    Elimination of ripples
    • hussainsail2002
      hussainsail2002 last edited by
      I have built a custom machine that had ripples on the surface using an MKS gen 1.4 board, Once I changed the board to Duet It was eliminated.
      Wondering what the reason could be ?
      above picture is before changing.
      • JamesM
        JamesM last edited by
        They don't look eliminated to me...just looks like they are finer which could just be from the microstepping.
        clearlynotstef 1 Reply Last reply Reply Quote 1
        • clearlynotstef
          clearlynotstef @JamesM last edited by
          @jamesm agree. Wonder what that's about. Op, have you carefully calibrated your esteps?
          • hussainsail2002
            I feel it has definitely improved by a large extent, will try calibrating e steps again.
            It was mentioned somewhere that e-steps need to be whole numbers and not fractions, is that true ?
            DocTrucker 1 Reply Last reply Reply Quote 0
            • DocTrucker
              DocTrucker @hussainsail2002 last edited by DocTrucker
              @hussainsail2002 I've used decimal without issue.
              ...but equally interested to see if there is anything more than circumstantial evidence showing otherwise.
              • clearlynotstef
                clearlynotstef last edited by
                I use decimals as well
