    Initial Homing issues - Sequence of Errors
    2.5k
    • B0M0A0Kundefined
      B0M0A0K @dc42
      @dc42 Thanks again for taking the time to reply. I ran through the commissioning guide you pointed me to and confirmed that just about everything is working with the exception of testing homing. I am focused on getting Home X working first. When I click on Home X the print head moves towards the stopswitch, but stops before it get's there (it moves about 80mm to the left).
      No fate but what we make ....
      A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
      • B0M0A0Kundefined
        B0M0A0K @Phaedrux
        @phaedrux Thank you!
        • A Former User?
          A Former User @B0M0A0K
          @b0m0a0k said in Initial Homing issues - Sequence of Errors:
          you need to increase the travel distance in the home file.
          it probably reads something like G1 X80 S1change the X80 part to match the length of your X axis + a little extra. (Possibly G0 instead of G1, makes no difference)
            dc42 administrators @B0M0A0K
            That could be caused by a few different things:
            1. In the configurator you specified that the size of your printer was much smaller than it actually is. Send M208 from the console and check that the reported min/max axis limits look right.
            2. You have specified the incorrect steps/mm, so that the motor is not moving as much as it should. Use G91 then G1 S2 moves to check that the motors are moving the right amount. For example, when you send G1 S2 X50 F1000 check that the amount of movement is 50mm.
            3. You are getting interference on the endstop wires, or you have a bad connection in one of them. This is uncommon, but possible if you have the endstop wires running right next to stepper motor wires over a considerable distance.
            Please post your config.g, homex.g, homey.g, homex.g and homeall.g files.
            B0M0A0Kundefined 1 Reply Last reply Reply Quote 0
            • B0M0A0Kundefined
              B0M0A0K @dc42
              @dc42 I will get back to this tonight and post the requested files. Thanks.
              • B0M0A0Kundefined
                B0M0A0K
                @dc42 As promised, here are my home config files;
                config.g
                ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
                ; generated by RepRapFirmware Configuration Tool v2 on Wed May 29 2019 19:19:18 GMT+0100 (British Summer Time)
                M550 P"Removed" ; Set machine name
                M551 P"Removed" ; Set password
                M552 S1 ; Enable network
                M587 S"Removed" P"Removed" ; Configure access point. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M569 P0 S1 ; Physical drive 0 (X) goes forwards
                M569 P1 S0 ; Physical drive 1 (Y) goes forwards
                M569 P2 S1 ; Physical drive 2 (Z) goes backwards
                M569 P3 S0 ; Physical drive 3 (E) goes forwards
                M350 X128 Y128 Z128 E16 I0 ; Configure microstepping without interpolation
                M92 X80.00 Y80.00 Z400.00 E100.00 ; Set steps per mm
                M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z600.00 E600.00 ; Set maximum speeds (mm/min)
                M201 X1000.00 Y1000.00 Z100.00 E5000.00 ; Set accelerations (mm/s^2)
                M906 X855.00 Y855.00 Z855.00 E855.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X200 Y200 Z180 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Set active low and disabled endstops
                M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
                M557 X25:175 Y25:175 S20 ; Define mesh grid
                M305 P0 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 0
                M143 H0 S60 ; Set temperature limit for heater 0 to 60C
                M305 P1 T100000 B3988 R4700 ; Set thermistor + ADC parameters for heater 1
                M143 H1 S210 ; Set temperature limit for heater 1 to 210C
                M563 P0 D0 H1 ; Define tool 0
                T0 ; Select first tool
                homez.g
                ; homez.g
                ; called to home the Z axis
                G91 ; relative positioning
                G1 S1 Z-185 F1800 ; move Z down until the endstop is triggered
                G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
                ;G91 ; relative positioning
                ;G1 S2 Z5 F100 ; lift Z relative to current position
                ;G90 ; absolute positioning
                homey.g
                ; homey.g
                ; called to home the Y axis
                G1 S1 Y-205 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                G1 Y5 F6000 ; go back a few mm
                G1 S1 Y-205 F360 ; move slowly to Y axis endstop once more (second pass)
                G1 Z-5 F6000 S2 ; lower Z again
                homex.g
                ; homex.g
                ; called to home the X axis
                G1 S1 X-205 F1800 ; move quickly to X axis endstop and stop there (first pass)
                G1 X5 F6000 ; go back a few mm
                G1 S1 X-205 F360 ; move slowly to X axis endstop once more (second pass)
                homeall.g
                ; homeall.g
                ; called to home all axes
                G1 S1 X-205 Y-205 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                G1 X5 Y5 F6000 ; go back a few mm
                G1 S1 X-205 Y-205 F360 ; move slowly to X and Y axis endstops once more (second pass)
                G1 S1 Z-185 F1800 ; move Z down stopping at the endstop
                G92 Z0 ; set Z to axis minimum (you may want to adjust this)
                G1 S1 Z5 F100 ; lift Z relative to current position
                • A Former User?
