    Solved Y homing off of the board
    • BearcatTD
      BearcatTD last edited by
      I am still working on getting by D2 wifi / Ender 3 up and running. I was able to get a copy of the Ender 3 setup/config files for the board and they uploaded fine. The only thing I have changed in the config.g file is the X and Y offsets for the BLTouch. So when i home X, it goes all the way over to the left side (great), Y though homes off of the front edge of the build plate. I am assuming that it should home a centimeter or two inside of the front edge of the build plate. If someone had any thoughts, I would be forever grateful!
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
        Phaedrux Moderator @BearcatTD last edited by
        @bearcattd said in Y homing off of the board:
        Can you show a picture of what you mean?
        Is it that the nozzle is off the bed when it's homed?
        BearcatTD 1 Reply Last reply Reply Quote 0
        • BearcatTD
          BearcatTD @Phaedrux last edited by
          @phaedrux
          Thanks! I actually just cracked the code (in my pea brain) for setting the minima settings. I homes just right now!
