    rfm - RepRapFirmware FileManager [duetbackup successor]
    83
    11.6k
    • gtj0undefined
      gtj0 @wilriker
      @wilriker said in rfm - RepRapFirmware FileManager [duetbackup successor]:
      @gtj0 Believe me, you don't want that. 😂 It was the working title while development. It's a PITA to type and typo guarantee. 😁
      P.S.: a friend of mine asked if I can someone get a "t" in there and some letter swapping to get rtfm. 😂
      That was going to be my next suggestion.
      • wilrikerundefined
        wilriker @gtj0
        @gtj0 said in rfm - RepRapFirmware FileManager [duetbackup successor]:
        Feel free to fork and rename it. 😂
        Manuel
        My Tool Collection
        • mloidlundefined
          mloidl
          Hi @wilriker,
          Found a small "issue".
          If rfm is called with no arguments (I know it should not called with no args), the program exit with panic because of an invalid array access (function args). Better would be to show a proper message.
          Further tests are outstanding. I had not the time to test it yet.
          Regards,
          Martin
          • wilrikerundefined
            wilriker @mloidl
            @mloidl Thanks! I fixed it in the source code and it will be in the next release.
            Probably also in the next release will be a couple of changes
            • Parameters relevant for connection (i.e. domain, port and password) can be put into a file in the user's home directory so they don't have to be provided on the command line everytime
            • Some parameters that are currently given as -parametername value will be shortened to just value but then have to follow a strict ordering in case there is more than one (this resembles more common CLI tools)
            • Adding help pages similar to the main help output for sub-commands
            Manuel
            My Tool Collection
            • mloidlundefined
              mloidl
              @wilriker thanks for the quick fix.
              Regarding config file for connection parameter:
              For users having multiple duet-based printers it would be cool to to store all these connections settings domain, port and password in a kind of connection group.
              e.g.
              [printer1]
              domain=<printer1-ip>
              port=<printer1-port>
              password=<printer1-pw>
              [printer2]
              Usage then could be rfm -device printer1 <cmd>
              I did something similar in a python-based backup script for my daily backups and found this very useful.
              What's your opinion about this?
              wilrikerundefined 1 Reply Last reply Reply Quote 1
              • wilrikerundefined
                wilriker @mloidl
                @mloidl I like that and will implement something like this. But even though I listed it first it's currently last in priority. 😉
                Manuel
                My Tool Collection
                  T3P3Tony administrators
                  @wilriker My vote goes for RepRapFirmware Total File Manager
                  wilrikerundefined 1 Reply Last reply Reply Quote 2
                  • wilrikerundefined
                    wilriker @T3P3Tony
                    @t3p3tony said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                    Yeah, that's what I thought of, too. 😂
                    Also another good idea might be
                    "[File-]Resource Manager for RepRapFirmware-based Filesystems" -> rm-rf 🤣
                    (Windows user's probably won't get this one)
                    Manuel
                    My Tool Collection
                    deckingmanundefined 1 Reply Last reply Reply Quote 5
                    • OBELIKSundefined
                      OBELIKS
                      You are evil! I wonder if anyone would even dare to use the tool in Linux then.
                      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                      Original Prusa i3 MK3S
                        deckingman @wilriker
                        I "googled" that and came up with "force deletion of everything in the root directory". That's the equivalent of a "nuke" button isn't it?
                        • wilrikerundefined
                          wilriker @OBELIKS
                          @obeliks said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                          I was trying hard to find any reason to also add a / at the end to make it even more evil. 😂 And top class would be to get sudo prepended. sudo-rm-rf/. Perfect name for any tool on Linux. 🤣
                          Manuel
                          My Tool Collection
                          OBELIKSundefined 1 Reply Last reply Reply Quote 0
                          • wilrikerundefined
                            wilriker @deckingman
                            @deckingman said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                            More or less. There are some protections in place but if you run
                            rm -rf / [note the spaces]
                            either as root user (admin user with full privileges in Linux) or prepend it with sudo (which will provide a regular user with root-rights) it will do exactly that. It will erase all contents of your hard-drive and depending on the configuration also of all mounted external drives. Not as fast as a giant hammer but fast enough to have made probably unrecoverable damage until you notice.
