    First Test Print following Duet3d Upgrade
    3.2k
    • B0M0A0Kundefined
      B0M0A0K
      @Phaedrux @dc42
      I have the print running at what Cura (4.1.0) calls "Extra Fast" the settings for which are as follows;
      Resolution: 0.3mm
      Print Temp: 190
      Print Temp Initial Layer: 190
      Initial print temp: 180
      Build Plate Temp: 60
      Flow: 100%
      Retraction enabled
      Retraction Distance: 6.5mm
      Retraction Speed: 25
      Print Speed: 60
      Travel Speed: 120
      Initial Layer Speed: 30.0
      Cooling Enabled
      FAN Speed: 100
      FAN Regular Speed: 100
      FAN Max Speed: 100
      Support: No
      Build Plate Adhesion: Brim
      Brim Width: 8.0
      Print Sequence: All At Once
      However. The Wanhao Duplicator i3 profile is active in the Cura interface so I'm not sure how much of that it keeps if you choose a Cura based resolution rather than the Wanhao profile (included below).
      It's worth mentioning that I used the "Extra Fast" setting to produce the better quality Benchy while the Wanhao i3 was still using the factory Melzi board.
      3_1559674614870_Wanhao Printer Profile Settings.png 2_1559674614870_Printer Machine Settings.png 1_1559674614870_Nozzle Settings.png 0_1559674614870_MaterialsPlusSettings.png
      No fate but what we make ....
      • B0M0A0Kundefined
        B0M0A0K
        Let me know if these are too small, I was getting told off by the system earlier for trying to post images that were too large, so have been reducing the images by 50%
          As I suspected, the screen shot of your machine settings extruder tab show it's using 2.85mm for your filament diameter. Change that to 1.75 or whatever the measured diameter of your filament is.
          • B0M0A0Kundefined
            B0M0A0K
            @Phaedrux Thanks for spotting that. I am confused about the relationship between the Wanhao profile and the Cura "Extra Fast" setting. Does that suggest that Cura uses the Wanhao profile as the base setting and then applies the Cura Extra Fast setting as a "tuning" of the model to be printed?
            By the way, I'm definitely using 1.75 filament.
              I don't think the machine setting has much of an effect on the print settings exactly. But it does define the physical properties of the machine.
              Either profile you choose will likely work fine ok nice the filament diameter is set correctly.
              B0M0A0Kundefined 1 Reply Last reply Reply Quote 0
              • B0M0A0Kundefined
                B0M0A0K @Phaedrux
                @phaedrux Thanks, I will try printing the temp tower and see what happens.
                • B0M0A0Kundefined
                  B0M0A0K
                  I have adjusted the machine settings to reflect 1.75 filament, re-leveled the bed, leveled the X-axis and started to print the temperature tower. Looks like a good 'squish' but there is already sign of melting on the left hand 0_1559677025847_temptower.png
                  • B0M0A0Kundefined
                    B0M0A0K
                    OK Folks. The temp tower has finished printing and the results are in. I am adding photos and the Cura GCode for your perusal.
                    0_1559680332452_BM-GCODE.txt
                    8_1559680352561_WIN_20190604_21_28_45_Pro.jpg 7_1559680352561_WIN_20190604_21_28_25_Pro.jpg 6_1559680352561_WIN_20190604_21_24_54_Pro.jpg 5_1559680352561_WIN_20190604_21_24_49_Pro.jpg 4_1559680352561_WIN_20190604_21_24_26_Pro.jpg 3_1559680352561_WIN_20190604_21_23_43_Pro.jpg 2_1559680352561_WIN_20190604_21_23_38_Pro.jpg 1_1559680352561_WIN_20190604_21_23_35_Pro.jpg 0_1559680352559_WIN_20190604_21_23_25_Pro.jpg
                      Did you manually change the temperature? Looking at the gcode file I don't see any M104 commands in there to change the temp at the corresponding layer.
                      On the plus side it looks better than the Benchy.
                      • B0M0A0Kundefined
                        B0M0A0K
                        I didn't change anything in the code, I just downloaded it and exported the gcode to Duet Web Control. I see the author mentioned the different temp changes and a failed Perl script.
                        Was I supposed to change those?
