis
                            @denis Astounding, but indeed, you get the same behavior as on my completely different printer (Hevo CoreXY)... I suppose the common denominator is some aspect of the hotend. How much play can you observe on the nozzle when it's cold by hand? Just try it by hand; it should be reasonably stiff for pulling or pushing the filament, plus pressure inside the Bowden tube, if any.
                            My hands are itching to try my nozzle-destroying theory, but I don't want to disassemble the hotend yet again and I don't have a 0.4 Volcano nozzle to play with just yet.
                            Also, what slicer do you use? I use Slic3r PE.
                            So far I observed that cooling affects this. Less cooling means the top layer is soft enough to not lift the nozzle. Can you try printing same piece with significantly less cooling and significantly higher speed?
                            • Denisundefined
                              Denis @Edgars Batna
                              @edgars-batna This is ABS and it was printed without cooling. I can include about 10 percent, but this will not affect the review picture. Waiting for PT100 and fisheye for further experiments. I used Simplify3D and Сura, hotend fixed well
                                Edgars Batna @Denis
                                @denis Another aspect that I noticed is that Slic3r PE does not produce all layers in the same direction and that the segments may not line up. It alternates between clockwise and counter-clockwise and does not line up corners of approximated curved perimeters between layers, which means the hotend will lag differently behind the target position. Can you check if all layers are printed in the same direction, in case it also affects other slicers?
                                  Have we already established that you are not using bang-bang control for the bed heater? Send M307 H0 to check. This is known to cause that type of problem. Note, if you haven't tuned the bed heater yet then it runs in bang-bang mode.
                                    Phaedrux Moderator @Denis
                                    1_1551779528546_config.g 0_1551779528545_config-override.g
                                    ; config-override.g file generated in response to M500 at 2019-03-03 15:19
                                    ; Delta parameters
                                    M665 L397.107 R157.000 H523.288 B175.0 X0.000 Y0.000 Z0.000
                                    M666 X0.653 Y-0.205 Z-0.447 A0.00 B0.00
                                    ; Heater model parameters
                                    M307 H0 A162.7 C784.3 D2.7 S1.00 V23.9 B0
                                    M307 H1 A1059.6 C247.6 D5.9 S1.00 V23.6 B0
                                    It appears to have been tuned.
                                      Edgars Batna
                                      I'm using bang-bang below an 8mm Aluminum plate and the symptoms are nearly identical. Using PID with a 1200W 220V heater would probably melt something somewhere. The heat appears to take a good while until it propagates to the top anyway as it's a grade of aluminum with just average thermal conductivity. Plus, the symptoms are sure to appear without heat bed turned on.
                                        @edgars-batna said in Repetitive layer defects:
                                        If controlled by SSR, what would melt?
                                          Edgars Batna @Phaedrux
                                          @phaedrux Well, if you take any SSR with a spec sheet, you'll see it's rated for a limited amount of on-off switches per hour or something like that. At least that's what I could find at the time. If you have an SSR with a spec sheet with unlimited switching capability for this amount of power, kindly let me know. I've seen people complaining about their cheap Chinese relays melting "unexpectedly" at some point when they're not at home and it's no wonder. Some try to control the heating system at their homes.
                                            deckingman @Edgars Batna
                                            @edgars-batna Try this http://www.crydom.com/en/products/catalog/ha-series-ha48-ac-panel-mount.pdf.
