    Bed compensation test?
    1.5k
    • thweundefined
      thwe @Phaedrux
      @phaedrux said in Bed compensation test?:
      it can be as high or as low as you need it to be. If it is set too low you'll end up probing the max of the A value every time. In my case, usually it probes twice, but occasionally it will probe 3 or 4 times. So for my BLTouch 0.003 seems to be alright. For me, 0.03 was too forgiving since my probe results could vary each time
      ah, thanks for the tip. at the moment I have S0.01, I will play with smaller values 👍
      Thomas
        Phaedrux Moderator @thwe
        @thwe I assume that it maxes out at three significant digits as that's the resolution reported by the G30 S-1, but I'm not certain.
        • FelixHundefined
          FelixH
          Holly Molly @Phaedrux thanks a lot for your comprehensible answer and the time you took...
          Both nozzle and bed were at working temperature when measuring the Z-trigger height, but the sensor can have obviously systematic errors nonetheless. I will try to adjust those parameters.
          I was aware that the probes are not 100% precise ore repeatable, but I thought 0.5 mm of error with babystepping was way too much, isn't it?
          I'll report back asap...
            @FelixH, how do you home Z? If you are homing Z using the IR sensor, where on the bed do you do that? The centre of the bed is usually best. It's a good idea to use a point that is also one of the points on the mesh used for bed compensation.
            • FelixHundefined
              FelixH
              @dc42 I modified the corresponding .h file (I don´t remember which one it is) so that the Z homing takes place on the center of the bed.
              Yesterday I was able to print a Benchy again. But after following all the indications, I still had to put the nozzle down with babystepping by 0.300 mm
                dc42 administrators @FelixH
                @felixh said in Bed compensation test?:
                If you home Z and then send G1 X0 Y0 Z0 with no babystepping active, does it put the nozzle right on the bed surface?
                FelixHundefined 1 Reply Last reply Reply Quote 0
                • Hornetriderundefined
                  Hornetrider
                  @FelixH
                  HI
                  please check your system folder if a "resurrect" file is there. Delete and try again to print...
                  Cheers
                  • FelixHundefined
                    FelixH @dc42
                    @dc42 said in Bed compensation test?:
                    G1 X0 Y0 Z0
                    If I do a homing on X150 Y150, followed by a G1 Z0, the nozzle lands at a height of 0.15mm. When I send a G1 X0 Y0 Z0, it lands at 0.30mm from the bed. I´m using feeler gauges (I think they are called that).
                    @Hornetrider there is no "resurrect" folder...
                      That indicates that your G31 Z parameter is not right. It should land at 0mm.
                      Did you definitely load a height map before that, either by running G29 S0 to probe again, or G29 S1 to load the existing height map?
                      You mentioned Z motors (plural). Are you taking steps to correct them if they get out of sync?
                      FelixHundefined 2 Replies Last reply Reply Quote 0
                      • FelixHundefined
                        FelixH @dc42
                        I did not load the map before doing the test. I will try again.
                        I check both sides of the x axis to check they are at the same height. Perfection is difficult, but they are in the range of 0.05mm max
                        • FelixHundefined
                          FelixH @dc42
                          @dc42 Loading the bed map, homing Z and going to Z0 leaves the nozzle touching the surface. On X0 Y0 Z0 leaves the nozzle 0.20mm above the surface
                            Three possibilities:
                            1. Height map is not being used because loading it failed. Run m122 and look for "Bed compensation in use:".
                            2. Height map is wrong because something has moved. Try running bed probing again, then do the same test.
                            3. Height map is inaccurate because the IR sensor doesn't work well with your bed surface. Try measuring the sensor trigger height at various points and see how consistent it is.
                            • FelixHundefined
                              FelixH
                              will do, and report back
                              Thanks
                              • FelixHundefined
                                FelixH
                                So, I measured the trigger height in 5 different points:
                                Center: 1.540
                                X35 Y25 : 1.523
                                X290 Y25 : 1.565
                                X290 Y290 : 1.543
                                X35 Y290 : 1.528
                                My bed surface is GKF, glass fiber or garolite I think it's known by
                                  Garolite is quite shiny and reflective. Perhaps the IR probe isn't performing well with it. Try covering the bed surface with a piece of plain paper to eliminate the shininess and see how the probe results compare.
                                  • FelixHundefined
                                    FelixH @Phaedrux
                                    @phaedrux I have a Easy Peelzy for the Tornado, I will try that. The surface is BuildTak-like and should be ok, I guess
