Laser power adjustment/speed
@phaedrux said in Laser power adjustment/speed:
I'm not sure if that comment that the Duet doesn't support G1 S moves to control the laser is accurate anymore as of firmware 2.02
Oh cool! I'm not up to date on Duet/ RRF since firmware 2.0 came out. So then the question will become how well RepRapFirmware handles these lines such as G1 X0.1 S0.6 F6000 (that's Smoothieware syntax, or in RRF case S255) when receiving several thousands of them a second for image rastering.
I don't know what the performance of that will be like.
Speeds were slow when we tested it with the "Marlin-resembling" previous syntax, and to be clear, that was the source of my comments in the LightBurn Forum.
@raykholo ha! I expected you'd find your way here eventually, but not in practically real time! Small world of people with these overlapping interests I suppose. I appreciate your help so far!
@raykholo said in Laser power adjustment/speed:
You can choose the S value (255, 1.0 or any other value you like) that represents full laser power, see the R parameter in the M452 command.
We are already talking to LighBurn about high speed rastering and I have proposed a laser rastering extension to the G1 command. See https://docs.google.com/document/d/1SMWFJUXfRSxe-p-veWEP-NU3A9ESKU_TVGB1Y1ADAV8/edit?usp=sharing.
@dc42 said in Laser power adjustment/speed:
requires access, you want do deal with the requests or make it public?
I'm sorry about that, I've updated the link in my post above. Try again.
Laser velocity ramping is now working in the RRF 3 beta at https://www.dropbox.com/sh/3azy1njy3ayjsbp/AACquxr2m00eV568RZg5QG5wa?dl=0.
Perfect timing, just got a new low power uv laser to use with photosensitive pcbs - hope to test it asap
The laser power is adjusted every 5 milliseconds at present during acceleration and deceleration. I hope this is OK. In the longer term I will probably make the adjustment interval the greater of 3ms and 5 cycles at the laser PWM frequency.
Wow this post has been so helpful! I will be following the progress with lightburn integration closely, I'm so excited to hear that you're already working on it. RRF has the potential to be outstanding with laser as it is with filament!
Best,
Stefan -
Do you have any idea of when Lightburn compatibility might come to fruition? I'm so happy to hear that you were working on it, but I can't get a sense of if its moving along or just something that was discussed and left alone.
Thanks,
Stefan -
@clearlynotstef said in Laser power adjustment/speed:
Thanks,
StefanLightBurn compatibility in what sense? I am fairly certain that firmware 2.03 and 3.0beta are already compatible with LightBurn. The difference is that 3.0beta implements velocity ramping.
Do I need to activate this velocity ramping or does it just work as is when in laser mode?
@TonyPagett said in Laser power adjustment/speed:
RRF3 implements velocity ramping when in laser mode, provided that you specify the laser power using S parameters on the G1 commands. So you don't need to enable it in Lightburn. RRF2 does not.
@dc42 Thank you.
My next question is this. The following code moves the laser (CNC) in the defined square but only switches the laser on for the first line (or one side of the square).
M3 S255
G1 Y75.0000 Z0.01000 F2500.0
G1 X75.00000
G1 Y25.00000
G1 X25.00000
M03 S0If I add an S command to each line it works OK
Is there a way round this?
Select "laser power sticky" in your M452 command. Preferably, don't use M3 to set the laser power, just use a S parameter on the first G1 move.
How do I do this?
@dc42 You put "Laser power sticky" in M42 .
That's what threw me -
That's what threw meSorry about that!
Not a problem
It would appear that I am on RRF2 as I am using a WorkBee from Ooznest so the velocity ramping is not useable
