cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems
Read through the online documentation. Therw is a guide for setting up caryesian printers:
https://duet3d.dozuki.com/Guide/3.)+Configuration+(General+Cartesian)/10
Have a general read through the documentation here too:
please bare with me i believe i have a mix of adhd and autisum so i tend to jump ahead of my self and miss steps but also some documentations i have read leave parts out and its thoughs parts that can get me confused so im sorry if i stress any of yous out and thank you so far i will re do my reprap and will be back
@jobesynoob1234 it's easy enough to miss the piece of documentation that has the right information for you when new. My posts were intended to help, but their brief nature probably came over as being snappy. Not intended.
hi again well re-did my reprap and heres the new config.g
; generated by RepRapFirmware Configuration Tool v2 on Mon May 13 2019 10:59:27 GMT+0100 (British Summer Time); General preferences
M83 ; ...but relative extruder moves; Network
M550 P"CREALITY CR-10S" ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S1 ; Enable FTP
M569 P0 S0 ; Physical drive 0 goes forwards
M569 P1 S0 ; Physical drive 1 goes forwards
M569 P2 S1 ; Physical drive 2 goes forwards
M569 P3 S1 ; Physical drive 3 goes backwards
M92 X80.00 Y80.00 Z400.00 E842.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X1000.00 Y1000.00 Z1000.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X285 Y285 Z385 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S1 ; Set active low and disabled endstops; Z-Probe
M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
M557 X15:195 Y15:195 S20 ; Define mesh grid; Heaters
M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
M305 P0 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S285 ; Set temperature limit for heater 1 to 285C; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
all motors home but my z still sounds energized and doesnt back off the endstop switch
have a look at you homeall.g
it explains it
;G91 ; relative positioning
;G1 S2 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning -
like this
//;G91 ; relative positioning
//;G1 S2 Z5 F100 ; lift Z relative to current position
//;G90 ; absolute positioning -
no // is c/java (and other programming languages)
uncomment mean removing comments not adding them.
so remove the ;
yip thats one of them confusing parts with me using marlin
i did that and it now lifts but i can still hear power going through it is that normal -
Ok i would like to say a massive thank you veti and doctrucker for steering me in the right direction you have saved me a lot of stress all motors home heatbed works now i just need to level the bed and try a print i still need to look into that "reducing stand still noise" but the important parts are sorted now so im a very happy bunny thank you again for your time
@jobesynoob1234 said in cr-10s upgrade to duet 2 wifi motors and ac 750w bed problems:
That's not uncommon. The current will be reduced automatically by a specified amount (default is to 30% of normal) after a specified idle time (default is 30 seconds), so it should get quieter after that. You can adjust that 30% and 30 seconds, they are controlled by the M906 command in config.g. If you find the standstill noise loud enough to be annoying, see the link posted by @Veti.
The Creality motors seem to have a rather unpleasant whine at low power for some reason. It's not so much loud as it is piercing.
@dc42 hello yip thats what i also did i knocked it down to 10seconds
@phaedrux so will it help if i shove the current up to 1000ma i did first put them to 750ma!
@jobesynoob1234
changing the current will not change the noise. -
@veti ah right well they can stay where they are then
