CONN_LCD wiring for external driver
  • I've remapped XYZ to the external stepper drivers, its working fine - and I'll be using 2 internal drivers for E0 and E1, now I wanted to connect my 6th external driver for U Axis - CONN_LCD have only 4 pins (Step 10, En10, DIR10, Stop 10) but I needed 6 wires to be connected to my external driver (Pul+, Pul-, Dir+, Dir-, ENA+ and ENA-), please guide to connect the external driver with CONN_LCD connector. Thanks
    It depends on whether the 3.3V low current outputs on CONN_LCD are sufficient for your external driver. If they are:
    • Pul+ to the Step output
    • Dir+ to the Dir output
    • Pul- and Step- to ground
    • If Ena is an enable input, then Ena+ to +3.3V and Ena- to the Enable output. But on some drivers it is really a Disable input; in which case, Ena+ to the Enable output and Ena- to ground.
    If your drivers need more drive, then someone published a level shifting circuit on this forum not long ago.
  • Thank you so much, I've done the wiring as instructed, stepper getting locked but not moving, sharing the Gcode , am I doing anything wrong, pls guide
    ; generated by RepRapFirmware Configuration Tool v2 on Fri Jun 21 2019 17:25:23 GMT+0530 (IST)
    M550 P"BIG FACTORY" ; Set machine name
    M551 P"3m3d" ; Set password
    M552 S1 ; Enable network
    M587 S"MMM" P"KINGS1234" ; Configure access point. You can delete this line once connected
    M586 P0 S1 ; Enable HTTP
    M586 P1 S1 ; Enable FTP
    M586 P2 S0 ; Disable Telnet
    M584 X5 Y6 Z7 U10 E3:4 ; create the U axis and assign stepper driver 10 to it
    M569 P5 S1 ; Physical drive 5 goes forwards
    M569 P5 R1 T2.5:4:5:0
    M569 P6 S1
    M569 P6 R1 T2.5:4:5:0 ; Physical drive 6 goes forwards
    M569 P7 S1
    M569 P7 R1 T2.5:4:5:0 ; Physical drive 7 goes forwards
    M569 P3 S1 ; Physical drive 3 goes forwards
    M569 P4 S1 ; Physical drive 4 goes forwards
    M569 P10 S1
    M569 P10 R1 T2.5:4:5:0 ; Physical drive 10 goes forwards
    M584 X5 Y6 Z7 U10 E3:4 ; Apply custom drive mapping
    M350 X32 Y32 Z32 U32 E32:32 I0 ; Configure microstepping without interpolation
    M92 X80.00 Y80.00 Z4000.00 U80.00 E420.00:420.00 ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 U900.00 E120.00:120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 U6000.00 E1200.00:1200.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 U500.00 E250.00:250.00 ; Set accelerations (mm/s^2)
    M906 X800.00 Y800.00 Z800.00 U800.00 E800.00:800.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X1800 Y1200 U1850 Z1800 ; Set axis maxima
    M208 X-50 Y0 U0 Z-0.2 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the edge of the bed)
    M574 X1 Y1 Z0 U2 S1 ; Set endstop configuration (X and Y endstops at low end, U endstop at high end, active high, no Z endstop)
    M307 H7 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M280 P7 S10 I0
    M558 P9 H7 F120 T6000 ; Set Z probe type to bltouch and the dive height + speeds
    G31 P500 X50 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
    M557 X15:6 Y15:1190 S100 ; Define mesh grid
    M141 H4 ; Assign chamber heater to heater 4
    M305 P4 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 4
    M143 H4 S100 ; Set temperature limit for heater 4 to 100C
    M305 P1 X200 ; Configure PT100 for heater 1
    M143 H1 S500 ; Set temperature limit for heater 1 to 500C
    M305 P2 X201 ; Configure PT100 for heater 2
    M143 H2 S500 ; Set temperature limit for heater 2 to 500C
    M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M106 P2 S1 I0 F500 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P0 S"FIRST" D0 H1 F0 ; Define tool 0
    M563 P1 S"SECOND" D1 H2 X3 F2 ; Define tool 1
    G10 P1 Y0 U0 Z0 S0 R0 ; set tool 1 offsets and temperatures
    M563 P2 S"MIXED" D0:1 H1:2 X0:3 F0:2 ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
    G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
    G10 P2 X500 Y0 U-500 S0 R0 ; set tool offsets and temperatures
    M567 P2 E1:1 ; set mix ratio 100% on both extruders
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
  • @milan said in CONN_LCD wiring for external driver:
    B4138 is the default value in the web ui and most likely not correct for your thermistors. An incorrect thermistor setting will report the wrong temperature.
