    Power Duet3D over usb?
    553
    • CNCModellerundefined
      CNCModeller
      So this is probably a stupid question but...
      Can I permanently power the logic board from a standard usb power supply via the on board usb connector? I am using external stepper drivers via a "Duet Expansion breakout board" and the heaters are also powered via external modules.
      Any thoughts would be much appreciated.
      Cheers
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
      • DocTruckerundefined
        DocTrucker
        You can provide 5VDC to the board via the three way connector that has the PS_ON on it. The USB connector isn't really intended for regular use but you should be able to tell from the schematics if it is essentially doing the same as I suggest anyway. Not sure if some functions are shut down when VIN is not detected.
        • zaptaundefined
          zapta
          You can see the relevant schematic at the third page here https://github.com/T3P3/Duet/blob/master/Duet2/Duet2v1.04/DuetWifiv1.04a_Schematic.pdf
          5V in and USB seem to feed to the same point.
            CNCModeller
            Thanks folks.
            The board seems to run fine with 5v from the usb so I'll stick with it for now as there doesn't seem to be any specific issues in the schematic.
            Cheers
            Barry M
            Wanhao D4S: Duet2
            K40 Laser, Duet2
            Wanhao D5S
            • zaptaundefined
              zapta
              @cncmodeller, do you run it also with vin (e.g. 12V or 24V)? Is so, did you disconnect JP9 to disable the on-board 5V buck converter?
              I presume this is what JP9 is for, anybody willing to comment?
              DocTruckerundefined 1 Reply Last reply Reply Quote 0
                DocTrucker @zapta
                @zapta you do need to disable the converter. There a header pin jumper that is moved or removed.
                  CNCModeller
                  I'm only running the logic board on 5v so haven't pulled the jumper. I probably should do though just to prevent future forgetfulness. I don't have power running to the 12v connection as I'm not using the drivers or heater outputs of the Duet3D board. I have external stepper drivers running at 36v.
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                  nopheadundefined 1 Reply Last reply Reply Quote 0
                  • nopheadundefined
                    nophead @CNCModeller
                    @cncmodeller Seems like you are not using most of the Duet, just the CPU and the Wifi or Ethernet module. You could probably just use an Arduino Due with a breakout board and a Wifi module.
                      dc42 administrators @nophead
                      @nophead said in Power Duet3D over usb?:
                      But then the file upload to the SD card over the network would be very slow, and he wouldn't get Duet Web Control.
                      CNCModellerundefined 1 Reply Last reply Reply Quote 0
                        CNCModeller @dc42
                        @dc42 said in Power Duet3D over usb?:
                        Personally I'm more than happy with using the duet as I believe in rewarding the development effort involved in creating a good product. I'm using closed loop stepper drivers hence the break out. I guess either closed loop on board or a cut back board without drivers would be a more cost effective solution but I'm more than happy to do prototyping this way. I may use the on board drivers for less position critical functions like a filiment changer etc.
                        Thanks for the feedback
                        Cheers
                        Barry M
                        Wanhao D4S: Duet2
                        K40 Laser, Duet2
                        Wanhao D5S
