    Master- Slave Approach in DUET-2
    1.6k
    • elmoretundefined
      elmoret @GeorgeP
      @georgep https://www.duet3d.com/duet3
      • GeorgePundefined
        GeorgeP
        how many extension boards can be connected ti the Duet3??? in a video is saw 2 extension boards. Is it possible to cascade as many as we want???
          dc42 administrators @GeorgeP
          @georgep said in Master- Slave Approach in DUET-2:
          We've designed it to allow a lot of expansion boards to be cascaded. I'm aiming to have it working with at least 8.
          GeorgePundefined 1 Reply Last reply Reply Quote 0
          • GeorgePundefined
            GeorgeP @dc42
            @dc42 said in Master- Slave Approach in DUET-2:
            wow... That sounds really cool... looking forward to that... When can we see it in the stores??
            • GeorgePundefined
              GeorgeP
              The Duet3 with the expansion board works on a similar master slave approach right??!! where the Duet3 is the master and the expansions are the slaves.
              What IC does the expansion board run on?
                The expansion board has an ATSAME51 processor, which has a 120MHz ARM Cortex M4F core.
                • GeorgePundefined
                  GeorgeP @dc42
                  @dc42 Do you think the duet2 can be tweaked to fit in a master slave using SPI/ UART with another board??
                    The technical difficulties would be substantial, also I suspect that the master would need more RAM than the processor on the Duet has, unless we removed some major feature to free up RAM.
                    You can already drive 12 stepper motors independently using a Duet + DueX5 + 2 external drivers. Another user already did a firmware patch to support another 2 external drivers, giving 14 in total.
                    • GeorgePundefined
                      GeorgeP @dc42
                      WoW... 2 more external drivers! where do we connect the 2 external drivers? if the Duet2 is connected to the duex5. Where are the additional pins for more drivers? Do we connect it in the display pins?
                        See the references to CONN_LCD at https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers.
                        • GeorgePundefined
                          GeorgeP
                          Really cool.
                          12 stepper drivers sounds good to me.👍
                          It is a good start.
                          Cant wait to start my project. Will come back with more queries as I progress.
                          Thank You☺
                          • GeorgePundefined
                            GeorgeP
                            Eager to see the Duet 3 in action too. Is there any way to get my hands on a prototype?
                            • GeorgePundefined
                              GeorgeP
                              I would love to contribute in some way too.
                                Prototypes are very expensive to make because the PCB production and especially the assembly costs are very high for small numbers of boards. So we have only a few Duet 3 prototypes. We've not yet decided whether we will make pre-production boards as we did for Duet WiFi, or go straight to production.
                                • GeorgePundefined
                                  GeorgeP
                                  Well i am sure it will be worth the wait... 8 Expansion boards is like a dream come true. You guys have taken expansion to a whole new level .👍
