    Access to other files on SD card
    • BearcatTDundefined
      BearcatTD
      As far as I can tell, the only files we have access to are the config files and our printer files. When I do a bed level, the printer creates a file heightmap.csv (or something like that. Is there a way to access that file without removing it from the printer and putting in my laptop?
      Thanks,
      Pat
      Professor of Theatre, Lighting and Scenic Designer, Northwest Missouri State University
      Hardware: Ender 3 with a Duet 2 wifi, CR-10 V2 with a Duet3
      Danalundefined 1 Reply Last reply Reply Quote 0
        Heightmap.csv will show up in the sys folder. you can right click and download any of the files from the DWC. You can download all of the files in a folder as a zip file if you use the check box to mark all the files you want to download.
        • Danalundefined
          Danal @BearcatTD
          @bearcattd said in Access to other files on SD card:
          file heightmap.csv. Is there a way to access that file without removing it from the printer and putting in my laptop?
          To view the heightmap (not the file, the actual graphic of the content of the file):
          To download any file in the /sys directory:
          That example shows right clicking a single file. As @Phaedrux mentioned, you can also check multiple files, and download a zip.
