    Horrible print results.Help needed?
    40
    4.0k
    • sibluesundefined
      siblues
      I am having some pretty bad print results which aren't being caused by my Duet but more than likely my limited experience and understanding of 3D printing.I have tried with a few different colored filaments and different brands and materials and I have also adjusted tons of things in Cura with no luck.I am going to attach my PETG and PLA+ profiles from Cura so that anyone willing to help can check my settings.I am having issues with the surface finish and horrible stringing even with PLA.I will attach some pictures of the PLA printed part but the PETG parts are just as bad they have less stringing to be honest which I believe should be the opposite way around.I am printing all of this on a cartesian using a BLTouch for bed levelling and z endstop.
      Here is the PLA+ profile settings
      acceleration_enabled = True
      jerk_enabled = True
      retraction_combing = off
      support_tree_enable = True
      support_type = everywhere
      position = 7
      quality_type = draft
      setting_version = 6
      type = quality_changes
      Inland PETG
      brim_width = 6
      coasting_enable = True
      cool_lift_head = True
      default_material_print_temperature = 225
      infill_enable_travel_optimization = True
      infill_pattern = gyroid
      infill_sparse_density = 40
      optimize_wall_printing_order = True
      retract_at_layer_change = True
      retraction_amount = 3.5
      retraction_speed = 60
      support_brim_enable = True
      support_infill_rate = 5
      support_interface_density = 50
      support_interface_enable = True
      support_skip_some_zags = True
      support_tree_branch_distance = 6
      support_tree_collision_resolution = =support_line_width / 2
      top_bottom_thickness = 1
      zig_zaggify_infill = True
      PETG Profile
      PETG profile
      name = Inland PETG
      jerk_enabled = True
      brim_width = 6
      PLA Pic1
      PLA Pic2
      PLA Pic3
      0_1554794336801_IMG_20190409_010256.jpg[0_1554794499054_Esun PLA+.curaprofile](Uploading 100%)
      • Vetiundefined
        Veti
        this looks like a lot of issues.
        printing to hot. is the part cooling fan on?
        retraction settings not calibrated.
        possible e steps not calibrated
        • sibluesundefined
          siblues
          I am almost positive the e-steps are correct I am using the recommended value BMG recommends.The retraction and temp are another story.
          • Vetiundefined
            Veti
            try a retraction speed of 30-40mm/s
            60 can be too much depending on your stepper and voltage.
            check your temperature with this
            https://www.thingiverse.com/thing:2625999
            then try different retraction distances with this
            https://www.thingiverse.com/thing:2563909
            • sibluesundefined
              siblues
              I can do the retraction test but the temp tower I can not figure out how to adjust the temps in Cura to work.I am new to all of this so I am still trying to learn even the basic stuff at the moment.
              PuterProundefined 1 Reply Last reply Reply Quote 0
              • Vetiundefined
                Veti
                just print a small cube like a calibration cube. one each for the temperature.
                • sibluesundefined
                  siblues
                  I will do that as soon as the current print is done and I will post pictures.I am printing this current print a bit colder with the slower retraction setting.
                  • Vetiundefined
                    Veti
                    your part cooling fan is on 100%?
                    • sibluesundefined
                      siblues
                      Yes it is on 100% for the PLA but there is no cooling when printing in PETG.
                        Can you post one of the gcode files? That will include the cura settings as well.
                        Actually it would be helpful if you went to File>Save in cura and exported a .3MF file that had the whole cura and printer configuration together so we could see everything.
                        Also post your config.g and maybe a few more details about your printer. Pictures even.
                        Do you have any fresh filament? The stringiness could be from moisture in the filament if it's been sitting out for a long time.
                        Have you PID tuned the hotend? What kind of thermistor is it using? What values are configured for it? It's possible that the temperature reported is far off from the actual temperature.
                        • sibluesundefined
                          siblues
                          Here is the Cura file
                          cura MF
                          The filament is brand new both reels have just been opened they don't even have 24 hours worth of moisture absorption yet.
                          Here is the config
                          ; generated by RepRapFirmware Configuration Tool on Mon Nov 05 2018 12:42:23 GMT-0500 (Eastern Standard Time)
                          M550 PTony's P3 Steel ; Set machine name
                          M551 Pfabian7505 ; Set password
                          M552 S1 ; Enable network
                          ;*** Access point is configured manually via M587
                          M586 P0 S1 ; Enable HTTP
                          M586 P1 S0 ; Disable FTP
                          M586 P2 S0 ; Disable Telnet
                          M569 P0 S0 ; Drive 0 goes forwards reversed
                          M569 P2 S0 ; Drive 2 goes forwards reversed
                          M92 X80 Y80 Z400 E415 ; Set steps per mm
                          M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
                          M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
                          M201 X500 Y250 Z250 E250 ; Set accelerations (mm/s^2)
                          M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X-25 Y0 Z0 S1 ; Set axis minima
                          M208 X220 Y320 Z200 S0 ; Set axis maxima
                          M574 Y1 S0 ; Set active low endstops
                          M574 X1 S1 ; Set active high endstops
                          M574 Z1 S2 ; Use zprobe for zmin
                          M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                          M558 P9 H7 F200 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                          G31 P25 X24 Y0 Z3.503 ; Set Z probe trigger value, offset and trigger height
                          M557 X25:200 Y30:300 S40 ; Define mesh grid
                          M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                          M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                          M143 H0 S110 ; Set temperature limit for heater 0 to 120C
                          M305 P1 T100000 B4725 C0 R4700 ; Set thermistor + ADC parameters for heater 1
                          M143 H1 S290 ; Set temperature limit for heater 1 to 290C
                          M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
                          M106 P1 S1 I0 F500 H0:1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M106 P2 S1 I0 F500 H0:1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                          M563 P0 D0 H1 ; Define tool 0
                          M501 ; Override
                            I took a look at your cura profile and config and here's what I've got.
