Control high power LEDs by relay
  • Hi,
    I'm replacing my Rumba with Duet Wifi and a Duex5 in my BigBox. I have been controlling LED strips pulling 2-3A at 12V through by GPIO on RPI. The relay module can handle 3.3 - 5V signal and need 5V power.
    • Is it possible to use GPIO pins to control LEDs on Duet Wifi software vise?
    • What pins would be recommended to use for signal 3.3V/5V?
    • Recommended pin for permanent 5V power to relay board?
    Regards
    Stian
  • You could bypass the relay board altogether and use the extra heaters on the Duex5 to control the strips.
  • @elmoret:
    How much load can the heater outputs take?
    In the docs all I can find is at least 12V 25W or 24V 50W so 2A should be feasible.
    The heater outputs are good for at least 5A.
  • Or as I just discovered the servo outputs are 5V signal and 5V power. They should work perfectly.
  • @dc42:
    Nice, then I can get rid of the relay 🙂
