    z-homing failed with mini IR
    IR Height Sensor
    1.2k
      Phaedrux Moderator @gueee78
      @gueee78 said in z-homing failed with mini IR:
      @Phaedrux it does match cause I've got dual independent z-axis, so I could level the x-gantry.
      In that case you could use a G32 in the homez to call bed.g to level the bed, and then use a single G30 in the center as shown above to set the z height.
      G32 ; call bed.g to level the bed
      G90 ; absolute positioning
      G1 X150 Y150 ; move to bed center
      G30 ; probe z height
      BlueDustundefined 1 Reply Last reply Reply Quote 0
        Phaedrux Moderator @BlueDust
        @bluedust said in z-homing failed with mini IR:
        I wanted to do something like this, I just don't know if I can, or if there is more to it.
        M574 X1 Y1 Z1 S1 ; Set active high endstops
        M5+58 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X0 Y-42 Z1.45 ; Set Z probe trigger value
        M557 X100:200 Y100:200 S100:100 ; Define mesh grid
        Yes that could work. your homing files would specify how the Z axis is homed. To use a probe, you use G30, to use the endstop switch, you would use a G1 S1 Z move to trigger the endstop. And with your probe defined in the config.g things like G29 that use the probe would still work as normal.
        But if I can make my IR Z Probe Home to the center of the bed, and not off the bed, that would be perfect.
        I am not sure how to use G1, or G30 as they are not currently in my config. I will have to look into them.
        This would probably be best and would be easy to do. The snippet I posted above would go into your homing file. If you post your entire homing files I can show exactly what needs to be modified.
        Also note, I have a CoreXY, not a Cartesian. Not sure if that changes things.
        Homing Z would be the same between cartesian and corexy.
        • BlueDustundefined
          BlueDust @Phaedrux
          @phaedrux
          I poked around the config files.
          I think I figured it out and updated the homeall and homez files
          Will play after this print completes
          Thanks!
          Fun, that 3 letter word with "u" in the middle.
          • BlueDustundefined
            BlueDust @Phaedrux
            @phaedrux
            Good stuff!
            Z works in the center of the bed now!
            Thanks!
            • gueee78undefined
              gueee78
              I still couldn't find a solution for that problem.
              I even updated my firmware and redid the whole configuration, but it still doesn't do the bed leveling with two z-motors.
              I do an initial homing of all axis wich works fine, when I start Auto Bed Compensation it probes the two points but then it throws the error message: Probe points P0 to P1 must be in clockwise order starting near minimum X and Y
              has anyone got a similar configuration working and could give me some advice?
                Does the order of your probe points match the order the motors are defined in config.g?
                • gueee78undefined
                  gueee78
                  yes it does and the error message occours even if I switch the probe points
                    Are you running a very old firmware version that doesn't support bed levelling using independently driven leadscrews? Send M115 to check the firmware version.
                    • gueee78undefined
                      gueee78
                      no, I'm running latest stable release 2.02
                        Error: Probe points P0 to P1 must be in clockwise order starting near minimum X and Y
                        That message means that the firmware thinks you want to do old-style bed compensation. It should only do that if the number of leadscrew coordinates you defined in M671 doesn't match the number of Z motors defined in M584. So try running M584 without parameters, and M671 without parameters, and report the results.