                            Is your nozzle size really 0.3mm?
                            The extruder jerk is quite low at M566 E120, same with acceleration at M201 E250 That's going to make your retractions pretty slow and allow some oozing, which could explain some of the stringing. I would try 1200 for jerk and 2500 for acceleration.
                            It would be nice to know what your thermistor is to know if your heater parameters are accurate since the pictures of your parts seem very overcooked. You can test your extrusion temperature by setting the hotend temp to something like 140 and trying to push the regular PLA filament through by hand. It shouldn't be able to melt very well at 140. If it does melt easily then your hotend temps may be higher than reported since PLA doesn't extrude very well until about 170c. If that's the case you can try reducing your print temps to see if it improves quality.
                            You may want to also try reducing the material flow % in Cura to 95%.
                            You may also want to disable the acceleration and jerk control in Cura for the time being as they are set very high compared to what you have in config.g and since this is such a small part you probably will need to slow down a bit. In fact, it may help to print two of these parts at the same time to give it time to cool down between layers.
                            You've got Z hop on retraction enabled in Cura. This will definitely add some stringing. Usually Z hop isn't needed.
                            Tree supports are probably unnecessary for this part. The overhangs are a little steep on the underside, but with cooling and slower external wall speed it should be alright. And the bolt holes on the top arms should bridge just fine.
                            • Vetiundefined
                              Veti
                              @siblues said in Horrible print results.Help needed?:
                              the B4725 would indicate that you are trying to configure a Semitec 104-GT2 but you are missing the C value. This would result in the wrong temperature. The C Value is 7.060000e-8
                              • sibluesundefined
                                siblues
                                I am using a .3 nozzle and I have adjusted the settings you mentioned other than the thermistor value.I am using a Semitec thermistor.I will try to print two parts so as to give them sufficient time to cool.I also turned off acceleration and jerk control in Cura and I am just slowing down the outer wall speed to 20.0 mm/s and disabling tree supports.
                                The thermistor value should be changed from
                                to
                                M305 P1 T100000 B4725 C7.060000e-8
                                • JamesMundefined
                                  JamesM
                                  FYI...I have gotten plenty of filaments that even though they arrived in a vacuum sealed bag with dessicant, they had moisture in them and had to be dried. Mainly PETG and definitely Nylon. Also I just received some prilon Carbon PC yesterday, perfectly vacuum sealed with dessicant and had tons of moisture.
                                  So if it's petg I would thrown it in an oven at it's lowest possible temperature for 4-6 hours or a dehydrator at 60-65C for the same time and dry it.
                                  • Dugeeundefined
                                    Dugee
                                    going to make a suggestion that helped me - make sure the filament size in the printer setup in cura is set to 1.75mm. I had very brittle prints and a lot of wierd issues because of this.
                                    even though I had set the filament size in the slicer at the correct size the printer profile was set to 3mm and was overriding the filament set up.
                                    basically gives the same effect as massive under-extrusion.
                                    probably not this but worth checking.
                                    • sibluesundefined
                                      siblues
                                      I am going to look into a dehydrator and the last time I checked it was set to 1.75 but I will make sure.
                                      The thermistor line in config.g should it be written like my second example?
                                        Phaedrux Moderator @siblues
                                        Yes, you can leave off the R value and the Duet will use the default, which is fine.
                                        As for the moisture, usually you can hear some hissing and popping or bubbling as you extrude into free air if it's really bad.
                                        I don't know where you live, but if there is high humidity it's more likely to be an issue.
                                        • sibluesundefined
                                          siblues
                                          I live in NJ also known as the armpit of America.I don't hear any hissing or popping which isn't definitive proof of dry filament.I tried lowering the temp to 210 before making all of the adjustments mentioned in this thread and there was much less stringing with the Esun PLA+ so maybe with the adjustments and some temp tuning I will get better results.
                                          • JamesMundefined
                                            JamesM
                                            I'm in NJ as well...I thought it was petg you were printing....I've never really had a moisture issue with PLA+. I used to use Esun but wasn't a fan and switched to Sunlu PLA+. Now for PETG I primarily use Esun.
