    Internet with Raspberry Pi and Crossover Cable?
    • bugsysiegals
      bugsysiegals last edited by
      I've the Duet Maestro which I've move to another room temporarily and have to borrow the VOIP ethernet cable to connect; however, I have a Pi in the same room which runs off WiFi. I'm wondering if it's possible to use a crossover cable between the Pi and Duet and allow it to access the internet so I don't have to borrow the cable?
        That should work if you can configure the Pi to work as a bridge or a router.
        • T3P3Tony
          T3P3Tony administrators @bugsysiegals last edited by
          @bugsysiegals this should help.
          https://www.raspberrypi.org/forums/viewtopic.php?t=132674
          www.duet3d.com
          Cata 1 Reply Last reply Reply Quote 0
          • Cata
            Cata @T3P3Tony last edited by
            @t3p3tony
            Can this be a problem? From the link
            ""This method works by creating a DHCP server on the Pi's ethernet connection and internally it 'shares' the internet access between eth0 and wlan0. A device connected to the Pi's ethernet will get an IP address from the Pi, not the WiFi, but will still have internet access. ""
            • Veti
              Veti last edited by
              install openwrt on it an follow this guide
              https://openwrt.org/docs/guide-user/network/wifi/relay_configuration
              • Maut
                Maut last edited by
                Yes, you can use the Pi as a router. I'm using something similar on my Duet Maestro and Pi:
                https://github.com/arpitjindal97/raspbian-recipes/blob/master/README.md
                https://github.com/arpitjindal97/raspbian-recipes/blob/master/wifi-to-eth-route.sh
