    Part Cooling Fans/Ducts
    1.7k
    • burtoogleundefined
      burtoogle
      Over the years I've tried all sorts of fan setups but now this mini-Kossel (ancient T3P3 kit, much modified, still working hard!) is equipped with the simplest possible solution, just a blower pointed at the spot below the nozzle. It works fine for all the prints I have tried it on. Not claiming it would be fine for everything. Here's a bad picture of the setup...
      • DocTruckerundefined
        DocTrucker @burtoogle
        @burtoogle That's not far off what I have running on my most standard Ormerod, but that does suffer when a 45 degree from vertical is behind the part relative to the fan. That said, mine is restricted with a small mount/duct.
          DocTrucker @deckingman
          @deckingman Tusk sounds like it is similar to what I have come up with.
          I'm trying to address issues with poor surface finish on surfaces 45 degrees from the vertical. Perhaps if it is not normally need then this may be more down to where the slicer is dumping the start/stop of the extrusion. More checking & tuning neeed! 😄
            DocTrucker
            Ok here's the stick man cooling duct. Accidental likeness.
            The mount is more chunky than necessary as it is designed to be able to take a direct mounted filament drive or, as shown here in a trial fit bowden.
            The slots are 17 * 2mm aimed to hit the build surface 5mm either side of where the nozzle touches. I'm just re-building with 3mm wide slots and the 'feet' dropped about 3mm to clear the silicone sock better. So far this one hasn't gone bendy...
            Edit: Trying to keep the path lengths to each side as even as possible, inlet to the fan as unrestricted as possible, and the inlet not sucking straight off the hot part bed.
            At 3mm the total area of the slots is still about around 50% of the outlet hole on the fan so I feel I still need to tweak a bit further...
              DocTrucker
              These are my previous iterations:
              First mounting of radial fan on standard reprap nozzle. Still going! Not great finish on 45 from vertical when the side is sheltered from the fan.
              First attempt at cooling on both sides of part around a V6 mounted on an Ormerod: The power cable from the heater was resting on the duct, was too hot, and closed the vent off on one side.
              Vikinghat style cooler. Alas to restrictive.
              Final iteration before current was this one. It was an attempt to be less restrictive. It that last less than one build before curling down and colliding with the print.
              Finally, yes I really should try the pumped systems soon but thought I should have been able to get a reasonable job with a radial blower.
                deckingman
                Also on my todo list is to make something similar to a Berd air but I'd likely use something like a Koi pond air pump because I've heard the Berd ones are noisy. (Koi like deep water so a suitable air pump would have good pressure as well as flow). I already have a micro pipe bender so forming the tube should be easy enough.
                • PlasticMetalundefined
                  PlasticMetal
                  This one has become popular on the RailCore II coreXY printers: https://www.thingiverse.com/thing:3367622. One fellow did mod his further by adding a small hole in the center, between the two primary outlets. This design is actually similar to MHackney's tusk technique.
                    DocTrucker @PlasticMetal
                    @plasticmetal Thanks for the link. I make the area of the exhaust to be about 45% of the outlet of the fan. If that's working well then I've no need to try and get better than my last attempt which is about 75%!
                    Second iteration of the stickman has dropped the feet by 3mm and opened the slot out to 3mm wide. I've yet to test this. Got to go pickup my son now from the inlaws.
                    The third iteration is just about to finish printing which has the feet 10mm longer which will cool the IR sensor a little but also cool a little better around the part. When I stuck my my finger under the first iteration with the full on full chat the airflow feels like it is going around the back of the heater block more than the front, so hopefully this should balance it a bit more.
                      PlasticMetal
                      Try placing a small dish of water on the bed, under the nozzle, to help visualize the air flow.
                      deckingmanundefined DocTruckerundefined zaptaundefined 3 Replies Last reply Reply Quote 2
                        deckingman @PlasticMetal
                        @plasticmetal said in Part Cooling Fans/Ducts:
                        That's a very good tip 👍
                          @plasticmetal I'll second that. Neat trick.
                            PlasticMetal
                            I read it elsewhere. I'm not that ingenious.
                              @plasticmetal fair enough, although kudos for not running with the credit! It is refreshing within this community that people actively credit work that has inspired or educated themselves.
                              • zaptaundefined
                                zapta @PlasticMetal
                                What should be the ideal pattern? How do you decide if design A is better than design B?
                                [I am using the hypercube evo design, strong flow from one side, and a silicon suck on the heat block]
                                  PlasticMetal
                                  I haven't tried this yet myself, but I would think you'd want to see an even depression in the water, centered around the nozzle. You don't want air blowing on the nozzle, so the depression would look like a doughnut/torus, with the water level under the nozzle not depressed.
                                  Getting a fan duct to do this, is another story. Obviously circular ducts, like Berd Air, can do it more easily than others. OTOH, it doesn't have to be perfect - just better than whatever you're using now ☺
                                    I just adapted a bracket to fit the classic Dii cooler to my setup. I have yet to find a better duct.
