    Uploading code files from Simplify3D to DuetWiFi using scripts?
    3.0k
    • briangilbertundefined
      briangilbert
      Was talking with a friend earlier who is using the "Post Processing" feature of Simplify3D to upload his saved gcode files to his Octoprint server, wondering if there is any way I could use this feature to upload gcode files to my DuetWiFi?
      In the instance of my friend he is uploading the files using curl with an API key to octoprint:
      [[language]]
      curl -k -H "X-Api-Key: [his api key]" -F "select=false" -F "print=false" -F "file=@[output_filepath]" "http://octopi.local/api/files/local" && rm "@{output_filepath}"
      I'm sure I've seen somewhere in the past about ways to upload files to the duet, but I can't find it now?
      Co-creator of the Zesty Nimble direct drive extruder
        See https://www.duet3d.com/forum/thread.php?pid=9032#p9032.
        • T3P3Tonyundefined
          T3P3Tony administrators
          The DWC readme lists all the rr_…. commands:
          https://github.com/chrishamm/DuetWebControl/blob/master/README.md
          It's a good place to start.
          www.duet3d.com
            briangilbert
            Thanks gents!
            • Martin1454undefined
              Martin1454
              Did anybody ever figure out how to upload from simplify3d directly to duet?
                Yes, see https://forum.duet3d.com/topic/867/duet-wifi-s3d.
