Repetitive layer defects
3.8k
    Denis
    How can I go back to the factory default firmware, is there such a function? This is the most confusing instructions for installing the firmware, which I have seen in my life. I do not want to update, I want to erase everything and reinstall it. What should I do?
      DocTrucker
      You often have to wait more than overnight (on a Monday too) for the right person to come on the forum and read the messages. By all means poke the message but comments like 'it's sad' will just wind people up.
      Part on the right looks over stuffed. Tried reducing extrusion multiplier?
      Strip everything off the carridges and make sure they move smoothly with no significant play.
      I'm not a delta person. On my machines that'd be referred to a z wobble.
        DocTrucker
        What duet are you running?
        Upgrade to the latest 2+ firmware version. If your issue was firmware based that would have been picked up on by now, particually as the lead developer's main machine is a delta.
        undefined 1 Reply Last reply 5 Mar 2019, 09:03 Reply Quote 0
          Denis @DocTrucker
          @doctrucker On right? I would say that there are problems with extrusion on the left, but the whole point is that the difference in prints is only in the motors) And I use the Wifi duet, with the latest firmware 2.02. I regret that I may annoy with my regrets, but I have been at war with the duet and printer for several weeks now.
          undefined 1 Reply Last reply 5 Mar 2019, 09:55 Reply Quote 0
            deckingman @Denis
            @denis
            Read this https://forum.duet3d.com/topic/5909/guide-for-posting-requests-for-help
            undefined 1 Reply Last reply 5 Mar 2019, 10:03 Reply Quote 0
              DocTrucker @Denis
              @denis You mentioned 1.19, that's why I encouraged the use of the latest firmware.
              I can only see the upper surface of the part on the right, that's what made me think that one was over extruded, and perhaps burnt on the top surface.
              I don't think you are struggling with the Duet, it appears more general issues.
              Swapping from 1.8 to 0.9 degree steppers appears to have reduced the severity of the problem. I think something is loose, or too flexible. The 1.8 steppers are likely to vibrate more strongly than the 0.9 and excite potential resonances in the frame or components.
              Thoroughly check your mechanics, check belts, check the joints at the end of the effector rods, check temperature, check e-steps, check extrusion multiplier.
              undefined 1 Reply Last reply 5 Mar 2019, 10:20 Reply Quote 0
                Denis @deckingman
                @deckingman At the moment I rolled back to this configuration
                Firmware Name: RepRapFirmware for Duet 2 WiFi / Ethernet
                Firmware Version: 2.0 (RTOS) (2018-06-05b3)
                WiFi Server Version: 1.21
                Web Interface Version: 1.22.61_1551779528546_config.g 0_1551779528545_config-override.g
                The model file is made in Cura, 3.6 using relative extrusion.
                Motors on axes 42BYGHM810 0.9 degrees, 2.4A, phase resistance 2.1, inductance 4.2
                extruder motor 0.9, 1.33A, phase resistance 0.8, inductance 1,8
                undefined 1 Reply Last reply 16 Mar 2019, 18:45 Reply Quote 0
                  Denis @DocTrucker
                  @doctrucker The resonances should depend on the speed, but the speed has no effect on the bands. As for the mechanics, everything is rechecked many times
                    DocTrucker
                    Second hit on a google search indicates this problem can exist on Tevo Little Monsters running OEM boards.
                    https://www.google.com/search?client=ubuntu&channel=fs&q=Tevo+LM+wobble&ie=utf-8&oe=utf-8
                    undefined 1 Reply Last reply 5 Mar 2019, 11:00 Reply Quote 0
                      Denis @DocTrucker
                      @doctrucker I opened this link. There is a problem with delamination abs. This is not my case.
                      undefined 1 Reply Last reply 5 Mar 2019, 11:32 Reply Quote 0
                        DocTrucker @Denis
                        @denis There is, but that is not the only problem there is also a z-wobble like issue. Short of pictures with scales the wobble looks a very similar wavelength to what you have pictured.
