    Very strange behavior, CoreXY with external drivers
    2.8k
    • Capricornundefined
      Capricorn @Veti
      @veti
      hmmmm... now i´m unsure myself.... maybe dc42 can light this issue up?
        Capricorn @dc42
        To the question of groundloops...
        is my power distribution ok?
        • jhonf441undefined
          jhonf441 @Capricorn
          @capricorn said in Very strange behavior, CoreXY with external drivers:
          to clarify how my extern drivers are connected:
          all Step+/Dir+ from the ext. drivers go to +5V.
          all Step-/Dir- from the ext. drivers go to the corresponding pins on the breakout board
          I can not read in its description, where the EN pins of the external drivers are connected.
          GND (-) from all sources should be a common point, to that the logical levels that reach the external drivers are measured with respect to a single GND of the entire system.
            dc42 administrators @Capricorn
            @veti
            not suitable for me, because i have no duex2 oder duex5 board. i have the duet2 ethernet and the expansion breakout board. the breakout board is only connected by the 50Pin connector
            Can you provide photos of your wiring between the expansion breakout board and the stepper drivers, so that I can check it?
            @veti said in Very strange behavior, CoreXY with external drivers:
            it would still cause a grounding loop.
            https://en.wikipedia.org/wiki/Ground_loop_(electricity)
            there is also a very specific warning for the duet where you have a separate 5v supply via usb.
            see
            https://duet3d.dozuki.com/Wiki/USB_ground_loops
            Should not be a problem if the 5V and main PSUs are in the same case, fed by the same mains cable.
            Capricornundefined 4 Replies Last reply Reply Quote 0
              Capricorn @dc42
              I think you won't see much. 0_1560031035943_IMAG0121.jpg 0_1560031070081_IMAG0122.jpg 0_1560031146843_IMAG0123.jpg 0_1560031194828_IMAG0129.jpg 0_1560031308327_15600312717345312954912045206415.jpg 0_1560031438647_15600314069137559970456482783905.jpg
                Capricorn @dc42
                  Capricorn @dc42
                  I hope you can see anything. I'm 100% shure, there is nö mistake in the cabling. I checked every single connection more than once, incl. with Multimeter.
                  jhonf441undefined 1 Reply Last reply Reply Quote 0
                  • jhonf441undefined
                    jhonf441 @Capricorn
                    @capricorn You need to connect each ENABLE signal that comes from the breakout board to ENA (-) of each driver.
                    Capricornundefined 1 Reply Last reply Reply Quote 0
                      Capricorn @jhonf441
                      @jhonf441
                      No, not necessary and my drivers don't work at all, when connected.
                        Capricorn @dc42
                        Maybe this helps to localize the problem :
                        I measured the resistance between the different
                        Step- Ports:
                        X>Y = 9.74 kOhm
                        Z>Y = 9.74 kOhm
                        X>Z = 3.30 Ohm!!!
                        Maybe the Breakoutboard is damaged?
                        But i'm uncertain, because this measurements are always the same, no matter which combination of Ports 5-9 I use.
                        Not connected to the Breakoutboard the resistance
                        in each xyz combination is 7.75 kOhm (because of the common 5V line to each driver)
                          I was already thinking that it's time to try a new breakout board and ribbon cable. Please ask your supplier to replace them. https://www.duet3d.com/warranty
                            Capricorn @dc42
                            OK, i'll try that.
                            Thank you so much, I will report if that works.
                            Meanwhile I finished cabling and everything works great 😀 , only the Motors 😞
                              Capricorn
                              Newest update:
                              Last Monday, i ordered a new Breakout-Board at a German supplier. They confirmed my order and told me, it's on stock and delivery time 3-4 days. Nothing happend since then.
                              So today i lost patience and did some further tests.
                              Result is, i desoldered the 4 75ALS192 chips and connected all the S-/D- to the appropriate ports on the 50-pin connector. Had to change the direction of rotation, and viola', all systems running. Perfect...
                              Smoothly...
                              I can not wait any longer, to do my first print. I'm so exited....
                              Thank you all, for trying to help me with that issue.
