    New firmware 2.03RC1 available
    Firmware installation
    8
    12
    1309
      I've just published new firmware at https://github.com/dc42/RepRapFirmware/releases/tag/2.03RC1. This is the candidate for release 2.03, which I intend to be the last release in the 2.0 firmware series. All future work except for important bug fixes will target RepRapFirmware 3.0.
      I have also included a 1.24RC1 release for the Duet 06/085.
      The upgrade notes and change list are at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md.
      Please submit feedback (whether positive or negative) on the changes in this release in this thread.
      Stephen6309 1 Reply Last reply Reply Quote 3
      • Stephen6309
        Stephen6309 @dc42 last edited by
        @dc42 Nope, it's not fixed. Fixed (hopefully - not tested!) issue with Fan 1 on Duet085 in 2.03 beta releases
        • A Former User
          A Former User last edited by
          Prints can now be baby stepped, paused and cancelled while they are waiting for temperatures to be reached
          Nice, was going to make a suggestion on the baby stepping - nothing better than getting beaten to it in this case:)
          • Cata
            Cata last edited by
            No phase disconect reports on Duet Maestro. Thanks
            • mudcruzr
              mudcruzr last edited by
              I've updated a couple of the 12864 menu files to cope with the changes in 2.03RC1
              As usual they are in https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files
              2 Files required updates to cope with the changes in 2.03RC1
              The new files are main_for_203RC1 and heat_for_203RC1
              Upload the 2 new files, rename the existing heat and main to something like heat_backup and main_backup then rename the 2 new files to heat and main respectively.
              Note these files are ONLY for using with 2.03RC1
                dc42 administrators @Stephen6309 last edited by dc42
                @stephen6309 said in New firmware 2.03RC1 available:
                I've just updated the RepRapFirmware.bin file in this release to version 1.24RC1+1 which fixes that problem.
                Stephen6309 1 Reply Last reply Reply Quote 0
                • Stephen6309
                  @dc42 It's fixed. 🙂
                  • gavatron3000
                    gavatron3000 last edited by
                    unfortunately theres no change in the behaviour of M291 during a tool change, the message comes up at the instance the m291 is called but the tool change will continue until its finished
                    • kazolar
                      kazolar last edited by kazolar
                      deleting comment -- I was using the wrong RRFLibraries, compiles fine now -- will try it later to see if i2c is improved
                      • hestiahuang
                        hestiahuang last edited by
                        just want to confirm, the code, no issue
                          dc42 administrators @hestiahuang last edited by
                          @hestiahuang said in New firmware 2.03RC1 available:
                          Thanks!
                            dc42 administrators @dc42 last edited by
                            I've just released 2.03RC2 at https://github.com/dc42/RepRapFirmware/releases/tag/2.03RC2 so I will lock this thread.