                        undefined 1 Reply Last reply 9 Mar 2019, 16:09 Reply Quote 0
                          Denis @DocTrucker
                          @doctrucker I would like to hear some reasonable thoughts, instead of an answer, that this is a problem of such printers. You can write shit happens, it will be just as useful
                          undefined undefined 2 Replies Last reply 9 Mar 2019, 16:22 Reply Quote 0
                            Edgars Batna @Denis
                            @denis Have you tried setting extrusion width to 75% of nozzle width? I've got a completely different printer, but I'm investigating a very similar issue. The image is sort-of potato-vision...
                            undefined 2 Replies Last reply 9 Mar 2019, 18:06 Reply Quote 0
                              DocTrucker @Denis
                              @denis said in Repetitive layer defects:
                              Your response makes little sense, and I've no time to waste freely with tone like that. I wish you luck fixing your problem. Good bye.
                                Denis @Edgars Batna
                                @edgars-batna Yes, and I see a change. Now I will try the leading pulleys made of polyurethane (Perhaps Chinese iron curves in places. suddenly help?)) and then publish a photo with reduced extrusion. Down to 85 percent. There is something to think about. In addition, in the spiral mode in one layer, the wall is ideal.
                                  Denis @Edgars Batna
                                  @edgars-batna It was a good idea. I see the problem in extrusion. Strange, because I calibrated it. It seemed to me that the calibration procedure should not be questioned. However, all I can say is that the problem exists, and I can only reduce the extrusion in order to get a quality print. This may be the uncoordinated steps of the engines of extruders and axial engines, but let the developers explore this. It is a pity that I changed the printer to the delta after buying a duet and lost several months of time)) I thought I was struggling with the wobble, but it turned out that it wasn’t. 0_1552180839782_photo_2019-03-10_04-04-56.jpg
                                  undefined 1 Reply Last reply 10 Mar 2019, 09:58 Reply Quote 0
                                    Edgars Batna @Denis
                                    @denis It is practically the same what I observe on my printer, even though it is a completely different build.
                                    Though, what I meant is not the overall extrusion multiplier, but rather extrusion width in slicer settings. So, for 0.4 nozzle set it to 0.3 for perimeters.
                                    The amount of material will still be as you calibrated it, but the perimeters will be significantly finer. It reduced most of the ripples for me.
                                    undefined 1 Reply Last reply 10 Mar 2019, 10:11 Reply Quote 0
                                      Denis @Edgars Batna
                                      @edgars-batna Now I use a 0.3 nozzle, but the general idea is clear to me. This is really strange, because these defects began after I changed the marlin to a duet for HBot and were aggravated during the transition to the delta. After the adjustment, I get excellent prints, so I don’t scold the duo in any way, but I urge the developers to check the algorithms again.
                                      undefined 1 Reply Last reply 10 Mar 2019, 10:28 Reply Quote 0
                                        Edgars Batna @Denis
                                        @denis Yes, I had exactly the same thoughts and couldn't figure it out either. One observation that I've made is that there have been threads with printers that use linear axes that encounter similar Z ripples, so one would think it's not mechanical, but wait...
                                        My current theory is that the E3D-type nozzles with a flat area around the nozzle hole is what's causing it. There's a snowball effect where the nozzle rides on top of the previously extruded perimeter, thus it is pushed upwards slightly. Just 25% of layer height and there you go - it will start snowballing and oscillating, since at high enough pressure the filament will get pushed down and then it starts over. Basically, as soon the nozzle can be pushed upwards by a fraction of layer height, the problem starts. We're already in fractions of a millmeter; these tolerances are hard to achieve at home.
                                        Well, this is a theory. To prove it one would need to take a nozzle and sand it down like this:
                                        But I haven't tried it yet. Sounds EZ... but, it might destroy lines where extrusion is larger than the nozzle...
                                        undefined 1 Reply Last reply 10 Mar 2019, 10:58 Reply Quote 0
                                          Denis @Edgars Batna
                                          @edgars-batna Well, I am glad that this situation can be influenced and we know how.
                                          12 out of 44
