    Thermal runaway not active by default?
    Firmware installation
    515
    • singhm29
      singhm29 last edited by
      Hey!
      I did the initial firmware setup for my Duet Ethernet via the online configuration tool and I now have everything working except the safety angle.
      If I disconnect my thermistor I would expect it to force a shutdown but it jumps to 2000 and still allows me to command the printer (homing X axis etc). I'm pretty certain I haven't taken anything out that would nullify the safeties but at the same time, I haven't explicitly declared anything in my config file as I had initially thought this was set by default.
      Thanks!
      • Veti
        Veti last edited by
        see
        https://duet3d.dozuki.com/Wiki/FireSafety
        the duet will shut down the heating elements on a fault.
        the axis movement is not effected by a heater fault.
        • singhm29
          Monitoring the console I don't see any errors being thrown either though is that normal?
          • PaulHew
            PaulHew last edited by PaulHew
            I beleive the safety is built in in regards to your max bed and tool temps.
            Did you try to heat the hotend up when the thermistor was disconnected?
            It won't shutdown so nothing will work, hence why you can move your axis's.
            I think it gives you a 'Heater Error' and you would have to reboot the control board to clear the error.
            HTH. P.
            Edit - Veti beat me too it!
            RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
            Voron 2.4 disassembled..... Waiting for the RailCore Mini....
              dc42 administrators @singhm29 last edited by
              @singhm29 said in Thermal runaway not active by default?:
              You should get a Heater Fault message on the GCode Console in Duet Web Control, on PanelDue if you have one, and sent to USB. The heater will be in the Fault state (this will be shown by DWC) and you will need to reset the Duet or send M562 to clear the fault.
              singhm29 1 Reply Last reply Reply Quote 0
              • singhm29
                singhm29 @dc42 last edited by singhm29
                @dc42 That's what I thought! Am I missing something in my config? https://pastebin.com/bRCFi4gR (also how do people add code snippets directly to posts in that scrollable window?) I'm using a PT100 if that makes a difference. Oddly I now see that at the top of my config it says it was setup for a Duet Wifi when I had set it up for a Duet ethernet.
                • A Former User
                  A Former User last edited by
                  look up markdown formatting
                  • T3P3Tony
                    T3P3Tony administrators @singhm29 last edited by
                    @singhm29 do you have a PT100 plugged in to the first port on the PT100 daughterboard?
                    I have pinned the how to format posts:
                    https://forum.duet3d.com/topic/10618/adding-images-files-etc-managing-notifications-in-posts
                    www.duet3d.com
                    • singhm29
                      @t3p3tony said in Thermal runaway not active by default?:
                      Its attached to RTD1 and is a 2 wire E3D PT100.
                      • T3P3Tony
                        @singhm29 apologies I just reread your initial post and see your thermistor is working but you are disconnecting it to test.
                        As others have said when it's disconnected the heater that it is associated with should display "fault" in DWC. If that happens it is working as intended.
                        www.duet3d.com
                        • singhm29
                          No problem! The issue however is that I get a reading of 2000 instead of fault and no error in DWC making me wonder what I've done wrong in the setup to have the safeguards disabled
                            If you are getting readings of 2000, the heater will go into the fault state as soon as you try to heat it up. It will not go into the fault state or report any other error as long as you leave it turned off.
