    Door Open Switch and LED´s
    duet leds trigger door door open pause command
    3.3k
    • CR3Dundefined
      CR3D
      Thank you for your answers 🙂
      @Martin1454 yes the LED Stripes work with 24V
      Normally my setup is following:
      The Duet is the controller board and the raspberry touch with repetier server is the HMI.
      In repetier server, there is a function Light on/off.
      In Repetier Firmware there is the command M355 S1 / S0 for this function.
      But I will test your solutions 😉
      @bearer i like your idea with the temperature control 🙂
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
        deckingman @A Former User
        @bearer said in Door Open Switch and LED´s:
        ............. I chose to make them as a thermostat controlled fan output, enabling whenever bed of hotend is over ambient temperature.
        M106 P1 S1 I0 F500 H0:1 T25 Basic thermostatic control for FAN1 either heater over 25C lights on.
        But I would like to make it so LEDs turn on whenever motors are active as well as when the temperature is high.
        Just out of curiosity, is that a "because I can" kind of thing or is there some practical reason?
          A Former User
          @deckingman said in Door Open Switch and LED´s:
          Printer is fully enclosed with relatively small windows so it gets relatively dark inside; temperature controlled works well enough when printing but for moving the axis when cold it would be nice to have light as well, and automatic is "always" better than manual:)
            @bearer We'll just have to agree to differ on the "automatic is always better than manual" thing. ☺ I just use an on/off switch.....
            However, in your case how about putting your M106 command in your slicer start gcode rather than config.g? That way, the lights would stay off until you start a print and the temperature gets above ambient. Or maybe, just use a couple of macros - one to turn them on and one to turn them off. Then you could call these from the slicer start and end gcodes as well as at any other time. Just a thought........
              A Former User
              Possibly getting a little OT, but if I can keep the config isolated to the Duet and not the slicer thats a + in my book. Sometimes I do remote operations using a IP camera as well, so automagic or at least controllable is good for me.
              I'm sure I'll come up with a better plan once I'm more familiar with the Duet and the firmware, but temperature control was quick, easy and 90% good enough, if need be I can heat the bed to 25C in seconds.
                @bearer Fair comments. Just bear in mind that almost all gcodes can be input at any time - even "on the fly". Sometimes that can useful....
                • CR3Dundefined
                  CR3D
                  Hi all,
                  thanks again for your answers!
                  I want to show you the working results.
                  I connected the LED´s directly to the fan output and implemented the firmware like this:
                  For the Open Door Switch I want to use M581. In principle it works...the macro is called, but for me M226 doesn´t work...
                  I have to complete... i use a Raspberry Pi with repetier server as User Interface. The connection is USB.
                  So I have read a lot about USB and Pause...for example this
                  https://forum.duet3d.com/topic/8065/m226-pause-gcode-ignored/12
                  I also updated to the last firmware version...
                  My Pause gets ignored... how to fix it?
                  Thank you a lot!!! 🙂
                  Homepage:
                  www.cr-3d.de
                  Facebook:
                  Our Discord Server
                    dc42 administrators @CR3D
                    M226 is for use within the GCode file being executed, for example where you want to pause at a particular point to change filament, or insert an object to be embedded within the print. Elsewhere, use M25. [M25 should also work where you are supposed to use M226.]
                    • CR3Dundefined
                      CR3D
                      Ok thank you...and both work with USB connection from Raspberry?
                      Homepage:
                      www.cr-3d.de
                      Facebook:
                      Our Discord Server
                        @cr3d said in Door Open Switch and LED´s:
                        M25 will work. M226 should only be used from within an SD card print.
                        • CR3Dundefined
                          CR3D
                          Ok Thanks! I will test it ...
                          Homepage:
                          www.cr-3d.de
                          Facebook:
                          Our Discord Server
                          • zaptaundefined
                            zapta @A Former User
                            I did something similar by sniffing the serial communication of the Panel Due with a small Arduino board and controlling RGB LEDs colors based on the status, temp, etc. There is a recent thread about it here, with pictures and a link to the source files.
                            • CR3Dundefined
                              CR3D
                              Unfortunately, M25 does not work with a print via USB. See error message
                              any recommendations?
