Piezo Settings
  • I'm using the Orion Piezo sensor on my hypercube build, so it uses the nozzle as the probe. I have it set so that I can see under machine properties that it is changing to yes for a split second every time I tap the nozzle with my finger, but when I do a homeall and I tap the nozzle the bed does not stop moving.
    What am I missing? I'll post my files below
  • ; Configuration file for Duet WiFi (firmware version 1.21)
    ; generated by RepRapFirmware Configuration Tool v2 on Mon May 20 2019 16:31:14 GMT-0700 (Pacific Daylight Time)
    M667 S1 ; Select CoreXY mode
    M550 P"DaveHevo" ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P0 S0 ; Physical drive 0 goes forwards
    M569 P1 S0 ; Physical drive 1 goes forwards
    M569 P2 S0 ; Physical drive 2 goes backwards
    M569 P3 S0 ; Physical drive 3 goes forwards
    M92 X80.00 Y80.00 Z400.00 E420.00 ; Set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z180.00 E1500.00 ; Set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z20.00 E10000.00 ; Set accelerations (mm/s^2)
    M906 X1000.00 Y1000.00 Z1200.00 E800.00 I50 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X568 Y498 Z700 S0 ; Set axis maxima
    M574 X1 Y1 Z1 S0 ; Set active low endstops
    M558 P8 Z1 I1 R0.4 F300 X0 Y0 Z1 ;analogue mode,NC, delay, speed, used as axis endstop
    G31 X0 Y0 Z-.2 P600 ; Set Z probe trigger value, offset and trigger height
    M557 X10:5 Y15:195 S20 ; Define mesh grid
    M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
    M563 P1 D0 H1 ; Define tool 1
    G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
    G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
  • ; homeall.g
    ; called to home all axes
    G91 ; relative mode
    G1 S1 X-240 Y-240 F3000 ; coarse home X or Y
    G1 S1 X-240 ; coarse home X
    G1 S1 Y-240 ; coarse home Y
    G1 X4 Y4 F600 ; move away from the endstops
    G1 S1 X-10 ; fine home X
    G1 S1 Y-10 ; fine home Y
    G1 X250 Y250 F6000 ; go to first bed probe point and home Z
    ;G91 ; relative positioning
    ;G1 S2 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v2 on Mon May 20 2019 16:31:15 GMT-0700 (Pacific Daylight Time)
    G1 X250 Y250 F6000 ; go to first probe point
    Can you confirm that you have connected the piezo to the Z probe connector on the Duet, not the Z endstop input?
  • I think I can see what's wrong.
    You have your Z end stop misconfigured. Your setup says:
    I also use the Orion on my V-Core and it is set up like this:
    M574 Y1 X1 S0 ; Set active LOW endstops for X and Y at minimum
    M574 Z1 S2 ; Z end stop is probe at low value
    M558 P8 R0.4 I1 H5 F360 T6000 ; Set Z probe type to inverted, unfiltered piezo and the dive height + speeds
    G31 P500 X0 Y0 Z-0.02 ; Set Z probe trigger value, offset and trigger height
    M557 X5:290 Y5:280 P14 ; Define mesh grid
    Note the second M574 which defines the Z end stop as being a Z probe (S2 parameter). My Orion is connected to the Z-probe input on the Duet WiFi.
  • Oh, you'll also find it's a good idea to uncomment the parts of homeall.g and homez.g which lift the head again after probing. Otherwise, you risk scraping the nozzle over your bed on the next move.
    @grizewald said in Piezo Settings:
    Actually, that isn't needed, provided that you home Z using a G30 command, which is the correct way to home Z using a Z probe, and what @57buick is doing.
  • @dc42 said in Piezo Settings:
    Ah, OK. It certainly isn't harming anything though.
    In 57buick's configuration, his Z end stop is included in the same M574 command that has S0 as the parameter. If this works, then what's the point of the S2 parameter to M574?
    The S2 parameter is needed for printers such as the RepRapPro Ormerod and Huxley Duo, because those printers use a single IR sensor to home both X and Z. So S2 is used in the M574 X command.
    OMG, Yes I was installing my X and Y endstops at same time and I plugged the piezo into the Z stop instead of the Z probe port, thank you, it's working now
