    Fillament-thickness sensor
    Hardware wishlist
    8
    15
    2.0k
    • fmaundefined
      fma
      You need to measure in 2 orthogonal directions, as the filament may have the correct section, but not being a circle... In this case, measuring in one direction only will give you a wrong indication.
      Frรฉdรฉric
        It's been done before, using linear CCD sensing elements. As @fma says, you need to measure the diameter in at least 2 directions.
        However, good quality filament has fairly closely controlled diameter these days, so I'm not convinced that monitoring filament diameter is worthwhile. For example, rigidink's 1.75mm PLA is controlled ot +/-0.03mm, which equates to +/-1.7% in diameter or about +/-3.4% in area. Prusament is +/-0.02mm diameter, so even less. Ian (@deckingman) did some tests that indicated that even quite large changes in extrusion rate didn't have much effect on the print.
          deckingman @dc42
          @dc42 said in Fillament-thickness sensor:
          Actually Michael Hackney did it much more scientifically and more in depth that I did - http://www.sublimelayers.com/2017/12/musing-on-under-extrusion-prepare-to.html
          Definitely worth a read but if you are short of time I hope Michael won't mind if I post this extract - quote:
          "The bottom line is, FFF 3D printing is surprisingly robust to non-trivial under-extrusion in the range up to 10% under-extruded, and possibly higher depending on your requirements."
          IMO, over extrusion is very noticeable but I agree with Michael regarding under extrusion. So much so that I simply run 95% extrusion multiplier as my default setting and very rarely change it.
          • klcjr89undefined
            klcjr89
            I am working on a sensor that measures in more than 2 axes and should eliminate all under and over extrusion issues for good. It even has the benefit of allowing a user to use random diameter filament without having to worry about issues.
            Even good quality filament is far from consistent. It may be '1.75mm', but has an egg shaped cross section or non consistent cross section across the length of the spool.
            This also doubles as a filament run out sensor. ๐Ÿ™‚
            • thweundefined
              thwe
              Manufacturers of extrusion products (including filamtent) use for example sensors from sikora, which operate on the principle as shown in the following image
              The product creates a shadow on the CCD line sensor. In this case, the number of dark pixels on the line sensor is equivalent to the diameter.
              Decisive for the measuring accuracy is the ccd sensor
              Thomas
              • klcjr89undefined
                klcjr89
                All of the parts have arrived for the sensor. If I can get everything designed and assembled, it will be a game changer! ๐Ÿ™‚
                devleonundefined nikschaundefined 2 Replies Last reply Reply Quote 0
                • devleonundefined
                  devleon @klcjr89
                  @klcjr89 care to share some more details about how you're going to build it and what parts?
                  klcjr89undefined 1 Reply Last reply Reply Quote 0
                  • klcjr89undefined
                    klcjr89 @devleon
                    @devleon The parts were very expensive, which always seems to be the case with any prototype project I undertake haha.
                    The heart of it is a transducer, or known as LVDT in the industry. ๐Ÿ™‚
                    devleonundefined 1 Reply Last reply Reply Quote 0
                    • nikschaundefined
                      nikscha @klcjr89
                      @klcjr89 sweet! Keep us updated!
                      Stay in school
                      • devleonundefined
                        devleon @klcjr89
                        @klcjr89 Holy ***, LVDTs are expensive, you weren't kidding. Definitely nothing for me if the sensor costs more than my 3D printer.
                        • klcjr89undefined
                          klcjr89 @devleon
                          @devleon I got it new old stock, so wasn't too bad ๐Ÿ™‚ If the idea works, the manufacturer has volume price discounts!
                          • DocTruckerundefined
                            DocTrucker
                            Work with one and rotate the assembly around the filament using a spare stepper drive, or perhaps target that as stage 2 of the testing. Read up on the laser filament monitor tests and get some of the filaments that caused large variations or problems with them.
                            How are you planning to verify your system? I've found the experimental noise on the weight of small test parts to be significant.
                            Solving under and over extrusion issues is a great aim but filament diameter is one part of the puzzle which other projects are also working on such as the magnetic filament monitors towted potential capability to automatically calibrate non linear extrusion.
                            I'm tackling calibration process issues myself this week and have decided to test setting my extrusion multiplier to 1 then adjusting the filament diameter to correct wall size, adjust extrusion multiplier over a sequence of solid 20*20mm test coupons, and finally tackle offset and scaling issues. This is before taking pressure advance, retraction settings, and extrusion correction in any detail.
                            Setting the temperature has been far too vague for my liking so far and mucks up other calibrations when I've had to change it later on.
                            Edit: I'll know I've got things nailed when a causal observer can't accurately tell what machine a test part has come from. I feel a coke/pepsi style test with some dissinteredted family members coming up!
