    End stop suggestions for Duet controlled CNC Mill
    • 3DPMicroundefined
      3DPMicro
      Waterproof is a must and needs to repeat within .025 mm. I can get a bulky mechanical switch but this is for a tiny mill so i'm trying to avoid "bulky". I guess that leaves an optical or proximity type switch or?? Some guidance would be greatly appreciated.
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
      • zaptaundefined
        zapta
        Have you considered motor stall detection?
        Catalin_ROundefined 1 Reply Last reply Reply Quote 0
        • Catalin_ROundefined
          Catalin_RO @zapta
          @zapta I would not recommend stall detection for CNC mills/routers. The steppers usually have a lot more torque than in 3D printers because of the force needed to push the cutter through the material. So after a few stall detection cycles something might break.
          @3DPMicro An inductive switch might do the trick. They are waterproof by design. Alternatively, I recall I have seen some switches with a thin rubber cap over the button. Misumi has quite a few options, but they are on the expensive side, with all of them more than 40EUR.
            A Former User
            I use inductive switches, looks like the PINDA probe but 12mm diameter. They are more repeatable than I can measure. Also used some smaller rectangular sensors before, found the threaded body easier to adjust though.
            Only challenge with the Duet is most of the industrial ones need 12-24v, refer to the wiki for how to connect these to Duet. https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_NPN_output_normally_open_inductive_or_capacitive_sensor
            • 3DPMicroundefined
              3DPMicro
              Thanks for the suggestions gents. I didn't think about using stall detection and although I would agree it may not seem well suited for a high power milling application this isn't really a high power application. 12.5 N/cm nema 14's with 1 mm lead ball screws do generate over 50 kilos of force though. Reading up on it I do think repeatability would be an issue (+-2 full steps) which may be worse with the high reduction from the 1 mm lead.
              I'll try some cheap inductive switches from eBay and go up for on there if needed.
