    PEI surface without adhesive?
    38
    2.7k
      Phaedrux Moderator @Nxt-1
      @nxt-1 said in PEI surface without adhesive?:
      flat-ish
      Since you want to transfer heat evenly between the two plates I would think you'd want it more than just flat-ish.
      • mrehorstdmdundefined
        mrehorstdmd
        I think you would want the base that the heater is attached to to be tooling plate for the flatness and thermal conductivity, and then use a simple piece of aluminum sheet which will conform to whatever it sits on for the other piece. If you do it the other way, the base won't be flat and thermal performance will suffer.
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @mrehorstdmd
          @mrehorstdmd said in PEI surface without adhesive?:
          This might be the way I will have to do it as finding tooling plate available to Belgium, EU as a consumer seems to be no easy feat. Best I could find was https://www.aluminiumwarehouse.co.uk/ and the thinnest they cary is 5mm. Doing two sheets of 5mm would be to much thermal mass I believe as well as rather expensive.
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          • NitroFreakundefined
            NitroFreak
            you can do it with a vacuum bed.
            That´s the way I´m doing it.
            Works perfectly with all kinds of sheets. Here is me printing ABS on a PEI sheet
            Here is PPSU being printed on a PEI sheet
            You just have to remember that you shouldn´t go above 190°C on the bed/chamber temp with the PEI sheet, otherwise this will happen
            You will basically thermoform the PEI onto the build plate and it will flow into the channels.
            For this reason most of the time i use borosilicate glass plates for printing high temperature stuff.
            I can´t use magnets because at those high temperatures they would demagnetize.
            Cheers
            Max
            • Nxt-1undefined
              Nxt-1 @NitroFreak
              @nitrofreak Holy crap, that is amazing. I have vacuum clamping in metal machining centers, but never on a 3D-printer. A quick Google leads me to believe that ready made tables are quite expensive though. Also, I am not sure if I would want a vacuum pump running for hours on end in my room. I love the idea though.
              • A Former User?
                A Former User @Nxt-1
                If the system didn't leak (much) and had some pressures control the pump would not run continuously. In an ideal setup it would just pull the vacuum and turn off, but I suspect in the real world some leakage would be expected, but I don't think it would require constant running.
                  NitroFreak
                  Yes exactly you can just turn on the pump, pull a vacuum (takes only a second) and switch it off. it holds around two hours more or less. In future i want to include a small reservoir and a digital pressure gauge that kicks the pump on once it goes above the threshold pressure. For long prints i just let the pump run while i´m away.
                  you can get machining vacuum plates relatively inexpensively.
                  https://www.ebay.de/itm/Vakuumtisch-VT2020-R-20mm-Raster-aus-Gussaluminium-fur-CNC-Frase/292939802580?hash=item443492a7d4:g:aVcAAOSwPVFcUX7o
                  This is a 20x20cm bed, but it is available in all kinds of sizes. It even has the side mounted vacuum connectors.
                  I just made my own out of a 15mm cast aluminum plate because i have acess to a cnc, and i can mill it to size.
                  I also used brake line and crimp connectors that can handle the heat going into the chamber. Outside it is connected to the Z axis and changes to a PU tube which goes to the vacuum pump.
                  • Nxt-1undefined
                    Nxt-1
                    I finally found a local source for 6mm cast and milled aluminium plate. Could you guys agree with the following layer stack (bottom to top):
                    1 - Silicone heater
                    2 - 6mm cast aluminium plate
                    3 - 3mm regular 1050 aluminium plate
                    4 - 3M glue sheeth
                    5 - 0.2mm PEI sheet
                    Feedback welcome, especially on the thickness of layer 3. I am also still kind of unsure how good of a thermal contact and flatness I can expect between the two sheets of aluminium.
                    mrehorstdmdundefined botundefined 2 Replies Last reply Reply Quote 0
                      mrehorstdmd @Nxt-1
                      @nxt-1 I'd go with thicker PEI. I use 0.7mm stuff on a couple printers and it lasts for years. The thin stuff will stretch a bit when you try to pull an ABS or PETG print off, and will end up with air bubbles under it (just had to replace the plate on a Prusa I3 for that).
                      • botundefined
                        bot @Nxt-1
                        @nxt-1
                        Why do you want to sandwich two aluminum plates together?
                        Also, I’m a bit late for the discussion, but I use a PEI sheet without adhesive. I use a thicker sheet (3.2 mm iirc) and I use a custom clamp around the perimeter of the bed. Works great, although it’s not perfect. My next attempt I will lap the cast plate and pie sheet together on a granite surface plate to get a precision flat print surface.
                        *not actually a robot
                        • Nxt-1undefined
                          Nxt-1 @mrehorstdmd
                          Thanks for the experience, I look around if I can find some a little ticker for a reasonable price.
                          @bot said in PEI surface without adhesive?:
                          @nxt-1
                          Other users have reported PEI sheets without adhesive starting to deform and warp at temperature. So I wanted to back it with a thin sheet of aluminium, while still maintaining a removable bed.
                          botundefined NitroFreakundefined 2 Replies Last reply Reply Quote 0
                          • botundefined
                            bot @Nxt-1
                            @nxt-1 Oh I see. I don't think that is a good idea. You'll get no benefit of the flat surface of the cast tool plate.
                            • Nxt-1undefined
                              Nxt-1 @bot
                              That is the main thing that has still got me not 100% convinced. I wouldn't bother with the added complexity of a removable sheet if the bed didn't take as long to cool as it does.
                              botundefined 1 Reply Last reply Reply Quote 0
                              • botundefined
                                bot @Nxt-1
                                @nxt-1
                                Aren't there removable, thin steel flexible sheets with PEI coatings these days? That sounds like something you'd like.
                                Or, perhaps, you could have the PEI glued to the cast tool plate and simply have two of those that you can swap out.
                                • Nxt-1undefined
                                  Nxt-1 @bot
                                  @nxt-1
                                  How would that differ from what I am planing to make, apart from it being off the shelf?
                                  I plan of having the silicone heater permanently glued to the back of the heat spreader.
                                    NitroFreak @Nxt-1
                                    @nxt-1 said in [PEI surface without adhesive?]
                                    if you mean me, i doubt this will happen in a normal environment. that was literally at 210 degrees surface temperature.
                                    • Nxt-1undefined
                                      Nxt-1 @NitroFreak
                                      @nitrofreak said in PEI surface without adhesive?:
                                      I was mainly referring to @CHarding.
                                      • Nxt-1undefined
                                        Nxt-1
                                        If I can source some decently priced thicker PEI, I might just all the materials for both approaches with and without extra aluminium and experiments what works
