    Hot end / thermistor problem
    709
    • BearcatTD
      BearcatTD last edited by
      So my extruder is reading very high but it is not hot:
      When I unplug the therm, it goes to 2000C. The therm is seated well into the heater block. When I changed the connector might have gotten the wires backwards...would that matter? The therms are NTC 100K ohm listed as compatible with Ender 3. Also, The configuration files I am using were created by someone who setup the E3 and D2W so that should be right.
      Thanks for all of the help, I'm going to be printing in no time!
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      • Veti
        Veti last edited by
        if you did not change the thermistor its the same as the bed.
        • BearcatTD
          I replaced it when I got the new micro swiss hotend. I put a continuity tester on both the heater element and the therm and they seemed fine that way. I wish I could somehow test this heater to see if that is the problem.
          • Veti
            Veti last edited by
            post your thermistor settings.
            what thermistor is it? did you get a temperature table with it ?
            • BearcatTD
              Here are the settings from config.g
              • BearcatTD
                I actually just took the thermistor out of the heater block and it immediately went down to "Normal" range...24ishC. When I put it back into the block and started to tighten the retaining screw, it shot back up to 9000c . Methinks there might be a short.
                or not. LOL.
                I appreciate your time Veti!
                • BearcatTD
                  These are what I bought:
                  https://www.amazon.com/gp/product/B07BBKWZ5K/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
                  Veti 1 Reply Last reply Reply Quote 0
                  • Veti
                    Veti last edited by
                    can you measure the resistance of the thermistor with a voltmeter?
                    my guess is you somehow shorted the thermistor cables and the resistance is very low.
                    • Veti
                      Veti @BearcatTD last edited by
                      @bearcattd said in Hot end / thermistor problem:
                      the problem with that is that they dont tell you what the thermistor actually is.
                      without a supplied resistance table the temperature can easily be off by 40 degrees at 200 degrees.
                      BearcatTD 1 Reply Last reply Reply Quote 0
                      • BearcatTD
                        101.2 on the voltmeter
                        • Veti
                          Veti last edited by
                          thats broken. it should read around 100k at room temperature.
                          • BearcatTD
                            BearcatTD @Veti last edited by
                            @veti Could I find a resistance table for 100k ohm thermistors and use that? Would it look like this:
                            http://www.bapihvac.com/wp-content/uploads/2010/11/Thermistor_100K.pdf
                            • BearcatTD
                              @veti FYI I had the voltmeter selector at 200K on the resistance side.
                              • Veti
                                Veti last edited by
                                so it was 100k.
                                can you swap the hotend and bed heaters around and report the temperatures?
                                • nhof
                                  nhof last edited by
                                  If it indicates 9000 degrees then it's probably a short rather than thermistor values being off. NTC means resistance goes down as temps go up. A short is essentially 0 resistance so it will read an unnaturally high value. Check the leads coming out of the thermistor as those are the usual suspects.
                                  You can generate your own beta values using a table and a calculator like so: https://www.ametherm.com/thermistor/ntc-thermistor-beta
                                  • Veti
                                    @bearcattd
                                    if thats the table for your thermistor then yes. if its a random one you found, prob not.
                                      dc42 administrators @BearcatTD last edited by
                                      I agree, there is a short. Is it a cartridge thermistor or a bead thermistor?
                                      • BearcatTD
                                        BearcatTD @dc42 last edited by
                                        It is a bead therm. I replaced the one that was bad and wired in the second one. the weird thing is, is that if I tighten down the retaining screw the temp goes crazy. so right now i have it loosely tightened (if that makes any sense) and things are working great!!
                                        • Veti
                                          Veti last edited by Veti
                                          put some nylon spacer in between.
                                            dc42 administrators @Veti last edited by
                                            @veti said in Hot end / thermistor problem:
                                            I doubt that Nylon will withstand the temperature of the heater block. I suggest some new glass fibre sleeving. Or change the heater block for one that accepts a cartridge thermistor.
