    Do i need Manual bed leveling ?2 z motors not working
    914
    • lui2004
      lui2004 last edited by lui2004
      Hi
      I have cartesian printer ( anet am8 )
      My board is The duet wifi.
      Actually i use 2 independent z motors connect to z1 and E1.
      As a Probe i use The piezo orion
      Do i need manual bed leveling to make the bed flat? If yes how to do that ?
      Thanks
      • mrehorstdmd
        mrehorstdmd last edited by mrehorstdmd
        Ideally, you want the bed to be both flat and "level". Level means in tram with the printer's axes defined by the guide rail positions. The bed should be parallel to the plane defined by the X and Y axis guide rails, and should be perpendicular to the Z axis guide rails.
        Your printer lifts the X axis with two screws driven by two motors. The motors will get out of sync when the power is cycled which will tilt the X axis relative to the Z axis. You need to have some way to resync the two. You can copy the Prusa I3 technique- after turning on power and before starting a print, send the X axis to the top of the Z axis until it bangs into the physical stops, then bring it back down to the bed surface. That will get the X axis perpendicular to the Z axis. Now you also want the bed plate to be perpendicular to Z. If you have a probe on the extruder carriage, you can use mesh compensation to probe the bed at multiple locations so the printer's firmware can tweak the Z axis as as print progresses. That can correct unflatness and tilt.
        If you don't have a probe, you will need a flat bed plate and some way to physically adjust its position so the surface is parallel to the printer's XY plane. That is usually done using leveling screws. 3 screws is best, but 4 or more can be made to work with sufficient messing around. Duet's manual bed leveling assist can make adjusting the bed position pretty quick and easy.
        • lui2004
          Ok thanks a lot
          I use piezo orion for z-probe
            Have you seen this? https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
            lui2004 1 Reply Last reply Reply Quote 0
            • lui2004
              lui2004 @Phaedrux last edited by lui2004
              @phaedrux yes i have Setup with 2 z motors I will reply my config later.
              Because its not working.
              What i want to use is 2 indepentend z motors
              And mesh compensation
              I hope this is possible ?
              Thanks a lot
                dc42 administrators @lui2004 last edited by dc42
                @lui2004 said in Do i need Manual bed leveling ?2 z motors not working:
                With 2 independent Z motors, you can only level the bed in one direction (normally in the X direction) using the motors. So you need manual screws to adjust the bed tilt in at least the Y direction.
                Yes.
                pipersw 1 Reply Last reply Reply Quote 0
                • lui2004
                  is there a how to manual screws to adjust bed tilt ?
                  bed.g
                  ; bed.g
                  ; generated by RepRapFirmware Configuration Tool v2 on Thu Apr 11 2019 17:51:12 GMT+0200 (Mitteleuropäische Sommerzeit)
                  ;M561 ; clear any bed transform
                  ;G29 ; probe the bed and enable compensation
                  G28 ; home
                  M401 ; deploy Z probe (omit if using bltouch)
                  G30 P0 X20 Y100 Z-99999 ; probe near a leadscrew, half way along Y axis
                  G30 P1 X180 Y100 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                  M402 ; retract probe (omit if using bltouch)
                  config.g
                  M550 P"AM8" ; Set machine name
                  M552 S1 ; Enable network
                  M587 S"**" P"" ; Configure access point. You can delete this line once connected
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  ; Driver
                  M584 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                  M569 P4 S0 ; Drive 4 2nd Z-motor - Normally used as Extruder 1
                  M92 X100.00 Y100.00 Z400.00 E100.00 ; Set steps per mm
                  M566 X600.00 Y600.00 Z18.00 E300.00 ; Set maximum instantaneous speed changes (mm/min)
                  M203 X6000.00 Y6000.00 Z180.00 E6000.00 ; Set maximum speeds (mm/min)
                  M201 X1500.00 Y1500.00 Z100.00 E10000.00 ; Set accelerations (mm/s^2)
                  M906 X500.00 Y500.00 Z500.00 E800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M671 X-20:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
                  M208 X-5:205 Y0:200 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                  ;M208 X-33 Y-10 Z0 S1 ; Set axis minima
                  M208 X220 Y220 Z240 S0 ; Set axis maxima
                  M574 X1 Y1 S0 ; Set active low and disabled endstops
                  M558 P8 I1 R0.4 F300 X0 Y0 Z0 ; Set Z probe type to effector and the dive height + speeds
                  G31 X0 Y0 Z-0.1 P600
                  M557 X20:200 Y20:200 S40 ; Define mesh grid
                  M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
                  M305 P0 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                  M143 H0 S130 ; Set temperature limit for heater 0 to 130C
                  M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                  M143 H1 S275 ; Set temperature limit for heater 1 to 275C
                  M563 P0 D0 H1 ; Define tool 0
                  T0 ; Select first tool
                    See https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant. It's the same process as auto levelling with multiple motors. What happens is that when the firmware sees that the number of bed support coordinates you give in M671 is not the same as the number of Z motors in M584, it tells you the manual corrections instead of adjusting the motors.
