Duet 2 Wifi + BL-Touch doens´t work, no Trigger-Signal
4.1k
    Phaedrux Moderator @JustD
    @justd said in Duet 2 Wifi + BL-Touch doens´t work, no Trigger-Signal:
    Whats the best Way to calibrate the BLTouch mechanic?
    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
    https://duet3d.dozuki.com/Wiki/Using_mesh_bed_compensation
      JustD
      Now it´s working.. .. Now I tune some S3D parameters for different filaments.
      Does anyone know the scripts for toolchange at printing time?
      For print with 2 different Materials or different colors at one Object. I know, should be two objects in one printingfile a combined object.
      What I´m searching for is, the scripts for Simplify 3 D.
      Ok, it´s a little offtopic here
      Own Tronxy X5S modified to 360x360x430, 7 linear-rails (4 Z; 2 Y; 1 X-Axis), 3 independent Z-Axis with 3 Steppers; BL-Touch..
      Duet 2 Wifi 1.04 + DUEX5, 3input-nozzle with 3 extruders, 6mm Glas Plate and 600W silicon-headbed with own powersupply.
      undefined 1 Reply Last reply 29 Mar 2019, 11:08 Reply Quote 0
        dc42 administrators @JustD
        You can do the tool changing either in the Duet's own tool change files (see https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Tool_change_files) or in S3D. if you put the commands ni the Duet tool change files, then all S3D needs to generate is a T command to change tool.
          JustD
          Thank you, thats wil help a lot..
          But for today I see.. it´s not soo easy to change tool during printing a object.
          I try it yesterday maually.. only via WEB-interface.. retract, load.. etc.. and.. I see, I must find out, how much I need to retract for a good and working toll-change.
            JustD
            Whow.. These 3-Way-1Nozzle Header.. needs really 55mm for complete retract.
            Puuh.. during a print for my feeling too much.
            I see at a manual retract and load a new filament via E2 with a ABS with lower quality.. it could be a problem to change.
            After I retract te cheap ABS, I can´t load the white, better ABS.. grr..
            So I order a Diamond-Nozzle with 3 E3D and only 15mm retract.
            I will see what happens next month.
            What i think about:
            How is it possible, only with the stock Duet 2 Wifi, to use 3 extruders??
            Is that possible or do I need a expasion-Board? (it´s heavy expensive)
              The expert on the Diamond hot end is @deckingman on this forum. See his blog at https://somei3deas.wordpress.com/tag/diamond-hot-end/.
              It's easiest to drive if you add a DueX2 or DueX5 to your system, although that's not the only way.
                JustD
                Another Question: What are the right setuo in simplify3D for the Duet 2 WiFi??
                Here my setup, but I´m not shure if it is right.
                What I mean is the Setup in the Process-Setupp FFF the section G-Code at the left side:
                x 5D-Firmware
                • relative extrusion
                  x the G92 E0 parametre
                • autonomous Extruder Axis
                • extensive M101/M102/M103
                  x Firmware support sticky parametre
                • use Tool-offset in G-code
                Sorry I try to transplate from German.
                undefined 1 Reply Last reply 2 Apr 2019, 09:19 Reply Quote 0
                  JustD
                  @DC42.. Thanks for that hint
                    JustD
                    Why is it impossible in the WEB-Interface to set the Temp of tool 1 (Heater) above 270°C?
                    In my printfile there is the command:
                    M104 S280 T0
                    M109 S280 T0
                    At the Config.g the maximum Temp:
                    M143 H1 S285 ; Set temperature limit for heater 1 to 285C
                    Is there any configuration what I´m forgotten?
                    undefined 1 Reply Last reply 2 Apr 2019, 13:39 Reply Quote 0
                      JustD
                      What strange is... with the selector I can maximum select 270.. or. better I´m able to select my own List entities of 280, but if I go to another field, there is automaticly 270 in the field what I select to 280.
                      But If I put in manually, then it´s possible to set it to 275 as maximum.. and the heater is heating up to 275°C.
                      But manually 280 switch back to 275°C.
                      Why is that maximum fix programmed at the web-interface instead of using the config.g and the List-selctions??
                        I don't think the DWC drop down list of selectable heats is "aware" of what's set in config.g. As you discovered, you can edit the list to include whatever values you want.
                        What version of DWC are you using?
                          x 5D-Firmware
                          Correct.
                          Not needed when using relative extrusion.
                          I don't know what this one means. I don't have it checked..
                          RRF can use those commands to do firmware retraction, because S3D doesn't support the standard G10/G11 method. But the M101/102/103 commands are not all generated at exactly the right times. So it's better to turn this off.
                          Yes.
                          I have that turned off because RRF manages tool head offsets itself.
                          Kein problem!
                            Stephen6309 @JustD
                            @justd If you're using a M143 in config.g, make sure it's high enough.
                              JustD
                              Thank you for the Answers:
                              @Phaedrux I´m using the DWC Version 1.22.6 WiFi 1.22 FW 2.02
                              But I have values in the drop down List from 190 up to 285°C
                              @dc42.. thanks help al lot.
                              @Stephen6309 here my M143: M143 H1 S280 ; Set temperature limit for heater 1 to 280C
                              Sorry, I can´t insert a pic.. only a Link to a pic.. or.. How does it here work?
                                JustD
                                  M143 H1 S280
                                  You may need to set M143 slightly higher than your target temp to allow for some overshoot.
                                    JustD
                                    @Phaedrux, by the way --- the Problem with the BLTouch is solved.
                                    My clone-BLTouch was defect.. now with the origin it works very fine.
                                    OK.. You mean.. maybe 300°c where better?
                                      JustD
                                      What I have seen.. tested/messured...
                                      My heatingblock, with the heating-patrone.. reach the abvised temperature... set 200° = 200° messured at the block.. but at the Nozzele at self.. there is only 166°c
                                      Is that normal.. this big difference?
                                        JustD
                                        I have change my Heatingblock and the Nozzle.. and its much better.
                                        I set 200°C and my Nozzle reach 194°C.. Thats Ok for me.
                                        I Work around som smal issues.. retract and so on.. its much, much better than ever before..
                                        Headbed.. I think I can sodl the silicon heater.. the objects hold very good with extrem low temp.. 30-40°.. ABS/PLA..
                                        Above 60°C I can´t use it.. the grip is to extrem.. . need 30min. to loosen the object.. lol
                                        I print with 60mm/sec.. for now it´s OK
                                        But the bedleveling is one Issue what I have open.
                                        I try with the WBC the Compensation.. but it seems very confused...and very extremly in reaktion of changing everything with bedleveling.
                                        What ist he difference between
                                        • Meshcompensation and
                                        • Bedcompensation ??
                                          At my Bedcompensation.. I Can´t define the Messurement-Area of testing.
                                          The Definition of Meshcompensation don´t work on it.
                                          The Bed dimensions are not the right ting.. in oder I start the bedcompensation, the wagon moves to the zero Point and the next messurement try to move out of the 0-X coordinate in Minus.??
                                          And the point before the last point in the middle... is outside my bed definition in +x.. above 350??
                                        Whats wrong at my printer or my definition?
                                        Is it possible to define the bed compensation in the config?
                                          JustD
                                          What does it mean with this Warning??
                                          "G32
                                          Warning: 3/4/5-point bed compensation is deprecated and will be removed in a future firmware release. Please use G29 mesh bed compensation instead.
                                          Bed equation fits points [10.0, 15.0, -0.136] [10.0, 325.0, -0.351] [335.0, 325.0, -0.666] [335.0, 15.0, 0.079] [175.0, 175.0, -0.528]"
                                          30 out of 43
