    Notification in Telegram
    12
    535
    • juanmena
      juanmena last edited by
      First of all thank you always answer all the questions and always give an answer, and good work.
      Some time ago, we talked about notifying on Telegram the status or completion of an impression (a job), but I do not see that it has been implemented, which is strange, since other applications apparently not so advanced, if they offer that possibility.
      Is there already in Duet?
      Thank you.
      • DocTrucker
        DocTrucker last edited by
        What do you mean by telegram? Link to the original thread?
        I'd suggest priority is low because with the high accuracy of the print time simulation it isn't really needed.
        Alternatives include using DWC to check the status either from the local network or through using VPN to get onto your network.
        Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
        • juanmena
          I mean, it would be very good, to get a warning to Telegram or something similar, when the printing is finished, to the mobile.
            How bout this?
            https://forum.duet3d.com/topic/7745/duet-telegram-bot
            • juanmena
              A pity to have to have a Raspberry and that is not directly in the Duet
                See also https://forum.duet3d.com/topic/9626/new-m-code-to-send-a-network-request.
                Does Telegram use MQTT, HTTP, or some other protocol?
                • A Former User
                  Some other protocol https://core.telegram.org/mtproto
                  (But the Bot API is https)
                  • hector
                    hector last edited by hector
                    From the Spanish telegram community of Duet we are making an integration with Nodered, to have bot, timelapse, dashboard for various duet machines ...
                    soon we will have an image for raspberry to release preconfigured, with which anyone can continue to customize ๐Ÿ˜œ
                    mqtt bridge include in this option, read data from duet api, use in flow and inject to mqtt server, o in the include server in the pi
                    Leds control is macro call in the duet board, and the macro set the pwm in pin in expansion port, and read with small arduino or wemos, and change the effect.
                    is possible set effect for heating, error, printing, homing, finish etc...
                    IdefixRC andymidtf madeinta1wan 3 Replies Last reply Reply Quote 1
                    • IdefixRC
                      IdefixRC @hector last edited by
                      @hector Ohhhhhh man.....finally ๐Ÿ™‚ been waiting for this for a long time (first raised a request for some sort of notification back in 2017.
                      Please let me know once the image is available. I have a Pi Zero connected to the duet already and use it as webcam so it should be a quick install (hopefully) โœŒ
                      • andymidtf
                        andymidtf @hector last edited by
                        @hector que tal va eso? Algรบn avance?
                        How is this going? Any news?
                        • madeinta1wan
                          madeinta1wan @hector last edited by
                          @hector Did you manage to get a working Telegram bot running? I know it's been some time since you posted and others have asked but I thought I'd check.
                          -Nate
                            Phaedrux Moderator @madeinta1wan last edited by
                            @madeinta1wan said in Notification in Telegram:
                            -Nate
                            See here: https://forum.duet3d.com/topic/7745/duet-telegram-bot