                    You don't have to use bed.g for both functions; you can put one of them in a separate macro file and then run it directly. The only thing magic about bed.g is that G32 runs it.
                    • pipersw
                      pipersw @dc42 last edited by
                      @dc42 it's the reason why I have choose the manual bed level assistant with dual Z motors.
                      The auto bed levelling can be done with 3 Z steppers or more.
                      • lui2004
                        i have now this as output
                        what did it mean
                        Manual corrections required: 0.00 turn up (0.00mm) 0.10 turn down (0.05mm) 1.36 turn up (-0.68mm)
                          Those are how many turns you need to adjust each adjusting screw. The order of the screws is the order you gave the coordinates in M671. The first adjustment is always zero, so in M671 you can choose that screw to be the least accessible one. "Up" means in the direction that raises the bed.
                          • lui2004
                            sorry for disturb you but i dont get it i cant level my bed
                            thats my bed see the picture i have 4 screws for leveling the bed
                            this is my actual config.g
                            ; Driver
                            M208 X220 Y208 Z210 S0 ; Set axis maxima
                            G31 X0 Y0 Z-0.13 P600
                            i am since months to get it work
                              I'll need more information than that:
                              • What macro, bed.g file or other procedure are you using to try to level it? Please provide that file or files.
                              • What happens when you try to level it?
                              • lui2004
                                this procedur: https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant
                                Macro i dont have it,do i need macro ?
                                bed.g
                                G28 ; home
                                G30 P0 X20 Y190 Z-99999 ; probe near an adjusting screw
                                G30 P1 X180 Y190 Z-99999 ; probe near an adjusting screw
                                G30 P2 X100 Y10 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
                                for 4 screws i dont know how to setup
                                my actual config.g
                                M587 S"*******" P"********" ; Configure access point. You can delete this line once connected
                                M569 P0 S1 ; Drive 0 goes forwards X
                                M569 P1 S1 ; Drive 1 goes forwards Y
                                M569 P2 S0 ; Drive 2 goes backwards Z
                                M569 P3 S1 ; Drive 3 goes forwards Extruder
                                ; Motor Remapping
                                M584 X0 Y1 Z2:4 E3 ; two Z motors connected to driver outputs Z and E1
                                M558 P5 I1 R0.4 F300 X0 Y0 Z0
                                M208 X215 Y200 Z195 S0 ; Set axis maxima
                                M671 X-33:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
                                M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
                                ;G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                                G31 X0 Y0 Z-0.1 P100
                                this is my output after G32 manual leveling:
                                14:21:03G32
                                Error: Number of calibration factors (3) not equal to number of leadscrews (2)
                                thanks a lot for help
                                • lui2004
                                  after i make this changes
                                  18:03:19G32
                                  Manual corrections required: 0.00 turn up (0.00mm) 0.21 turn up (-0.11mm) 0.05 turn down (0.03mm) 0.34 turn down (0.17mm)
                                  i run G32 again and then come again
                                  18:09:48G32
                                  Manual corrections required: 0.00 turn up (0.00mm) 0.37 turn up (-0.19mm) 0.27 turn down (0.14mm) 0.30 turn down (0.15mm)
                                  thats no end everytime i must turn uo or down
                                  it is normal ??
                                    If the corrections it asks for diverge, that usually means you are turning the screws the wrong way, or turning the wrong screws. The corrections are listed in the same order as you list the screw coordinates in the M671 command.
                                    That said, a bed on 4 levelling screws is over-constrained so it may not react to adjustments the way that the firmware assumes.
                                    • lui2004
                                      Hi
                                      now my bed is flat 😉 thanks a lot
                                      so now i want to use and configurate the dual Motors for Z with using Z-Probe ( Piezo Orion ) and Mesh bed compensation
                                      my Config now:
                                      M587 S"" P"" ; Configure access point. You can delete this line once connected
                                      ; Motor Remapping
                                      M558 P5 I1 R0.4 F250 X0 Y0 Z0 T2000 ; Piezo Z-Probe für Z-Achse
                                      M208 X220 Y220 Z195 S0 ; Set axis maxima
                                      ;M671 X6:6:210:219 Y10:215:215:10 P0.5 ; für manual bed levelling
                                      ;M671 X-20:220 Y0:0 S0.5 ; leadscrews at left and right of X axis
                                      my bed.g
                                      ; bed.g
                                      thanks in advance for helping me
                                      • lui2004
                                        think i have it ,is that so ok ?
                                        RepRapFirmware height map file v2 generated at 2019-03-14 08:52, mean error -0.012, deviation 0.038
                                        xmin,xmax,ymin,ymax,radius,xspacing,yspacing,xnum,ynum
                                        20.00,200.00,20.00,200.00,-1.00,40.00,40.00,5,5
                                        -0.025, -0.005, -0.010, -0.015, 0.060
                                        -0.023, -0.010, 0.003, -0.030, 0.048
                                        -0.017, -0.023, -0.100, -0.012, 0.043
                                        -0.065, -0.040, -0.105, -0.005, 0.015
                                        0.025, 0.020, 0.000, -0.017, 0.000
