    rfm - RepRapFirmware FileManager [duetbackup successor]
    83
    11.5k
    • wilrikerundefined
      wilriker @T3P3Tony
      @t3p3tony said in rfm - RepRapFirmware FileManager [duetbackup successor]:
      @wilriker My vote goes for RepRapFirmware Total File Manager
      Yeah, that's what I thought of, too. 😂
      Also another good idea might be
      "[File-]Resource Manager for RepRapFirmware-based Filesystems" -> rm-rf 🤣
      (Windows user's probably won't get this one)
      Manuel
      My Tool Collection
      deckingmanundefined 1 Reply Last reply Reply Quote 5
      • OBELIKSundefined
        OBELIKS
        You are evil! I wonder if anyone would even dare to use the tool in Linux then.
        P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
        Original Prusa i3 MK3S
          deckingman @wilriker
          @wilriker said in rfm - RepRapFirmware FileManager [duetbackup successor]:
          I "googled" that and came up with "force deletion of everything in the root directory". That's the equivalent of a "nuke" button isn't it?
          wilrikerundefined 1 Reply Last reply Reply Quote 1
          • wilrikerundefined
            wilriker @OBELIKS
            @obeliks said in rfm - RepRapFirmware FileManager [duetbackup successor]:
            I was trying hard to find any reason to also add a / at the end to make it even more evil. 😂 And top class would be to get sudo prepended. sudo-rm-rf/. Perfect name for any tool on Linux. 🤣
            Manuel
            My Tool Collection
            OBELIKSundefined 1 Reply Last reply Reply Quote 0
            • wilrikerundefined
              wilriker @deckingman
              @deckingman said in rfm - RepRapFirmware FileManager [duetbackup successor]:
              More or less. There are some protections in place but if you run
              rm -rf / [note the spaces]
              either as root user (admin user with full privileges in Linux) or prepend it with sudo (which will provide a regular user with root-rights) it will do exactly that. It will erase all contents of your hard-drive and depending on the configuration also of all mounted external drives. Not as fast as a giant hammer but fast enough to have made probably unrecoverable damage until you notice.
              Manuel
              My Tool Collection
              1 Reply Last reply Reply Quote -1
              • OBELIKSundefined
                OBELIKS @wilriker
                That is a lot of nonoes in one sentence 🙂
                • wilrikerundefined
                  wilriker
                  Back to business:
                  Release v1.0.0-RC2
                  I have just release v1.0.0-RC2.
                  Changes
                  Help
                  This second release candidate has help texts for every sub-command now that are accessible via
                  rfm help <command>
                  Command Structure
                  The second major change is the structure of the parameters and options. This now resembles better the style of common CLI tools. Please see the appropriate help pages to see the format.
                  rfm backup Changes
                  Most notably also the format for rfm backup changed. This now is
                  rfm backup <common-options> [-removeLocal] [-exclude <excludepattern>]* [<local/path> [<remote/path>]]
                  where -outDir has been reduced to <local/path> with a default of the current directory if omitted and -dirToBackup is shortened to <remote/path>. The default is still 0:/sys. In case this needs to be changed the local directory also has to be provided.
                  rfm ls
                  rfm ls now accepts multiple remote paths to list.
                  Fixes
                  • panic when no sub-command is provided is replaced with default help text
                  • Uploading single files was broken
                  Manuel
                  My Tool Collection
                  • wilrikerundefined
                    wilriker
                    Release v1.0.0
                    And here comes the first official release v1.0.0.
                    Release Notes
                    This release implements all functions listed in README.md, i.e. it can
                    • download files
                    • upload files and folder
                    • backup (like duetbackup did before but slightly different and simplified syntax)
                    • list directory contents
                    • move or rename files and directories
                    • create directories
                    • delete files and directories
                    This covers all functions of the HTTP interface.
                    Also it is capable of handling multiple devices via an automatically managed configuration file.
                    As usual there are releases for Linux x86_64, Windows x86_64, MacOS X x86_64, Linux ARM and Linux ARM64.
