    Z-probe triggers way above table during HOME ALL
    2.2k
      When it triggers prematurely, does the red LED on the sensor illuminate?
      Billsrfundefined 1 Reply Last reply Reply Quote 0
      • Billsrfundefined
        Billsrf
        How do check that? I attached my config.g, home.all and home.z files. my home.all calls for a G30 to trigger and the config.g z-probe calls for a G31 at the same point. When I change the G31 in the config file to G30, it crashed into the bed without triggering, so I changed it back to G31
        www.dpp3d.com , pellet fed large format 3d printers
        • Billsrfundefined
          Billsrf
          swap that, HOME.ALL calls for G30, CONFIG.G calls for G31, HOME.Z calls for a G30
            dc42 administrators @Billsrf
            @billsrf said in Z-probe triggers way above table during HOME ALL:
            How do check that?
            By observing it when you run homeall. When it stops prematurely, also look at the Z probe reading in DWC, or send G31 without parameters to report it.
            • Billsrfundefined
              Billsrf @dc42
              @dc42 yes it flashes just like it is at the bed
                Can you confirm that it flashes just once? Not 2 or 4 times, like it does when it initialises?
                • Billsrfundefined
                  Billsrf
                  it is roughly 50mm above the bed, it flashed 1 time just like normal then moves up 5mm. 0_1555960761051_Z probe.JPG
                    G31 P500 X570 Y570 Z0
                    This looks a little off from your config.g.
                    Is the probe really X570 and Y570 away from your nozzle?
                    You also haven't calibrated the Z trigger height.
                    • Billsrfundefined
                      Billsrf
                      after home.all, I can push HOME.Z and it moves to the bed and sets the correct nozzle height
                      • Billsrfundefined
                        Billsrf @Phaedrux
                        @phaedrux i have the offset Z trigger height set to zero for testing. What should the X-Y settings be for the G31? isnt it center of my build plate?
                          Phaedrux Moderator @Billsrf
                          @billsrf The X and Y values for G31 should be the distance of the probe from the nozzle. Just as the Z value is the distance from the probe to the nozzle tip in Z.
                          If the probe is to the left, the value will be -x.
                          If the probe is to the right, the value will be +x.
                          If the probe is to the front, the value will be -y.
                          If the probe is to the back, the value will be +y.
                          • Billsrfundefined
                            Billsrf
                            my BED.G looks like it is missing a lot of information now for some reason. 0_1555961191732_bed.g
                              It looks like your bed.g is currently setup to just do a mesh grid compensation run.
                              • Billsrfundefined
                                Billsrf @Phaedrux
                                @phaedrux ok, i will measure the offset and change that in the G31 in config.g
                                • Billsrfundefined
                                  Billsrf
                                  If I am not using a bed compensation. Why would that be making my trigger so high off my build surface? It moves down about 20 mm then triggers during home.all. But, if i do a home.z afterwards it moves to the correct trigger height and it is ready to go
                                    Have you gone through these steps?
                                    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                    • Billsrfundefined
                                      Billsrf
                                      yes 9 times. I will change the offsets and then go through the probe set up again
                                      • Billsrfundefined
                                        Billsrf
                                        @dc42 went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
                                        • Billsrfundefined
                                          Billsrf @Phaedrux
                                          @phaedrux went through the same set up process as described in test and calibrate Z probe, same results as before, it moves down 10 mm then triggers then stops. I did nottice, as it is moving towards the X-Y home position, the IR sensor flashes 3 times like it is just initialized. Never done that before either.
                                          • Billsrfundefined
                                            Billsrf
                                            Tried running a G29 and this is what I am getting back now. I have never had this kind of issue with my duet3d before. its triggering during moves.0_1555968974806_G29 Probing.JPG
