    Duet3D PCB delta printer effector sneak preview
    53
    367
    77.5k
      If you look at the first post in this thread, you will see that we have matching PCB carriage adapters. We will be selling the effector + carriage adapters as a set. This ensures that the arm spacing is the same at the carriages as it is at the effector to a high degree of precision, which eliminates one of the sources of effector tilt and calibration difficulties. Using a separate mount would lose that benefit. But of course you could attach your own mounting system to the effector in place of the ball studs if you didn't want to use magnetic arms.
      • terabyteundefined
        terabyte
        Thanks for the reply David. I have seen that matching sets will be available, but that brings me back to the point of the increased cost (effector+arms+carriages+new E3D = $$$). Obviously, precision of the build is not easy to achieve, but not everyone will want to get the complete set. While it is possible to attach the PCB to an existing effector, this will probably involve some drilling/cutting which is more time and a room for error. I am just worried that there won't be enough space, dimensions would not match, or I could not drill straight. I believe that having more mounting options out of the box could be good for sales too. I am sure that your design will be great, but my choice will be trying the effector first.
          The carriage adapters are just pieces of PCB, so they cost very little and it wouldn't make sense to offer the effector without them. They are designed to fit existing carriages with M3 fixing centres on a 20mm square. As for dimensions not matching, you are always going to have that issue if you want to retrofit a commercially-made effector to an existing design without fitting new rods as well.
          If you already have an E3Dv6 then you shouldn't need a complete new hot end, just the new heatsink.
          • fcwiltundefined
            fcwilt
            Aren't there advantages to having the nozzle as close to the effector plate as possible?
            I've seen folks use standoffs on the effector plate to get the mount for the hot end assembly up higher.
            Not a good idea?
              Mounting the hot end higher gives you a little extra build height. Also if you don't manage to eliminate effector tilt then it may reduce the resulting print distortion.
              We considered whether we could mount the bottom of the heatsink to the effector instead of the top, but we couldn't find a practical arrangement.
              The PCBs for the next version of the effector have arrived. This version has the top of the heatsink going through the effector, so the distance from the nozzle to the effector is reduced somewhat.
              • Dougal1957undefined
                Dougal1957
                David
                Could you share a drawing of the top of the heatsink and mounting to the effector I need to get Lykle on board to design an adaptor so that a Nimble extruder can be mounted to it?
                Doug
                • jannisjundefined
                  jannisj
                  Hey guys!
                  Any updates on this?
                  I'm just waiting to order πŸ™‚
                  -Jannis
                  • abbott_mundefined
                    abbott_m
                    Quite interested in this as well. Wound up machining a similar setup out of AL but without the electronics. Works rather nicely with the rod ends absolutely parallel.
                      I've published the preliminary fitting instructions at https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer. I also added some photos, including this one:
                      This is our second prototype. The electronics is working even better than in the first prototype and we have been able to increase the sensitivity, so that the probing force is lower.
                      The combination of magnetic joints and two connectors (one for signal connections and the other for power connections) makes it very easy to remove the effector - the hardest part is removing the Bowden tube and filament from the hot end.
                      The main thing we need now is for E3D to finalise their new heatsink design. We may also make the effector a little larger to make the underside less cramped, which would increase the rod separation from the current 55mm to 60 or 65mm. Do any potential users have strong views on this?
                      • abbott_mundefined
                        abbott_m
                        I machined mine at 55 and about the only thing I noted is having to be a bit more careful about anything mounted to the vertical tower and staying clear of the mounts (how. Do I know this,..it wasn't pretty). Larger seems like a good notion though.
                        Think a larger size would be useful if this got extended to two hot ends in the future.
                        • A Former User?
                          A Former User
                          Im in for a full set as soon as they become available.
                          Thinking out loud on the wider spacing : would there be any noticeable deflection with the wider rod separation ?
                          And personally I would be modifying my Prometheus hotend to fit the effector, therefore could i ask for a picture of the modified e3d hotend out of the effector to see whats going on.
                          • davidbatesundefined
                            davidbates
                            Just wanted to stop in and say this is looking fabulous. I've been looking for a solution to house multiple tool heads with quick disconnects and this looks perfect for that.
                            A couple of features I'd really like to see:
                            1. A single connector on the back that can be universal for all the different tool heads (hot end, laser, cnc, touch probe, etc)
                            2. That single connector is a magnet style both for safety and for a quick change.
                            3. I'd like for the rods to carry current either for the connections needed (there are 6 connectors) or for fault-tolerant break detection.
                            4. a purple color from osh?
                            Again really good work and thanks for sharing. If there's a beta or early product tester program sign me up.
                            • njjn2020undefined
                              njjn2020
                              @davidbates:
                              i vote for magnetic quick change too. as for connector - if i change tool, how than board will differentiate which tool is connected?
                              if it does then firmware may automatically adapt for the tool.
                                The PCB effector uses two connectors, one for signal wires and one for power wires. This is to reduce the risk of mis-wiring causing a short. A magnetic connector might work for the signal wires, but I doubt that it could be used for the power wires.
                                • elmoretundefined
                                  elmoret
                                  @dc42:
                                  Apple shoves 85w through Magsafe! πŸ˜„
                                  • A Former User?
                                    A Former User
                                    @elmoret:
                                    Have you seen the repair percentage on apple products power circuit ? a prime example of what NOT to do…......
                                    • jrledererundefined
                                      jrlederer
                                      So the big question is when to expect availability on this seemingly very cool and precise product development?
                                      "Insanity is doing the same thing over again, yet expecting different results..." --Albert Einstein
                                      • saffiundefined
                                        saffi
                                        @jrlederer:
                                        Once you make a defined scheduled, circumstances beyond your control will always delay it three to six months!
                                        Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
                                          jrlederer
                                          Haha good ol' Murphy hard at work…
                                          • inachisiojexusundefined
                                            inachisiojexus
                                            I'm also very interested in this as I may need to replace the somewhat bulky aluminum effector on my TEVO delta in order to fit a DyzEnd-X hotend. In the meantime I'm going for a hacky solution. πŸ™‚