                    Manuel
                    My Tool Collection
                    • mloidlundefined
                      mloidl
                      @wilriker
                      Thank you very much for the release. Well done. I'll test it today when i'm at home.
                      Especially i like the way you implemented the multi-device handling.
                      • wilrikerundefined
                        wilriker @mloidl
                        @mloidl Thanks! 🙂
                        Re device handling: I tried to make it as automagically as possible for the user and hope it will be useful like that.
                        But as always: all feedback is welcome. 🙂
                        Manuel
                        My Tool Collection
                        • mloidlundefined
                          mloidl
                          @wilriker Tested 1.0.0 and everything worked perfect.
                          But i have one question. Is there any reason for not creating the rmf.toml as hidden file?
                          • wilrikerundefined
                            wilriker @mloidl
                            @mloidl said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                            None in particular. At least none other than symmetry. On Linux and MacOS it's simple by just prefixing the filename with a dot. But on Windows I would have to access file system attributes to achieve that. So I dropped this idea (that I also had in the beginning). Of course I could change the name to .rfm.toml and on Windows it would just have this name without being hidden.
                            EDIT: I just researched how to create hidden files with Go on Windows and stumbled across an open bug that says opening hidden files on Windows for write access fails with an error. So even if I got it somehow hidden I could never edit it after that anymore.
                            EDIT2: The above bug does not apply since I write the new settings to a temporary file and only if that was successful I overwrite the existing one with the new one so that in case writing the file fails I do not jeopardize the current settings. Still I rather don't want to go to the length of hiding the file on Windows specifically.
                            Manuel
                            My Tool Collection
                            • Jacotheronundefined
                              Jacotheron
                              I have just tried this, and getting "Unable to save configuration to rfm.toml. The process cannot access the file because it is being used by another process."
                              This is on Windows 10, 64bit.
                              Just a suggestion, why not store the file in the same directory as the rfm file? Since it is a self-contained executable, I keep it in a folder, with the backup folders as sub-folders of the main folder. The idea is that I keep regular backups of this whole folder (with the rfm executable), and simply know that everything is there.
                              Currently I have plain text files with the commands I run (for my machines), to simply copy/paste, inside of this main folder.
                              wilrikerundefined 2 Replies Last reply Reply Quote 0
                              • wilrikerundefined
                                wilriker @Jacotheron
                                @jacotheron said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                That's not how it is supposed to be. I'll have to check if I forgot to release the file at some place. It should definitely not block itself.
                                The reason for that is that the executable might be in a directory where the user does not have write permissions, e.g. if I install it in Linux to /usr/local/bin/rfm (actually I do) so that it is accessible by every user of the system. The same goes for C:\Windows\* or C:\Program Files\*. If anyone wants to do that they should be able to. The only place where the user always has write permissions is the user's home directory.
                                Manuel
                                My Tool Collection
                                • wilrikerundefined
                                  @jacotheron I found something that might be the reason for the error message you are seeing. I uploaded a possible fix to my Dropbox. Can you please test if this issue still occurs in that version?
                                  Manuel
                                  My Tool Collection
                                    Jacotheron
                                    I have just tested the new version, and it worked - no issues found. The devices file was made and saved.
                                    • wilrikerundefined
                                      @jacotheron Thanks for confirming. I will do an official bug fix release tomorrow.
                                      Manuel
                                      My Tool Collection
                                      • wilrikerundefined
                                        wilriker
                                        Release v1.0.1
                                        Bug fix release to fix the issue where on Windows rfm.toml would not be overwritten. Get it at GitHub Releases page.
                                        Manuel
                                        My Tool Collection
                                        • gtj0undefined
                                          gtj0
                                          Hey Manuel, rfm has been working great for me but is there any chance you could automatically exclude the "System Volume Information" directory or maybe save excludes in the rfm.toml file?
                                          • wilrikerundefined
                                            wilriker @gtj0
                                            @gtj0 I'll think about something.
                                            Meanwhile you can also use rfm to just delete this stupid folder. It doesn't serve any purpose in the first place. I don't think that removable media are supposed to even have this folder.
                                            Manuel
                                            My Tool Collection