    Can you confirm that the stepper is initially not locked, but it locks when you first try to move it and then remains locked until you reset the Duet or send M18?
    If so, try increasing the T2.5 on the M569 P10 command. With only 3.3V drive, the step pulse may need to be a little longer.
  • Its locked from the beginning and remain locked till switch off, I've tried increasing the T2.5 to till T5, but no change , the stepper getting lil warmer , other than that no change happening, pls help
    My guess is that the Enable input of your driver is actually a Disable input, and that the CONN_LCD outputs don't provide sufficient drive to your stepper drivers.
  • In that case, what could be the solution - Can I remap E0 to U and CONN_LCD pins to E0 (so that I can have Nema17 connected to CONN_LCD for extruder 0 - will this work -or please suggest the alternative to run this system
    See https://forum.duet3d.com/topic/9683/additional-stepper-drivers-on-duex-5 for a suggested buffer circuit between CONN_LCD and external drivers.
  • dc42 ADMINISTRATORS 6 Apr 2019, 15:01
    For a 74HCT365 or 74HCT367 (either will do) in 16-pin DIL package:
    Pins 1,8,15 - ground
    Pin 16 - +5V
    Pins 2,4,6,10,12,14 - inputs from CONN_LCD
    Pins 3,5,7,9,11,13 - +outputs to stepper driver +input pins (connect the -input pins of the stepper driver to ground)
    Also connect a 0.1uf capacitor between pin 16 and ground.
    A few stepper drivers have a common +input pin. For those, use a 74HCT366 or 74HCT368 instead, connect the driver -input pins to the outputs of the chip (pins 3,5 etc.), and connect the common +input of the driver to +5V.
    Take great care not to short +5V to any of the other pins on CONN_LCD.
    HTH David
    I've done the level shifting circuit, one clarification required,
    Which means, should I connect 2,4,6 to Driver Pulse+, DIR+, ENA+
    10, 12, 14 to Pulse-, DIR-, ENA- respectively?
    Here is a pinout diagram of the 74HCT365:
    Connect /G1, /G2 and GND to ground, and connect Vcc to +5V. For the rest, pins 2 and 3 are one input/output pair, 4 and 5 are another, and so on. So here is one possible connection scheme, for one external driver:
    STEP_10 from CONN_LCD to pin 2 (1A)
    DIR_10 from CONN_LCD to pin 4 (2A)
    EN_10 from CONN_LCD to pin 6 (3A)
    Pin 3 (1Y) to STEP+ on external driver
    Pin 5 (2Y) to DIR+ on external driver
    Pin 7 (3Y) to ENA+ on external driver
    STEP-, DIR- and ENA- from external driver to GND.
    You can use the A and Y pins on the other side of the chip in a similar way for a 2nd external driver.
  • Thank You so much David, I wonder how could you mange to provide solution for every problem worldwide... Thank you once again , I'll connect as instructed..
  • Thank you so much, Its working flawlessly ...help me with endstop connectivity for this channel 10
    What endstop connectivity problem do you have?
  • Should we use Stop 10 Enc_B and Gnd for channel 10 Endstop?
    Do we need to remap the other endstops in firmware as we do for Axis remap, we are using channel 5,6&7 for XYZ. Thanks
    In firmware 2.03 and earlier, when you create axes the endstop inputs are allocated automatically. So if you create axes U and V in your M584 command then U will use the E0 input and V will use the E1 input.
    In firmware 3.0 beta you have to allocate endstops for additional axes and specify the input pins using M574.
