Requested speed is not reached
6.2k
    PuddingBaer91
    Okay Data seems to be wrong on the Website. My Motor ist labeled with 2.5A
    https://photos.app.goo.gl/CSqKTi9TxJZBSTX27
    Should i ran the Motors near 85% ? 2A?
      Veti
      @puddingbaer91 said in Requested speed is not reached:
      yes
        PuddingBaer91
        Thank you i will try and Report. But can't Imagine that this causes the Problem because the Motors are already very Strong at 1.3 ampere...
          PuddingBaer91
          tried with 2100mA but even with pa=0.1 the same sound but now only at high speed when printing infill. While printing slower the sound is now silent. Tomorrow i will try another stepper for extruder drive and report results
            PuddingBaer91
            okay also with another stepper (original from TronXY) i get the same sounds 😞 Only reducing jerk to 600 will result in good sound
            undefined 1 Reply Last reply 8 Jun 2019, 08:18 Reply Quote 0
              deckingman @PuddingBaer91
              @puddingbaer91 I say again that none of my 5 Bondtech BMGs make that noise. You said above that "there should be nothing loose" but have you actually taken it apart and checked?
              Edit. The only reason why reducing "jerk" helps the sound is that it effectively reduces pressure advance so either don't use pressure advance at all or fix the problem with the extruder.
                PuddingBaer91
                Could you please Share a Video of your running Extruder? I de assemled my bondtech 100 Times also because switching Stepper Motor it seems all perfekt. Also the other Extruder (ultimaker Clone) Made These Sounds...it also makes this Sound with pressure advance = 0.1
                Edit: i bought a bondtech BMG Clone to Check If Mine was faulty...
                undefined 1 Reply Last reply 8 Jun 2019, 13:54 Reply Quote 0
                  Taken just a few minutes ago and uploaded to my google drive folder.
                  https://drive.google.com/file/d/1oEaL72FOPDlCzU3uTm2UajcCdYBtXVWL/view?usp=sharing
                    PuddingBaer91
                    thank you this is what i expect from my extruder 🐶
                    May i found the problem:
                    https://photos.app.goo.gl/Krb1Pd1MatLy46S57
                    look closely to the metal gears. I tightened the screw to max and loosen it till it is possible to move the plastic gear (just a little bit. As you can see the spring is on block (compressed fully). The gears are slipping 😤 if i loosen the srew much more this will also happen. I think this is not normal or what do you think?
                      Veti
                      have you tightened the grub screw on the gear with the white gear?
                        PuddingBaer91
                        yes checked that. Here is also a video with cover (second bearing) mounted.
                        https://photos.app.goo.gl/PoWPArpmCjFiu4kH7
                        metal gears still slipping
                        undefined 1 Reply Last reply 8 Jun 2019, 15:08 Reply Quote 1
                          Veti
                          take the one with the white gear apart and post a picture of the shaft and the grub screw.
                            @puddingbaer91 AFAIK that white gear is a press fit onto the shaft and it looks like it might be slipping. Take it apart and clamp the shaft firmly, then see if you can move that gear. It's likely to get worse the longer you print because of the heat conduction from the motor which will soften the plastic and /or make it expand more than the shaft. If that is the case, then you could try a it of epoxy adhesive or contact Bondtech and see if you can get new gear/shaft assembly (but make sure that is the problem first).
                            Edit - looks like we weer both typing at the same time.
                              PuddingBaer91
                              Commando Back, talked with bondtech Support and they told me it is designed for using with Filament loaded. Then they doesn't Slip. Reassemled and If i Turn the White Gear fast Back and forth by hand with Filament loaded There ist absolutely No Bad Sound. So i will try it again. If it is Not better i will do a Print without bondtech Extruder to Gear only Extruder stepper
                                Veti
                                the white gear and and bondtech gear should never turn separately, even if there is no filament loaded.
                                  PuddingBaer91
                                  i tried again but the same sound. So i unmounted the bondtech bmg and printed without it. The sound comes from the motor because it is skipping steps or something other is wrong with them.
                                  If i hold the motor shaft while printing lines without big speed changes i can't fix the shaft by hand. While fast and often print speed changes (infill) i easily can fix the motor shaft by hand also can turn the shaft in each direction by hand in spite of motor is working.
                                  I tried 3 motors (ACT, original tronxy and original e3d pencake) but all three acting the same. Also lowered the current of xyz to 800mA and let the extruder at 85% current but no change (may it's a little harder to fix the shaft)
                                  Do you know whats going wrong here?
                                  It's a 12V system with 360W power supply
                                  undefined 1 Reply Last reply 8 Jun 2019, 20:50 Reply Quote 0
                                    @puddingbaer91 If you run M122 while it's printing, what is the reported voltage?
                                      PuddingBaer91
                                      @deckingman said in Requested speed is not reached:
                                      M122
                                      Supply voltage: min 11.7, current 11.8, max 11.9, under voltage events: 0, over voltage events: 0, power good: yes
                                        Do you have any other motors to test with?
                                          PuddingBaer91
                                          I have more tronxy Motors... But don't think the 3 i tested all faulty
                                          56 out of 75