                        • B0M0A0Kundefined
                          B0M0A0K @Phaedrux
                          @phaedrux said in First Test Print following Duet3d Upgrade:
                          It IS steady progress. The suggestion you made to change the M556 and M203 started it in the right direction, the correct filament size got it midway.
                            Yeah, in order to change the temperature at each layer section you need to go into the exported gcode file before printing it, find the layer height you want the temperature to change and then add your own M104 command to set the temperature. Otherwise it just prints to whole tower at the same temperature and kind of defeats the purpose.
                              I think if you can get your temperature sorted out you'll get the rest of the way there.
                              I'm not super familiar with the Wanhao hotend, but maybe it's a good opportunity to upgrade to an E3D V6 with proper thermistor or PT100, etc that would give you known reliable temps.
                              • B0M0A0Kundefined
                                B0M0A0K @Phaedrux
                                LOL, yep, I like your thinking, but I'm going to have to do one upgrade at a time to limit "anomalies". I have a 3mm base to add, the BLTouch and [optional] igus RJ4JP-01-08 - Solid Polymer Bearings (LM8UU) .
                                But I can't do any of that without getting the prints settled down.
                                • B0M0A0Kundefined
                                  B0M0A0K
                                  This has not gone well so far.
                                  I have no idea what point at which I should add my M104 entries on a print GCode. I found a great explanation by "inventimark" here: "3D Printing Guide #001 : Changing Temp in Gcode" https://www.youtube.com/watch?v=EATU7grYZ8E
                                  So I fired up Repetier Host and loaded the "Better_Temperature_Tower_v5_240-180.stl" file. Next I worked through the tutorial changing the temp with the M104 command and the appropriate temp change at each new step in the tower.
                                  I checked my X-Axis for parallel, changed my config.g to allow for the increase in extruder temp (mine had been set with the max temp well below 240) and the performed HomeAll.
                                  I started the print.
                                  First thing I notice is that today my Extruder temp is back to wandering. +5 Degrees above the primary temp (I set to get the extruder up to a working temp) and below by up to 2 Degrees. Strange, it wasn't doing that yesterday, though it did sort of settle down in the end.
                                  The print starts. The skirt looks fine and sticks well, filament adhesion looks alright. I watch it until it starts the base of the first tower and then look away for a few moment. When I look back the print head is printing in midair around 10mm off the bed. I cancel the print.
                                  Not sure if anyone can spot what I did wrong, damned if I know.
                                  0_1559735319213_BM_Better_Temperature_Tower_v5_240-180.gcode
                                  Vetiundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                  • Vetiundefined
                                    Veti @B0M0A0K
                                    @b0m0a0k
                                    that g code does not contain any temperature variation.
                                    Open the file in a text editor like notepad++.
                                    then find the layer information
                                    i.e
                                    ;LAYER:116
                                    and add the corresponding line underneath.
                                    i.e
                                    M104 S225
                                    • B0M0A0Kundefined
                                      B0M0A0K
                                      You're absolutely right, I posted the wrong file. Sorry. Let's try that again.
                                      0_1559737942538_BM-EDIT_INCL_TempChanges_Better_Temperature_Tower_v5_240-180.stl
                                      0_1559738055550_BM_Incl-Temp-Changes-Temperature_Tower_v5_240-180.gcode
                                        Phaedrux Moderator @B0M0A0K
                                        @b0m0a0k said in First Test Print following Duet3d Upgrade:
                                        Did you save the results of the PID tune you did yesterday? After the tune, send M500 to save it. You'll then need M501 at the end of your config.g to load those tuned values again at boot up.
                                        It kind of sounds like the heater either got turned off. Did you happen to notice what the temperature was or what the temp graph looked like?
                                        That Gcode file has M104 commands in it at least. Try removing the P0 from the command. Instead of M104 P0 S235, try just M104 S235. Also it looks like one or more temperature steps got skipped/duplicated. But you're on the right track.
                                        B0M0A0Kundefined 2 Replies Last reply Reply Quote 0
                                        • Arkadiuszundefined
                                          Arkadiusz
                                          I can see 2 problems here:
                                          • Layer height is 0.3 I would go for 0.2 its more "standard" height and will let you compare your print with others.
                                          • looks like there is over extrusion, try lowering your flow rate
                                          Arkadiuszundefined 1 Reply Last reply Reply Quote 0
                                            Arkadiusz @Arkadiusz
                                            Under extrusion:
                                            Over extrusion:
