    SOLVED BL Touch Flashing
    778
    • WILLYD3113
      WILLYD3113 last edited by
      So I've plugged in my BL to the pin 8 slot 0_1556600240531_Screen Shot 2019-04-29 at 11.56.44 PM.png except instead of pin 31 I've plugged the wire into pin 8(Heater 3). I ran through the RRF Config using default settings. I also severed the pad switching the BL touch from 5v to 3.3v. When I turn on the Duet the BL clicks in and out and then starts to flash. The Duet interface throws up "G29: No valid grid defined for bed probing" and "Z probe already triggered at start of probing move". The probe doesn't respond to any command and the interface on the reads 1000.
      • Veti
        Veti last edited by
        https://docs.wixstatic.com/ugd/f5a1c8_9a3c29b6f5f2417096922091eb9d8702.pdf
        activate self test. if it fails do an alarm release.
        adjust the top grub screw.
        repeat.
        post your config because you might not have defined the grid.
        • WILLYD3113
          Tighten Grub or Loosen Grub?
          ; generated by RepRapFirmware Configuration Tool v2 on Mon Apr 29 2019 23:17:44 GMT-0500 (Central Daylight Time)
          M550 P"PussySlayer" ; Set machine name
          M552 S1 ; Enable network
          M587 S"11818e" P"endless.955.drift" ; Configure access point. You can delete this line once connected
          M586 P0 S1 ; Enable HTTP
          M586 P1 S0 ; Disable FTP
          M586 P2 S0 ; Disable Telnet
          M569 P0 S0 ; Drive 0 goes backwards
          M350 X256 Y256 Z256 E256 I0 ; Configure microstepping without interpolation
          M92 X1280.00 Y1280.00 Z6400.00 E6790.61 ; Set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
          M906 X1200.00 Y1200.00 Z1200.00 E1600.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X220 Y220 Z220 S0 ; Set axis maxima
          M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
          M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
          M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
          M557 X15:6 Y15:195 S20 ; Define mesh grid
          M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit
          M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
          M106 P0 S1 I0 F500 H T10 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P1 S0 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M563 P0 D0 H1 ; Define tool 0
          ; Custom settings
          M307 H3 A-1 C-1 D-1
          M558 P9 H5 F100 T2000
          G31 X0 Y0 Z0 P25
          • Veti
            Veti last edited by
            @willyd3113 said in BL Touch Flashing:
            A 3d printer?
            connected
            You might want to change that now.
            Normaly X16 with interpolation is what you want.
            15 > 6 So this is incorrect.
            You have to try in both directions and see which one works. Start with tightening.
            • WILLYD3113
              How Should I modify the config file, and I tightened and loosened the screw but saw no effect(what am I looking for?)
              • WILLYD3113
                The BL doesn't respond M401 or M402 also and the flashing doesn't stop.
                • Veti
                  Veti last edited by
                  From the linked document you can see the command to use is M280 with the parameters for your connection and the command to execute.
                  Also for M557 you need to define the area of your bed where the probing is allowed.
                  this depends on the location of your probe etc.
                  You could also use the configurator which calculates these things for you.
                  configurator.reprapfirmware.org
                  • WILLYD3113
                    The BL touch is now solid red and will test when It turns on but I cannot get it to deploy or retract.
                    • Veti
                      Veti last edited by
                      if you cant get it working by adjusting the grub screw you will have to go in deeper.
                      see https://www.youtube.com/watch?v=wq5QmN-MIJA
                      • WILLYD3113
                        New Config:
                        ; generated by RepRapFirmware Configuration Tool v2 on Tue Apr 30 2019 09:39:22 GMT-0500 (Central Daylight Time)
                        M557 X10:210 Y10:210 S25 ; Define mesh grid
                        ; Custom settings
                        M307 H3 A-1 C-1 D-1
                        G31 X0 Y0 Z0 P25
                        Deploy probe:
                        ; deployprobe.g
                        ; called to deploy a physical Z probe
                        M280 P3 S10
                        Retract Probe:
                        ; retractprobe.g
                        ; called to retract a physical Z probe
                        M280 P3 S90
                        • WILLYD3113
                          The interface reads 0 and the BL is solid red(turns off when I pull out the probe) and it does a few test clicks when I turn on the printer but any attempt to deploy or retract goes through the console fine but the BL doesn't do anything.
                            Deploy probe:
                            ; deployprobe.g
                            M280 P3 S10
                            Retract Probe:
                            ; retractprobe.g
                            M280 P3 S90
                            See https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Software_setup_Duet_2_WiFi_Ethernet. You need to add the i1 parameter to your M280 commands. Then test M401 and M402 again.
                            • WILLYD3113
                              All is working! Thanks Guys!
                              • WILLYD3113
                                Hey Guys I'm finding a weird issue with the probe. Ive set the probe as my Z Endstop now and I've configured the offset countless times but it doesn't seem to change where the printer thinks zero is. I will set the offset to 0, manually configure where Zero is G92, and run G30 S-1. The printer after restarting then homes when I command it to then goes to z = 5.0 but its really more like 8- 10 and I have no clue why. I've read the BeTrue article and can't figure it out.
                                Here's my Config:
                                ; generated by RepRapFirmware Configuration Tool v2 on Mon May 06 2019 22:38:59 GMT-0500 (Central Daylight Time)
                                M550 P"Mods Suck" ; Set machine name
                                M566 X1800.00 Y1800.00 Z24.00 E240.00 ; Set maximum instantaneous speed changes (mm/min)
                                M203 X12000.00 Y12000.00 Z360.00 E2400.00 ; Set maximum speeds (mm/min)
                                M201 X1000.00 Y1000.00 Z2040.00 E500.00 ; Set accelerations (mm/s^2)
                                M906 X1200.00 Y1200.00 Z1200.00 E1700.00 I0 ; Set motor currents (mA) and motor idle factor in per cent
                                M574 X1 Y1 S0 ; Set active low and disabled endstops
                                M558 P9 H10 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
                                G31 P25 X15 Y20 Z3.4 ; Set Z probe trigger value, offset and trigger height
                                M557 X10:200 Y10:200 S30 ; Define mesh grid
                                ; Custom settings
                                M307 H3 A-1 C-1 D-1
                                G31 X0 Y0 Z0 P25
                                  dc42 administrators @WILLYD3113 last edited by
                                  G30 S-1 measures the trigger height, but doesn't do anything with it apart form report it. See https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height.
                                  • WILLYD3113
                                    After Probing with G30 S-1 I take that height and plug it into the G31 line of config file, forgot to mention.
                                    chriskimbr 1 Reply Last reply Reply Quote 0
                                    • chriskimbr
                                      chriskimbr @WILLYD3113 last edited by
                                      @willyd3113 Ive done this countless times and it doesn't seem to effect where the bed/nozzle is. Mine still prints too far off the bed.
                                      • WILLYD3113
                                        WILLYD3113 last edited by WILLYD3113
                                        Is it like 4 to 5 mm away from bed even at z=0? @chriskimbr