                  A Former User
                  Your M208 and G1 commands say it should be allowed to move more than 80mm. Are you certain the steps/mm is correct?
                    Phaedrux Moderator @B0M0A0K
                    Delete that line now that you've connected to the wifi router.
                    It's a good idea to stick to x16 microstepping with interpolation to x256 and calculate your steps per mm based on x16 at least until everything is working properly, then if necessary you can experiment with other microstepping values, but generally, x16 interpolated will give the best results.
                    100mm/s might be a little slow for travel moves.
                    @bearer said in Initial Homing issues - Sequence of Errors:
                    I think your microstepping being set to x128 is making your steps per mm value of 80 incorrect. 80 may be correct for x16 though. This would explain why the axis isn't moving as much as you are requesting.
                    • B0M0A0Kundefined
                      B0M0A0K
                      OK, so thanks to the combined suggestions of @bearer and @Phaedrux we have progress. I changed the line;
                      to
                      M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
                      as per your suggestions. The I re-ran all the home commands one axis at a time. Movement was much similar to what it had been with the old Melzi board setup. All axes homed to the stop switches, backed off a little and then slowly recontacted with the stop switches. They all stopped their movement with the stop switch activated (all red stop switches on the board active).
                      I'm not sure if this is a new feature that I need to get used to (and I can see it in the config files for each axis), but before starting the Home process on X & Y they all raise Z before proceeding.
                      The one that worries me here is the Z axis. When it triggers the stop switch it is pressed hard against the bed, so I need to back that off a little. I have tried lowering the bed as much as it will go and its still pressed hard.
                      • A Former User?
                        you'll get the same movement but smoother motion if you change the I0 to I1 to enable interpolation.
                        • B0M0A0Kundefined
                          B0M0A0K @A Former User
                          Thanks, am giving that a try now.
                          • B0M0A0Kundefined
                            B0M0A0K
                            I am wondering if the issue with the Z axis hitting the bed is because I am using a glass plate as the bed surface. The end stop switch was adjusted to allow for this, but I am wondering if there is a need to allow for that in the homez.g file?
                            ; homez.g
                            G1 S1 Z-400 F1800 ; move Z down until the endstop is triggered
                            • A Former User?
                              A Former User
                              Not quite sure how this is built, but sounds like you need to move your z-switch. but strange if it worked before you replaced the board.
                              • B0M0A0Kundefined
                                .. but strange if it worked before you replaced the board.
                                Yes, that's what bothers me as well.
                                • A Former User?
                                  A Former User
                                  Not familiar with the printer, maybe you could add a picture showing the bed, the switch and the axis raised, and showing the bed, switch and axis lowered?
                                  or maybe first double check that the switch triggers correctly again, it really shouldn't need any force at all.
                                  • B0M0A0Kundefined
                                    B0M0A0K
                                    I think I have fixed the Z-Axis issue. By moving the Z-Axis up by hand prior to each homing test I had inadvertently unbalanced the Z-Axis (the left hand was at a different level to the right). I have now re-balanced the Z-Axis and this time, when I tested homing I was still able to get the paper under with enough room to adjust the bed height.
                                    I'm going to run that test a couple more times just to be sure.
                                      It's there commands that are raising the z axis before each homing move.
                                      This is to give the nozzle some clearance before moving things around.
                                      In the Z homing files you can have it automatically raise the z axis again to give some clearance as well.
                                      So if you remove the ; on those lines it will raise another 5mm for clearance.
                                      Is the endstop trigger height modifiable? Either with a set screw, or moving the switch mount position? You could also add a spacer if you need it to trigger sooner.
                                      Does the switch stop movement if you trigger it by hand before the nozzle hits the bed?
                                        Yes that could definitely explain it. The X axis must be parallel to the bed.
                                        If you have 2 Z motors you can hook each up to a separate driver and then use a self leveling routine to get them evened before printing. You'd need a Z probe for this to be most effective.
                                        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
                                        • B0M0A0Kundefined
                                          B0M0A0K @Phaedrux
                                          @phaedrux OK, so I wasn't going to mention this until I was happy that basic operation was working properly, but I have a BLTouch sitting here ready to be installed as well. Am looking forward to adding that once the basic operation with the new board has been confirmed.
                                          Next step is to "Home All" and see what happens.
                                          • B0M0A0Kundefined
                                            B0M0A0K
                                            Is it normal for the printer to return to needing Home on all axes every time you move something on the bed. Seems like each time I move something and then go to use "Head Movement" I get this sort of thing;
                                            M120
                                            G91
                                            G1 Z5 F6000
                                            M121
                                            Error: G0/G1: insufficient axes homed