                              New Firmware Version
                              Homepage:
                              www.cr-3d.de
                              Facebook:
                              Our Discord Server
                                That's as expected. The headline description of M25 is "Pause SD print". When printing over USB (which we don't recommend anyway), the program that sends the data has to handle pausing. That's what Octoprint and similar programs do.
                                • CR3Dundefined
                                  CR3D
                                  Yes I know... repetier Server is something like octoprint.
                                  And I know that you don´t recommend it...
                                  I have to use this as my user interface, because my customers want this.... is there no other possibility to control the pause?
                                  I spoke with the guys from repetier, they said that it was possible to request a break.
                                  RequestPause: Reason
                                  The server also understands @Pause
                                  Is it possible to send such commands to the server?
                                  The same problem exists for me with the filament runoutsensor...
                                  Would be glad if you can help me! 🙂
                                  Homepage:
                                  www.cr-3d.de
                                  Facebook:
                                  Our Discord Server
                                    Please clarify: what inputs does Repetier Server have for requesting a break?
                                    What is it that your customers don't like about using Duet Web Control as the main user interface?
                                    • CR3Dundefined
                                      CR3D
                                      So now here is the answer from Roland Littwin .. the programmer of Repetier... The answer in the picture is in german... here the translation from the mail:
                                      <response type="requestPause" string="true">//\saction:pause\b\s(.)</response>
                                      <response type="continuePause">//\s
                                      action:resume\b</response>
                                      Recently there was a discussion with the Marlin developers and Gina from Octoprint to correctly implement the official solution. As a result, you can
                                      // action: break
                                      send from the firmware to tell the host to pause. (RequestPause: The reason is the solution only Repetier host / server understand, therefore, if it is officially implemented better you use action commands.)
                                      // action: resume
                                      would make the host talk again.
                                      This was wrong in older server versions because the description was too spongy. But with the last version it should work correctly. Marlin is still echoing: before that what is accepted by the server.
                                      So if the sensors are connected to the printer you have to bring the firmware only to send this. How does David know who wrote the firmware? Logic would then perhaps if sd pressure as always else host ask for break. Whether he also installs a continue or if you should always explicitly click on the server afterwards is then a matter of taste.
                                      Hope that helps to solve it on the firmware side.
                                      In my opinion, a break function is enough. that would continue in my opinion then synonymous over the server suffice.
                                      Is it possible to add this command ... ? 🙂
                                      Thanks a lot!!!
                                      And about Duet interface:
                                      I try to use it more in the future, but companies often like a clear and simple design, file management on the server, display of files etc ... actually things that are less related to printing, but unfortunately it is. ...
                                      Homepage:
                                      www.cr-3d.de
                                      Facebook:
                                      Our Discord Server
                                        To do this properly, the GCode sender would need to tag each line with a file address or line number or similar (line numbers are a standard but optional feature of GCode) and RRF keep track of them. Then in the resume message, RRF would tell the sender which line to resume from. That way, RRF can do an early pause, throwing away moves that have been queued but not yet executed - just as it does when you print from SD card.
                                        Without this, RRF will need to send the pause response, complete all the moves in the queue, and complete any additional moves that the host has already send or is in the process of sending (otherwise it won't be able to read the resume command from the host). So the pause will be delayed significantly.
                                        It really is much simpler to print from SD card, also that way you are not dependent on a host computer to send the GCode stream fast enough - which is a problem not only with a Windows host but, according to reports, even when using a dedicated Raspberry Pi as the sender.
                                        • CR3Dundefined
                                          CR3D
                                          Yes I know that SD would be much easier... i will focus this in the next time... but for other Machines a USB Print is needed.
                                          The delayed pause is ok... I know this...
                                          A resume isn´t needed....
                                          Would adding the pause function possible? 🙂
                                          Homepage:
                                          www.cr-3d.de
                                          Facebook:
                                          Our Discord Server
                                            What is the reason that you want the Duet to be able to initiate the pause? Is it because the reason for the pause is out-of-filament, or something like that? If not, why can't you initiate the pause from Repetier?
