    Duet3D PCB delta printer effector sneak preview
    53
    367
    77.5k
    • botundefined
      bot
      This is music to my ears! Thank you for collaborating with e3d on this.
      *not actually a robot
      • Jimborrundefined
        Jimborr
        @T3P3Tony:
        @Jimborr:
        Any chance you or T3P3 will make custom length Haydn Huntley magnetic arms and sell it all as a kit with the PCB?
        We will certainly explore collaborating with Haydn on purchasing his mag arms in larger volumes to bundle with the effectors, once we get closer to a production version. That makes sense for people in the UK/Europe at least (it makes less sense to import them from the US just to ship them back).
        I would buy it that's for sure - located in EU/SWE. I have a copy of David's delta and would love the same setup, incl
        rails instead of wheels.
          @Jimborr:
          I've just published the build details at https://miscsolutions.wordpress.com/2017/03/22/time-to-rebuild-my-large-kossel/. I haven't finished the commissioning instructions yet, and the section on the effector and hot end is a bit sketchy because we and E3D are making some design changes.
          • T3P3Tonyundefined
            T3P3Tony administrators
            Nice blog post David! (I like the Escher lizards in the photos as well :P)
            www.duet3d.com
            • haleypundefined
              haleyp
              Hi, really cool development here. I'm just wondering, can the circuit board go at the heat break, so that the hot end and the cold end are on either sides of the circuit board? This would bring the nozzle closer to the effector plane and also help prevent the cold end cooling fan from cooling the hot end.
                I looked at that, but there isn't enough room between the heatsink and the heater block to fit he PCB in without the heater block being very close to the PCB. However the next version will put the hot end about 10mm higher because there won't need to be a collar below the heatsink.
                  Another photo, this time with the wiring in place
                  The prototypes are working well. We're making a few design changes to further improve sensitivity and noise immunity, also E3D is changing the grooveless hot end mount. So some new PCBs are on order.
                  • Immutefundefined
                    Immutef
                    Really looking forward to a release! Love the idea to use a PCB directly as effector!
                    • Russ Griesundefined
                      Russ Gries
                      you know, for some reason i was thinking that you could put FSR with on the PCB. and if the PCB "flexes" it would be in its self the Z probe…
                      They make force devices like that, you could mound in between each 3 points in a direction going to the hotend.
                      Just some random thoughts 🙂
                      ~Russ
                      One Day At A Time…
                      My Main Research Page:
                      http://rwgresearch.com/open-projects/3d-printing-research/
                      • terabyteundefined
                        terabyte
                        David, this is awesome! Although I like my IR sensor, it has its limitations, and the contact solution like this would be great. However, I have a question. How this will accommodate existing mounting for arms? It does not look like the PCB has a lot of space to mount something like Rostock ball-cup attachments or u-joints, unless they are mounted on posts. The problem with switching arms is that it would also require switching (or adjusting) attachements on the carriage side, or possibly changing carriages. While this may be ideal for some people (as you have noted you have eliminated the tilt buy changing the arms/carriages), it does add to the total cost of the solution, as well as the time involved.
                        As for the weight of the PCB vs Al effector, I wouldn't think that a PCB is necessary lighter than Al plate such as http://713maker.com/effector.html or a similar from http://tricklaser.com. The 713 effector (without a mount) weighs in at about 10g and Rostock ball-cup plastic effector (without a mount) about 13g. Sure, there is an added weight of the mount, and PCB-only plate might be lighter, but I do not think it is really that important here, as the weight of E3D extruder is about 50-80g or even more for some models.
                        Regardless of the weights, I would propose separating the effector from the mount part. This way, people will be still able to use their current effectors/arms/carriages/rails without modification. I understand that it will require additional work for you, but it would save a lot of work and money for those who are not ready to buy the whole set. -Thanks.
                          If you look at the first post in this thread, you will see that we have matching PCB carriage adapters. We will be selling the effector + carriage adapters as a set. This ensures that the arm spacing is the same at the carriages as it is at the effector to a high degree of precision, which eliminates one of the sources of effector tilt and calibration difficulties. Using a separate mount would lose that benefit. But of course you could attach your own mounting system to the effector in place of the ball studs if you didn't want to use magnetic arms.
                          • terabyteundefined
                            terabyte
                            Thanks for the reply David. I have seen that matching sets will be available, but that brings me back to the point of the increased cost (effector+arms+carriages+new E3D = $$$). Obviously, precision of the build is not easy to achieve, but not everyone will want to get the complete set. While it is possible to attach the PCB to an existing effector, this will probably involve some drilling/cutting which is more time and a room for error. I am just worried that there won't be enough space, dimensions would not match, or I could not drill straight. I believe that having more mounting options out of the box could be good for sales too. I am sure that your design will be great, but my choice will be trying the effector first.
                              The carriage adapters are just pieces of PCB, so they cost very little and it wouldn't make sense to offer the effector without them. They are designed to fit existing carriages with M3 fixing centres on a 20mm square. As for dimensions not matching, you are always going to have that issue if you want to retrofit a commercially-made effector to an existing design without fitting new rods as well.
                              If you already have an E3Dv6 then you shouldn't need a complete new hot end, just the new heatsink.
                              • fcwiltundefined
                                fcwilt
                                Aren't there advantages to having the nozzle as close to the effector plate as possible?
                                I've seen folks use standoffs on the effector plate to get the mount for the hot end assembly up higher.
                                Not a good idea?
                                  Mounting the hot end higher gives you a little extra build height. Also if you don't manage to eliminate effector tilt then it may reduce the resulting print distortion.
                                  We considered whether we could mount the bottom of the heatsink to the effector instead of the top, but we couldn't find a practical arrangement.
                                  The PCBs for the next version of the effector have arrived. This version has the top of the heatsink going through the effector, so the distance from the nozzle to the effector is reduced somewhat.
                                  • Dougal1957undefined
                                    Dougal1957
                                    David
                                    Could you share a drawing of the top of the heatsink and mounting to the effector I need to get Lykle on board to design an adaptor so that a Nimble extruder can be mounted to it?
                                    Doug
                                    • jannisjundefined
                                      jannisj
                                      Hey guys!
                                      Any updates on this?
                                      I'm just waiting to order 🙂
                                      -Jannis
                                      • abbott_mundefined
                                        abbott_m
                                        Quite interested in this as well. Wound up machining a similar setup out of AL but without the electronics. Works rather nicely with the rod ends absolutely parallel.
                                          I've published the preliminary fitting instructions at https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer. I also added some photos, including this one:
                                          This is our second prototype. The electronics is working even better than in the first prototype and we have been able to increase the sensitivity, so that the probing force is lower.
                                          The combination of magnetic joints and two connectors (one for signal connections and the other for power connections) makes it very easy to remove the effector - the hardest part is removing the Bowden tube and filament from the hot end.
                                          The main thing we need now is for E3D to finalise their new heatsink design. We may also make the effector a little larger to make the underside less cramped, which would increase the rod separation from the current 55mm to 60 or 65mm. Do any potential users have strong views on this?
                                          • abbott_mundefined
                                            abbott_m
                                            I machined mine at 55 and about the only thing I noted is having to be a bit more careful about anything mounted to the vertical tower and staying clear of the mounts (how. Do I know this,..it wasn't pretty). Larger seems like a good notion though.
                                            Think a larger size would be useful if this got extended to two hot ends in the future.
