    Stepper motors
    513
    • Melfesto
      Melfesto last edited by
      Hey, all got a question about stepper motors. Is there such a thing as best for precision. Like If you were to build a printer and money wasn't a problem what would be the best stepper motor you would buy and why?
      fcwilt JoergS5 2 Replies Last reply Reply Quote 1
        I suppose if money was not a question I might try something more exotic like a servo or some kind of closed loop system, but honestly for any printer I'm likely to build I'd probably stick with these:
        https://www.omc-stepperonline.com/nema-17-bipolar-0-9deg-46ncm-65-1oz-in-2a-2-8v-42x42x48mm-4-wires-full-d-cut-shaft.html
        They pair pretty much perfectly with the DuetWifi. There's also a 1.8 degree version if you need a bit more torque.
        gtj0 1 Reply Last reply Reply Quote 2
        • fcwilt
          fcwilt @Melfesto last edited by
          @melfesto
          I have purchased a couple of dozen steppers from the referenced site (stepperonline) and have always been very happy with the products.
          • mrehorstdmd
            mrehorstdmd last edited by
            High precision/accuracy industrial machines often use 5 phase stepper motors that are built to deliver 500 or 1000 steps per rev. Combining those with microstepping drivers can make for very fine position control.
            Run this search term in ebay:
            5 phase stepper -2 phase -two phase -four phase -4 phase -3 phase -three phase
            and you'll see a lot of listings for 5 phase motors and drivers. The smaller motors tend to be rated for either 750 mA or 1.4A and for the same physical size, the torque is usually lower than 2 phase motors. Some motors are wound for pentagon connections and others for star connections. I believe the driver has to match the motor configuration, so you have to shop carefully to ensure compatibility.
            • gtj0
              gtj0 @Phaedrux last edited by
              @phaedrux said in Stepper motors:
              Those are the ones I use as well. Got 7 of them for the movement axes but use a 1.8 deg one for the extruder.
              • JoergS5
                JoergS5 @Melfesto last edited by JoergS5
                @melfesto If money is not a problem, I would use linear actuators like http://www.airoil.com/products/view/511/ultra-high-speed-magnetic-linear-actuator.html
                There was a DIY project on reprap https://reprap.org/forum/read.php?160,813817,page=1, but unfortunately it died.
                • Melfesto
                  what do you all think of something like this.
                  https://www.linengineering.com/products/stepper-motors/z417-series/z417-17-02/#fndtn-standard_motor
                  gtj0 fcwilt 2 Replies Last reply Reply Quote 0
                  • gtj0
                    gtj0 @Melfesto last edited by
                    @melfesto They seem expensive for the torque provided.
                    • fcwilt
                      @melfesto said in Stepper motors:
                      I'm would imagine they are good but I only pay more when I find I must.
                      The ones I referenced have worked fine for me (and others).
