    Duet Wifi not detected
    908
    • vamatis
      vamatis last edited by
      I recently received my Duet Wifi 3D board, and wanted to have a first look at it today.
      I tried to configure the network using the instructions on that page: https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
      Unfortunately, my board isn't recognized on my macbookpro.
      The 3 leds 3.3v, 5v and usb are lit.
      I also tried to power it from an external power supply before connecting the usb, but with no more results.
      What else can I check?
      Thank you very much,
      nick
      Stephen6309 1 Reply Last reply Reply Quote 0
      • Stephen6309
        Stephen6309 @vamatis last edited by
        @vamatis https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
        • vamatis
          Thank you very much for the answer. I just tried it. I now also have the "diag" led lit, but still nothing showing up when going for ls /dev/tty.*
            Have you tried using a different USB cable?
            • vamatis
              yes, I tried that too 🙂
                Is this relevant https://forum.duet3d.com/topic/9796/no-usb-connection-on-macbook-duet-2-wifi-first-start ?
                Also, I have a feeling that you may need ls /dev/tty* without the '.'.
                • vamatis
                  Just tried both (/de/tty*) and looking directly in the /dev/ folder, and nothing appears 😞
                  • vamatis
                    Apparently it's my macbook that must be the problem.. I tried connecting it to a friend's pc, and I got the bossa port.... Which enabled me to load the firmware..
                    Is there any way to setup the wifi connection other than the serial method?
                    thanks
                    • Veti
                      Veti last edited by
                      open a terminal and issue the dmesg command after the usb connection.
                      there should be some information regarding the usb connection.
                        dc42 administrators @vamatis last edited by
                        @vamatis said in Duet Wifi not detected:
                        thanks
                        You can set up the wifi connection on your friend's PC if you know the SSID and password for your network. Both are case sensitive.
                        • vamatis
                          Sorry for the very long delay, I haven't had time to retry the board and try to finally setup my board to revive my printer. Just came back to it after a black friday crazy buy of the hemera setup.
                          I tried to get the board to work again, on a windows 7 pc that time, but I can't get anything else than "the device malfunctioned and windows can't recognize it" so I can't flash the board (it is in recovery mode, with the diag led on)
                          What did I mess up?
                          thanks
                            Windows does that sometime, it appears that it can't handle the speed with which a Duet can reboot. The usual fix is to plug it into another USB port; or if you are using a USB hub, disconnect the hub from Windows and then reconnect it; or reboot Windows.
                            vamatis 1 Reply Last reply Reply Quote 0
                            • vamatis
                              vamatis @dc42 last edited by vamatis
                              What did I mess up?
                              thanks
                              I tried all 3 of the ports I have on the pc, all do the same... I tried the sd procedure also to reflash the FW, but I can't get the diag led to stay off..
                              • vamatis
                                Ok, so I've an other computer today, on another version of windows just to make sure.... And all I can get is "unknown device"
                                I can't get the damn bossa port to show up 😢
                                At that point, I don't really know what I'm supposed to do? Is there someone I can send the board to to have it checked or setup?
                                thank you
                                Nick
                                  dc42 administrators @vamatis last edited by dc42
                                  Have you installed the Windows device driver? You can download it from https://github.com/dc42/RepRapFirmware/blob/dev/Driver/DuetDriverFiles.zip. However, if you've already installed the Windows version of Bossa then I think you should already have a suitable driver installed.
                                  If you display the properties of the unknown device, what VID and PID does it give?
                                  • vamatis
                                    Ok, I finally got the board working! I had to build a custom cable connected directly to the external usb header of the motherboard to get my stupid computer to see it as bossa port..
                                    Firmware flashed, network configured, all good now!
                                    Thank you very much for the support!
                                    Corexy 1 Reply Last reply Reply Quote 0
                                    • Corexy
                                      Corexy @vamatis last edited by
                                      @vamatis
                                      Can you please show how to make the custom cable (connected directly to the external usb header of the motherboard) you have described?
                                      I seem to be having the same problem, and have run out of options.
                                      vamatis A Former User 2 Replies Last reply Reply Quote 0
                                      • vamatis
                                        vamatis @Corexy last edited by
                                        @Corexy said in Duet Wifi not detected:
                                        @vamatis
                                        Don't think I still have it but I basically cut a usb cable to connect it on the internal USB expansion header of my computer...
                                        • A Former User
                                          A Former User @Corexy last edited by A Former User
                                          @Corexy you'll find the pinout in your motherboard manual; and colour coding of the cut usb cable on google.
                                          most motherboards i've seen follow this layout though, can measure to confirm if you don't have the manual to double check,
                                          • Corexy
                                            Corexy last edited by Corexy
                                            That's a pretty big step going onto the motherboard lol....missus will kill me if I mess about with the computer like that.
                                            So you think it's the actual USB plug on the computer giving trouble??
                                            I've got 2 dead boards here, both have been reset. One won't read at all, and the other is showing a bossa port but fails to write the firmware each time.
                                            Surely it's either connecting or it isn't?
                                            And thank you very much for getting back to me, appreciated.
                                            • A Former User
                                              A Former User last edited by
                                              It seems to have been in the case for that user; utilizing a unused usb header seemed to work for him.
                                              Its no different than the wiring for front panel usb connectors, the header is usually keyed with one pin missing so you could take 2x5 dupont housing, plug a hole, crimp some terminals and make up cable that is more or less impossible to connect the wrong way (if made correctly ofc)
                                              • deckingman
                                                deckingman last edited by
                                                I'm not expert by any means but I have a built a few PCs in my time. I can see how this might happen because the last one I built, I wanted to fit a USB hub/card reader and bought about 3 before I found one that played nicely. Even now, sometimes when I get a Windows update, that USB hub / card reader will start to misbehave and it always takes me a few hours to get it working properly again.
                                                • vamatis
                                                  vamatis @deckingman last edited by
                                                  @deckingman said in Duet Wifi not detected:
                                                  the problem is that on a lot of computers, the front outside usb ports are soldered and built like shit and it apparently made the board hickup and not connect properly...
                                                    dc42 administrators @Corexy last edited by
                                                    ... the other is showing a bossa port but fails to write the firmware each time.
                                                    Does it write but fail to verify? If so, that can be caused by the Erase jumper still being in place/Erase button being stuck down.
