    fan 0 and fan 2 operation by slicer simplify3d help!
    342
    • fr4nc3sco
      fr4nc3sco last edited by
      sorry for my short english, is there a way to make fan0 and fan2 work as the only door seen by the various slicers? or is the only solution to use fan 0?
      • deckingman
        deckingman @fr4nc3sco last edited by
        @fr4nc3sco said in fan 0 and fan 2 operation by slicer simplify3d help!:
        You can use M563 to map one or more fans to tools https://duet3d.dozuki.com/Wiki/Gcode#Section_M563_Define_or_remove_a_tool
        So to use both fans 0 and 2 as part cooling fans, use M563 Pn F0:2 (where n is the tool number which will be 0 if you only have one tool).
        • fr4nc3sco
          thank you so much I solved it to perfection
          one last question with this fan configuration I was able to make them start from 2% to 100% only that they are not constant but a little on-off is a way to make them more constant without penalizing the percentage? increasing the F I get a worsening for the starting percentage
          ; fans
          M106 P0 S0 I0 F0.18 H-1; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
          M106 P1 T45 H1
          M106 P2 S0 I0 F0.18 H-1; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
          deckingman dc42 2 Replies Last reply Reply Quote 0
          • deckingman
            @fr4nc3sco Are you getting the F and S parameters confused?
            The F parameter is the frequency in Hz and the default is 250 Hz so 0.18 is very low.
            The "S" parameter is the PWM value (mark-space ratio) which can be defined as either 0-255 or 0-1.0.
            So M106 S0.02 F250 would run the fan using 2% PWM at a frequency of 250 Hz and M106 S1.0 F250 would run the fan using 100% PWM also at a frequency of 250 Hz but as the fan would be permanently on, the frequency is irrelevant in this particular case.
            fr4nc3sco 1 Reply Last reply Reply Quote 0
              dc42 administrators @fr4nc3sco last edited by
              @fr4nc3sco, you might want to check out the B parameter too, for more reliable startup at low speeds.
              • fr4nc3sco
                fr4nc3sco @deckingman last edited by
                @deckingman said in fan 0 and fan 2 operation by slicer simplify3d help!:
                tested this configuration
                M106 P0 S0 I0 F250 H-1
                I attach video to see what it really does ...
                https://vimeo.com/user98280453/review/334974393/8be5172058
                • deckingman
                  @fr4nc3sco That link doesn't seem to work. Can you describe what happens in words?
                  Scachi 1 Reply Last reply Reply Quote 0
                  • Scachi
                    Scachi @deckingman last edited by
                    @deckingman I think this is his video: https://vimeo.com/334974393
                    • fr4nc3sco
                      the video is the one that in practice only works 100% under no part
                      • fr4nc3sco
                        hello,
                        no one can help me?
                        • deckingman
                          deckingman @fr4nc3sco last edited by deckingman
                          @fr4nc3sco Well, not all fans play nicely with PWM and it sounds like yours might be that type. You said that you had tried a frequency of 0.18Hz which is really too low. That's why I thought you might have been confusing the F and S parameters because 0.18 would be a valid number for S (although many slicers use the 0 to 255 range rather than the 0 to 1.0 range).
                          I have some very small part cooling fans that I've managed to get working by using a PWM frequency of 10 Hz. Try that, or a frequency close to it.