                            Manuel
                            My Tool Collection
                            1 Reply Last reply Reply Quote -1
                            • OBELIKSundefined
                              OBELIKS @wilriker
                              That is a lot of nonoes in one sentence 🙂
                              • wilrikerundefined
                                wilriker
                                Back to business:
                                Release v1.0.0-RC2
                                I have just release v1.0.0-RC2.
                                Changes
                                Help
                                This second release candidate has help texts for every sub-command now that are accessible via
                                rfm help <command>
                                Command Structure
                                The second major change is the structure of the parameters and options. This now resembles better the style of common CLI tools. Please see the appropriate help pages to see the format.
                                rfm backup Changes
                                Most notably also the format for rfm backup changed. This now is
                                rfm backup <common-options> [-removeLocal] [-exclude <excludepattern>]* [<local/path> [<remote/path>]]
                                where -outDir has been reduced to <local/path> with a default of the current directory if omitted and -dirToBackup is shortened to <remote/path>. The default is still 0:/sys. In case this needs to be changed the local directory also has to be provided.
                                rfm ls
                                rfm ls now accepts multiple remote paths to list.
                                Fixes
                                • panic when no sub-command is provided is replaced with default help text
                                • Uploading single files was broken
                                Manuel
                                My Tool Collection
                                • wilrikerundefined
                                  wilriker
                                  Release v1.0.0
                                  And here comes the first official release v1.0.0.
                                  Release Notes
                                  This release implements all functions listed in README.md, i.e. it can
                                  • download files
                                  • upload files and folder
                                  • backup (like duetbackup did before but slightly different and simplified syntax)
                                  • list directory contents
                                  • move or rename files and directories
                                  • create directories
                                  • delete files and directories
                                  This covers all functions of the HTTP interface.
                                  Also it is capable of handling multiple devices via an automatically managed configuration file.
                                  As usual there are releases for Linux x86_64, Windows x86_64, MacOS X x86_64, Linux ARM and Linux ARM64.
                                  Manuel
                                  My Tool Collection
                                  • mloidlundefined
                                    mloidl
                                    @wilriker
                                    Thank you very much for the release. Well done. I'll test it today when i'm at home.
                                    Especially i like the way you implemented the multi-device handling.
                                    • wilrikerundefined
                                      wilriker @mloidl
                                      @mloidl Thanks! 🙂
                                      Re device handling: I tried to make it as automagically as possible for the user and hope it will be useful like that.
                                      But as always: all feedback is welcome. 🙂
                                      Manuel
                                      My Tool Collection
                                      • mloidlundefined
                                        mloidl
                                        @wilriker Tested 1.0.0 and everything worked perfect.
                                        But i have one question. Is there any reason for not creating the rmf.toml as hidden file?
                                        • wilrikerundefined
                                          wilriker @mloidl
                                          @mloidl said in rfm - RepRapFirmware FileManager [duetbackup successor]:
                                          None in particular. At least none other than symmetry. On Linux and MacOS it's simple by just prefixing the filename with a dot. But on Windows I would have to access file system attributes to achieve that. So I dropped this idea (that I also had in the beginning). Of course I could change the name to .rfm.toml and on Windows it would just have this name without being hidden.
                                          EDIT: I just researched how to create hidden files with Go on Windows and stumbled across an open bug that says opening hidden files on Windows for write access fails with an error. So even if I got it somehow hidden I could never edit it after that anymore.
                                          EDIT2: The above bug does not apply since I write the new settings to a temporary file and only if that was successful I overwrite the existing one with the new one so that in case writing the file fails I do not jeopardize the current settings. Still I rather don't want to go to the length of hiding the file on Windows specifically.
                                          Manuel
                                          My Tool Collection
                                          • Jacotheronundefined
                                            Jacotheron
                                            I have just tried this, and getting "Unable to save configuration to rfm.toml. The process cannot access the file because it is being used by another process."
                                            This is on Windows 10, 64bit.
                                            Just a suggestion, why not store the file in the same directory as the rfm file? Since it is a self-contained executable, I keep it in a folder, with the backup folders as sub-folders of the main folder. The idea is that I keep regular backups of this whole folder (with the rfm executable), and simply know that everything is there.
                                            Currently I have plain text files with the commands I run (for my machines), to simply copy/paste, inside of this main folder.
                                            wilrikerundefined 2 Replies Last reply Reply Quote 0
